Hello My Estate dryer shuts off after 10 min, I have replaced every sensor, Timer, Motor. There is no shorts anywhere that i see. Oiled all the pullies, And still shuts off after it gets hot, after cools down can restart it and again it will run for 10 min Sensors that i replaced are as follows ( high temp, cycling sensor, thermostate,timer, fuse on the back, and the motor) Heating element is fine and check for 220 cleaned all vents. Still can't find problem any sugestions would be great, almost have new dryer with all the new parts.:mad: :confused: all replacement parts are factory original
