LRose
#1 Posted : Sunday, November 23, 2008 1:15:26 PM(UTC)
LRose
This electric dryer will no longer get hot enough. I have thoroughly cleaned out lint from dryer and discharge chute.
Lee Rose
Drags1998
#2 Posted : Sunday, November 23, 2008 1:32:28 PM(UTC)
Drags1998
If thats the correct Model# listed, I got some bad news for you. The dryer is AT LEAST 30 YEARS OLD!!!! Not 5-10 as you listed,But anyway, The heater is most likely SHORTED to ground by a coin or another metal object!!! Its quite a job to repair this heater, The cabinet must be removed because the element is located against the inside of the front panel.
Kenmore 100 dryer Heating Element (Dryer Repair)
by postalservice21 3/27/2024 6:43:17 AM(UTC)
LG dryer heat stops during load (Dryer Repair)
by Guest 4/15/2023 10:14:22 AM(UTC)
LG Dryer Heater Thermistor Error (Dryer Repair)
by Guest 11/16/2022 8:37:57 AM(UTC)
Dryer heating in timed cycle but now heating in oher cycles (Dryer Repair)
by bblossm 2/19/2022 4:32:16 PM(UTC)
Dryer heating sometimes (Dryer Repair)
by Guest 2/13/2022 4:07:15 PM(UTC)
Kenmore Dryer Heat and Run issue (Dryer Repair)
by IDConundrum 10/26/2020 7:06:47 PM(UTC)
Whirlpool dryer heats for a bit then stops (WGD6400SW1) (Dryer Repair)
by don_caruana 9/2/2020 6:35:54 PM(UTC)
Samsung Electric dryer heating issue (Dryer Repair)
by £∆Z€R* 6/18/2020 10:08:23 AM(UTC)
Gas Dryer heat cycles on and off (Dryer Repair)
by Al Lynch 4/23/2020 10:47:08 AM(UTC)
Kemore elite dryer heating coil not heating (Dryer Repair)
by kenmodel 1/27/2020 7:50:40 PM(UTC)
Samsung Dryer heats then stops working and begins beeping. (Dryer Repair)
by jmm0816 6/1/2019 5:54:04 AM(UTC)
Dryer Heats, but drum does not turn (Dryer Repair)
by tzmango 2/21/2019 1:47:43 PM(UTC)
Dryer heats up but takes too long to dry (Dryer Repair)
by bear0729 11/13/2018 6:35:10 AM(UTC)
Electric Admiral Dryer heating problems. (Dryer Repair)
by ShaneBurle24 7/12/2018 8:32:23 AM(UTC)
dryer heats but won't spin (Dryer Repair)
by nugentc 4/26/2018 8:09:40 AM(UTC)
