Discuss
no heat
 in
Dryer Repair
hello; Came home the other day after being gone for 4 hours and the dryer was still running. put in
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » no heat
  #1 (permalink)
Old 12-26-2010, 02:26 PM
Junior Member
michigantrucker41 is on a distinguished road
Default no heat
Model Number: lgr5636eq3   Brand: Whirlpool   Age: 5 - 10 years
hello;
Came home the other day after being gone for 4 hours and the dryer was still running. put in next load and had no heat and the timer would not move unless on time dry.
Seen the no heat check list. just want to double check. removed wired from the thermal fuse and check with meter it shows open. Do I remove the wires to check? Did I see some where you could put the wires together to make sure it is the problem? will not leave this way never bypass a safty switch to fix something. big fire danger thenk you
Ads By Google
Related Models
Whirlpool LGR5636EQ3
Whirlpool LGR5636EZ0
Whirlpool LGR5636EZ1
Whirlpool LGR5636EZ2
Whirlpool LGR5636EZ3
Whirlpool LGR5636JQ0
Whirlpool LGR5636JQ1
Whirlpool LGR5636JT0
Whirlpool LGR5636JT1
Whirlpool LGR5636KQ0
Whirlpool LGR5636KQ1
Whirlpool LGR5636KT0
Whirlpool LGR5636KT1
Whirlpool LGR5636LG0
Whirlpool LGR5636LQ0
Whirlpool LGR5636LQ1 29"gas Dryer
Whirlpool LGR5636LT0
Whirlpool LGR5636LT1 29"gas Dryer
Whirlpool LGR5636LW0
Whirlpool LGR5636PQ0 29"gas Dryer
Whirlpool LGR5636PQ1 29"gas Dryer
Whirlpool LGR5636PT0 29"gas Dryer
Whirlpool LGR5636PT1 29"gas Dryer
Whirlpool LGR5638AN0
Whirlpool LGR5638AN1
Whirlpool LGR5638AN2
Whirlpool LGR5638AN3
Whirlpool LGR5638AW0
Whirlpool LGR5638AW1
Whirlpool LGR5638AW2
Whirlpool LGR5638AW3
Whirlpool LGR5644AN0
Whirlpool LGR5644AN1
Whirlpool LGR5644AN2
Whirlpool LGR5644AW0
Whirlpool LGR5644AW1
Whirlpool LGR5644AW2
Whirlpool LGR5644EQ0
Whirlpool LGR5644EQ1
Whirlpool LGR5644EQ2
Whirlpool LGR5644EQ3
Whirlpool LGR5644EZ0
Whirlpool LGR5644EZ1
Whirlpool LGR5644EZ2
Whirlpool LGR5644EZ3
Whirlpool LGR5644JQ0
Whirlpool LGR5644JQ1
Whirlpool LGR5644JQ2
Whirlpool LGR5644JQ3 29" Gas Dryer
Whirlpool LGR5644JT0
Whirlpool LGR5644JT1
Whirlpool LGR5644JT2
Whirlpool LGR5644JT3 29" Gas Dryer
Whirlpool LGR5644PQ0 29" Gas Dryer
Whirlpool LGR5644PQ1 29" Gas Dryer
Whirlpool LGR5700KQ0
Whirlpool LGR5700KQ1
Whirlpool LGR5700KT0
Whirlpool LGR5700KT1
Whirlpool LGR5848EQ0
Whirlpool LGR5848EQ1
Whirlpool LGR5848EQ2
Whirlpool LGR5848EQ3
Whirlpool LGR5848EQ4
Whirlpool LGR5848EQ5
Whirlpool LGR5848EQ6
Whirlpool LGR6611LQ0
Whirlpool LGR6611LQ1 29"gas Dryer
Whirlpool LGR6611PQ0 29" Gas Dryer
Whirlpool LGR6620PQ0 29"gas Dryer
Whirlpool LGR6620PQ1 29"gas Dryer
Whirlpool LGR6620PT0 29"gas Dryer
Whirlpool LGR6620PT1 29"gas Dryer
Whirlpool LGR6621PQ0 29" Gas Dryer
Whirlpool LGR6634BN0
Whirlpool LGR6634BN1
Whirlpool LGR6634BN2
Whirlpool LGR6634BQ0
Whirlpool LGR6634BQ1
Whirlpool LGR6634BQ2
Whirlpool LGR6634BW0
Whirlpool LGR6634BW1
Whirlpool LGR6634BW2
Whirlpool LGR6634DQ0
Whirlpool LGR6634DQ1
Whirlpool LGR6634DW0
Whirlpool LGR6634DW1
Whirlpool LGR6634DZ0
Whirlpool LGR6634DZ1
Whirlpool LGR6636PW0 29" Gas Dryer
Whirlpool LGR6636PW1 29" Gas Dryer
Whirlpool LGR6638DQ0
Whirlpool LGR6638DQ1
Whirlpool LGR6638DW0
Whirlpool LGR6638DW1
Whirlpool LGR6638DZ0
Whirlpool LGR6638DZ1
Whirlpool LGR6644DQ0
Whirlpool LGR6644DQ1
Whirlpool LGR6644DZ0
Whirlpool LGR6644DZ1
Whirlpool LGR6646BN0
Whirlpool LGR6646BN1
Whirlpool LGR6646BN2
Whirlpool LGR6646BW0
Whirlpool LGR6646BW1
Whirlpool LGR6646BW2
Whirlpool LGR6646DN1
Whirlpool LGR6646DW1
Whirlpool LGR6646PW0 29" Gas Dryer
Whirlpool LGR6646PW1 29" Gas Dryer
Whirlpool LGR6848AN0
Whirlpool LGR6848AN1
Whirlpool LGR6848AN2
Whirlpool LGR6848AQ2
Whirlpool LGR6848AW0
Whirlpool LGR6848AW1
Whirlpool LGR6848AW2
Whirlpool LGR6848AZ2
Whirlpool LGR7620KQ0
  #2 (permalink)
Old 12-27-2010, 04:38 AM
Senior Expert
APP Volunteer
kayakcrzy will become famous soon enough
Default
It saounds like one of my post!! Jump out the white thermal fuse, and tape up the wire terminals, so they don't hit metal, and see if it comes on. Tom Appliance Educator, Appliance Parts, Washer and Dryer Parts, Refridgerator and Freezer Parts, Stove and Oven Parts
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper (Gas) Dryer heats up then heat goes off (still running, no heat) jtdesignsca Dryer Repair 3 01-17-2013 12:06 PM
Kenmore dryer heats on low heat but not on high heat Mrhollywood334 Dryer Repair 0 09-11-2010 09:33 PM
No High Heat, Medium heat work fine! Scubadude Dryer Repair 0 09-07-2010 05:39 PM
Dryer stops after a few minutes with heat on - will run continuously with heat off somegeek Dryer Repair 0 05-27-2010 01:35 PM
Normal Heat Empty, Heat Shuts Off Full BigDaddyG Dryer Repair 4 08-06-2009 03:17 PM
