Nevadaman
#1 Posted : Tuesday, November 25, 2008 12:20:34 PM(UTC)
Nevadaman
The dryer will not start. There is power to the unit, I have replaced the door switch and the thermostat control but still will not run. When unit is plugged into power there is a "clicking" noise from the timer unit that doesn't stop regardless of the postion. Suggestions? Thank you.
#2 Posted : Tuesday, November 25, 2008 6:52:28 PM(UTC)
Which thermostat did you replace?
Most likely the problem is an open thermal fuse which comes together with the hi-limit thermostat.
- The part number for the thermostat kit is AP415996
#3 Posted : Wednesday, November 26, 2008 1:19:46 AM(UTC)
Here is your parts breakdown a wiring diagram is included
Model CDE22B6V
The ticking is probably the timer.
Use timed dry to troubleshoot, it is the easiest.
Circuit path is NEUTRAL / THERMAL FUSE NON RESETTABLE / DOOR SWITCH C to NO contacts / MOTOR / START SWITCH / TIMER contacts L to M / L1
Once the motor starts the MOTOR CENTrifugal SWITCHes trip, this removes the AUX (start) winding from the circuit and the RUN winding now gets power through the TIMER contacts L to M. Also the other MOTOR CENT SWITCH switches in the heater circuit.
Timer contacts L to M should be closed except when timer is at OFF
Timer contacts L to TM should be closed for the entire timed dry cycle, they are not closed for most of the AUTO cycles as the timer gets it's power from a different circuit path.
If your THERMAL FUSE NOT RESETTABLE is blown, be sure to give the interior a good cleaning including the blower wheel. Also clean and check your vent system.
The best/safest way to check the fuse is with a meter.
If you do not have a meter you can
Unplug the unit
Short the two wires to the fuse together
Tape them together so they cannot short to anything
Plug it in and give it a try.
If shot replace both the Safety Thermostat (High Limit) and the thermal fuse as shown in Gene's post, they come both are in the kit.
Nevadaman
#4 Posted : Wednesday, November 26, 2008 8:43:14 AM(UTC)
Nevadaman
The one I ordered and replaced the old one with was part #AP311676
I did in fact short the two leads together to test it but it had no effect and still wouldn't run. It will not run regardless of what position the timer is in as well.
#5 Posted : Wednesday, November 26, 2008 9:11:57 AM(UTC)
That is the wrong item, it is the cycling thermostat.
The ones you want are on the heater case.
Model CDE22B6V
Heater section Item 5. High limit and thermal fuse.
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest 2/23/2024 11:17:20 AM(UTC)
Dryer won't start after changing fuses and timer (Dryer Repair)
by Guest 1/17/2023 11:21:44 AM(UTC)
Dryer Won't start - Repair Video (Dryer Repair)
by Guest 8/8/2021 1:55:18 PM(UTC)
Kenmore 100 Series Dryer Won't Start (Dryer Repair)
by juser 11/7/2020 4:44:16 PM(UTC)
Gas dryer won't start at all (Dryer Repair)
by GuyGreg 2/21/2018 2:26:33 PM(UTC)
Dryer won't start (Dryer Repair)
by Ginadrc 1/26/2018 7:24:30 PM(UTC)
by Petem 12/2/2017 3:27:50 PM(UTC)
Maytag dryer won't start (Dryer Repair)
by eagle243 11/15/2017 6:44:39 PM(UTC)
Dryer won't start after replacing the heating element (Dryer Repair)
by ivyholly 6/8/2017 6:45:42 PM(UTC)
Dryer Won't Start-Lights Blinking (Dryer Repair)
by rleigh 6/5/2017 9:20:31 AM(UTC)
Inglis dryer won't start (Dryer Repair)
by jkeefe 4/20/2017 2:48:09 AM(UTC)
Amana Dryer won't start, but still gets hot (Dryer Repair)
by halfmoonranch 3/15/2017 9:38:33 AM(UTC)
Dryer won't start (mid-troubleshooting, could use some help) (Dryer Repair)
by OUberLord 3/13/2017 7:15:55 PM(UTC)
Whirlpool Dryer Won't Start (Dryer Repair)
by agjr200hp 2/5/2017 5:36:21 AM(UTC)
Dryer won't start all the time (Dryer Repair)
by DaHadster 1/10/2017 12:25:28 PM(UTC)
