jrl1125
#1 Posted : Monday, December 27, 2010 11:40:10 AM(UTC)
jrl1125
Replaced the thermal fuse and the cycle thermostat. checked to make sure gas was working, and can see the ignitor glow red for approx. 10 sec. then goes out. That will happen approx every minute. Just seems it won't light. What is a fix for this problem. Clog? New sensor...ect.
#2 Posted : Monday, December 27, 2010 2:03:44 PM(UTC)
If the igniter does glow but the gas would not flow, then most likely the problem is a bad gas valve coils. If you do have an ohmmeter then you can check the coils as instructed in one of our previous threads: http://forum.appliancepartspros...er-runs-but-no-heat.html
- The coil kit Part number: AP3094251
jrl1125
#3 Posted : Monday, December 27, 2010 2:33:35 PM(UTC)
jrl1125
thank-you very much Gene! is there a diagram somewhere i could see where they are located. i couldn't find it on the diagram of parts and numbers or it even listed. Thanks again!
#4 Posted : Wednesday, December 29, 2010 10:46:09 PM(UTC)
They are shown as #13 & #14 on the diagram.
You also can see a picture of them in one of our previous threads: http://forum.appliancepartspros...ace-coils-gas-valve.html
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
no heat from oven or broiler (Oven Repair (including Ranges and Cooktops))
by lennyag 1/5/2024 1:41:07 PM(UTC)
Dryer loud squeaking and no heat (Dryer Repair)
by hackerfam 11/2/2023 10:52:15 AM(UTC)
LG Dryer DLE2301R No Heat (Dryer Repair)
by mhess01 10/19/2023 4:56:37 PM(UTC)
No heat when assembled (Dryer Repair)
by Guest 8/16/2023 3:44:03 AM(UTC)
whirlpool PN# W10339417; no heating after replacing element (Oven Repair (including Ranges and Cooktops))
by Guest 7/13/2023 12:27:07 PM(UTC)
Whirlpool Duet Electric dryer - no heat (Dryer Repair)
by ShawnDS24 2/25/2023 9:08:24 AM(UTC)
No heat, (Dryer Repair)
by tseibring 1/8/2023 7:57:44 AM(UTC)
Brand New LG gas dryer , GAS code, no heat (Dryer Repair)
by lglad 11/24/2022 7:24:02 PM(UTC)
Gas Dryer GE GFDS355GL0MS No Heat. Ignitor is good E11 error. (Dryer Repair)
by jim.starzynski@gmail.com 7/5/2022 6:35:29 PM(UTC)
Dryer starts, does not stop, no heat (Dryer Repair)
by Guest 6/28/2022 11:03:33 AM(UTC)
Samsung Electric Range-No Heat (Oven Repair (including Ranges and Cooktops))
by Jimh64 6/27/2022 8:39:17 AM(UTC)
Samsung Dryer DV448AEP/XAC - no heat (Dryer Repair)
by mgmjtech 5/18/2022 8:22:27 PM(UTC)
heeat turns on no heat comming up through floor register (Heating, Ventilation, and Air Conditioning (HVAC))
by Guest 2/6/2022 2:57:49 PM(UTC)
LG Gas Dryer No Heat - Control Panel? (Dryer Repair)
by TomDBBills 1/29/2022 4:03:42 PM(UTC)
