dryer won't start. • power's good • start relay ok • timer makes noise (like it's trying) only while relay is held in, nothing once released • that's about all i can find/see. not sure how to open the main compartment to test/check the other things (therm. fuze, etc.) • was going to test for continuity on the timer but the one i found i could not find a wiring diagram to go with it to see what the terminals are connected to to match it to mine (as my terminal lettering is different) Originally Posted by: Gene Open the control panel and check for continuity between the BK & BK-BU and the T & W timer terminals while the timer is in any "on" position. If there is no continuity then the timer is the culprit. - The timer Part number: AP2947073
Gene. any help would be greatly appreciated.
