Discuss
No Heat
 in
Dryer Repair
Dryer runs but no heat generated, Changed heating element, still no change. Appreciate any help.
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » No Heat
  #1 (permalink)
Old 10-10-2007, 02:26 AM
Gboyz Gboyz is offline
Junior Member
Gboyz is on a distinguished road
Default No Heat
Model Number: LEC8858DZO   Brand: Whirlpool   Age: 5 - 10 years
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-10-2007, 04:51 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Common failure items, thermal fuse, circuit breaker, burnt wire. Should have a meter to check things.
__________________
  #3 (permalink)
Old 10-10-2007, 08:48 AM
Junior Member
Default
No burnt wires, did test power source to element and no power read.
  #4 (permalink)
Old 10-10-2007, 03:20 PM
Pegi's Avatar
Pegi Pegi is offline
Senior Expert
APP Volunteer
Pegi is on a distinguished road
Default
Check the cut-off fuse on the side of the heating element canister, the one above the safety thermostat....this is assuming you have 240 volts going to the dryer???
__________________
-Serving North Central Texas and Southern Oklahoma since 1978.
www.samsservicesenter.com
  #5 (permalink)
Old 10-10-2007, 08:38 PM
Junior Member
Default
Yes, 240v is read. Is there a way to test the cut off fuse. I tested accross the fuse on the resistance scale and did not get a reading (open).
  #6 (permalink)
Old 10-11-2007, 02:56 AM
Senior Expert
APP Volunteer
Default
That is your problem.These come as a kit with a safety thermostat. Thermostat is self-resettable and saves the fuse from blowing P # 279973
Check your dryer venting and remove clogs all the way to outside, they sell a 4 inch brush for this.
Appliance parts pros should have the kit, just call.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Heat but not drying, seems like heat is not blowing good Papa1 Dryer Repair 2 10-07-2007 11:11 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
