Discuss
Dryer Squeaks When Drum Turns
 in
Dryer Repair
My dryer squeaks when the drum turns. everything works fine but the squeaking noise is very annoying. I've checked
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer Squeaks When Drum Turns
  #1 (permalink)
Old 10-09-2007, 04:46 PM
Ruben1 Ruben1 is offline
Junior Member
Ruben1 is on a distinguished road
Default Dryer Squeaks When Drum Turns
Model Number: GLER341AS0   Brand: Frigidaire   Age: 1 - 5 years
My dryer squeaks when the drum turns. everything works fine but the squeaking noise is very annoying. I've checked the felt seal and the drum belt and I can't figure out what the problem is. Can anyone help me please?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-10-2007, 11:34 AM
whatupwitthat whatupwitthat is offline
Junior Member
whatupwitthat is on a distinguished road
Default worth a try
hello,
Going through some issues with my dryer of which squeaky while turning is one. I opened front end and took out tensioner and cleaned completed with dawn dishwash stuff returned tensioner and so far it has been quiet as a mouse.
  #3 (permalink)
Old 10-10-2007, 08:31 PM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
For Ruben:
Remove drum by lifting rear ball out of the socket. Use high temperature grease in the socket, that should fix it. Click on your model # for assembly info or parts.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer drum doesnt turn eric1025 Dryer Repair 3 10-07-2007 03:47 AM
Something hitting the drum when it turns janjan Washer Repair 2 10-05-2007 04:49 PM
Dryer drum won't turn tlathan Dryer Repair 1 08-15-2007 05:12 PM
Only 1 fan speed / Unit turns itself off KenK Heating, Ventilation, and Air Conditioning (HVAC) 0 08-09-2007 09:25 AM
Maytag Dryer: Drum Not Turning miatahowie Dryer Repair 2 07-26-2007 08:18 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
