The dryer works OK in the manual mode, but in auto mode the dryer will only operate in the "more dry" section of the timer. When turned toward the less dry section the dryer stops. This doesn't seem like a timer problem, is there a moistsure sensor that isn't operating properly? Model is 110.96591240.
