My GE dryer model DX4500EA1WW will not stop drying. For start I thought it was the timer( because it stay at the same spot it start), but after a brand new part replaced, it still act the same. the timer seem to stuck wherever it start. I'm now not sure that it's the timer or anything else, please help.:confused:
Put the dryer timer on the TIMED DRY cycle, Does it move on this cycle? If it does, Pull it apart and check the heating element, I'll bet that 1/2 of the element is broken!!!:)
In deed the timed dry cycle is working perfectly good. Only the automatic part that's not function. I'll check the element and report back. Big THANKs,:D
