Discuss
Maytag gas dryer won´t heat, igniter receiving no voltage, other parts OK
 in
Dryer Repair
Have already checked all electrical parts involving the heating process as described within this helpful forum. Hi limit Thermostat continuity
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag gas dryer won´t heat, igniter receiving no voltage, other parts OK
  #1 (permalink)
Old 11-23-2008, 09:20 AM
Junior Member
erwin68 is on a distinguished road
Smile Solved! Maytag gas dryer won´t heat, igniter receiving no voltage, other parts OK
Model Number: MDG7400AW   Brand: Maytag   Age: 1 - 5 years
Hi limit Thermostat continuity OK
Cycling Thermostat continuity OK
Igniter (114 ohm) OK. this is a new one because in the first place suspected of failure because of too low ohm reading.
Flame sensor continuity OK
Gas valve coils
coil with 2 terminals 1266 ohm
coil with 3 terminals 1358 ohm across left and middle, 553 ohm across left and right
Adittional voltage readings during operation:
input voltage: 122 v AC
voltage reading at igniter connector: 0.3 v AC (drum working, hi heat setting). This same voltage has been tracked up to the input at the "temp switch" and up to the corresponding output at the timer connector. This reading changes to 10 v AC when not operating the dryer.
Already checked gas line up to the dryer connection.
Any help please. Could it be some component on the upper control panel, lets say timer?
Thank you.
Erwin.
Ads By Google
Related Models
Maytag MDG7400AWQ DRYER- GAS
Maytag MDG7400AWW DRYER- GAS
Maytag MDG7460AWQ DRYER- GAS
Maytag MDG7460AWW DRYER- GAS
Maytag MDG7500AWQ DRYER- GAS
Maytag MDG7500AWW DRYER- GAS
Maytag MDG75MNAWW MANUAL, PARTS (DRYER GAS)
Maytag MDG75MNVWQ MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75MNVWW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PN1AW MANUAL, PARTS (DRYER GAS)
Maytag MDG75PN2VW MANUAL, PARTS (DRYER GAS)
Maytag MDG75PNAVW MANUAL, PARTS (DRYER GAS)
Maytag MDG75PNHWQ MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PNHWW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PNVVQ MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PNVVW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PNVWQ MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PNVWW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG7600AWQ DRYER- GAS
Maytag MDG7600AWW DRYER- GAS
Maytag MDG7657AWQ DRYER- GAS
Maytag MDG7657AWW DRYER- GAS
Maytag MDG7657BWQ DRYER- GAS
Maytag MDG7657BWW DRYER- GAS
Maytag MDG7658AWQ DRYER- GAS
Maytag MDG7658AWW DRYER- GAS
Maytag MDG7658BWQ DRYER- GAS
Maytag MDG7658BWW DRYER- GAS
Maytag MDG76PCBWS MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG76PCBWW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG7757AWQ DRYER- GAS
Maytag MDG7757AWW DRYER- GAS
Maytag MDG7758AWQ DRYER- GAS
Maytag MDG7758AWW DRYER- GAS
Maytag MDG77PNAWW COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG77PNSWW COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG8000AWQ DRYER- GAS
Maytag MDG8000AWW DRYER- GAS
Maytag MDG8000BWQ DRYER- GAS
Maytag MDG8000BWW DRYER- GAS
Maytag MDG8057AWQ DRYER- GAS
Maytag MDG8057AWW DRYER- GAS
Maytag MDG8057BWQ DRYER- GAS
Maytag MDG8057BWW DRYER- GAS
Maytag MDG8058BWQ DRYER- GAS
Maytag MDG8058BWW DRYER- GAS
Maytag MDG8400AWQ DRYER- GAS
Maytag MDG8400AWW DRYER- GAS
Maytag MDG8416AWA DRYER- GAS
Maytag MDG8416AWW DRYER- GAS
Admiral MDG8426AAW DRYER- GAS
Admiral MDG8426AEW DRYER- GAS
Admiral MDG8426AGW DRYER- GAS
Maytag MDG8500BWW DRYER- GAS
Maytag MDG8506AWA DRYER- GAS
Maytag MDG8506AWW DRYER- GAS
Admiral MDG8550AGW DRYER- GAS
Admiral MDG8550BGW DRYER- GAS
Maytag MDG8600AWQ DRYER- GAS
Maytag MDG8600AWW DRYER
Maytag MDG8757AWQ DRYER- GAS
Maytag MDG8757AWW DRYER- GAS
Maytag MDG9206AWA DRYER- GAS
Maytag MDG9206AWW DRYER- GAS
Maytag MDG9206AXW DRYER- GAS
Maytag MDG9206BWW DRYER- GAS
Maytag MDG9306AWA DRYER- GAS
Maytag MDG9306AWW DRYER- GAS
Maytag MDG9306AXA DRYER- GAS
Maytag MDG9306AXW DRYER- GAS
Maytag MDG9316AWA DRYER- GAS
Maytag MDG9316AWQ DRYER- GAS
Maytag MDG9316AWW DRYER- GAS
Maytag MDG9316AXW DRYER- GAS
Maytag MDG9316BWQ DRYER- GAS
Maytag MDG9316BWW DRYER- GAS
Maytag MDG9357AWA DRYER- GAS
Maytag MDG9357AWW DRYER- GAS
Maytag MDG9360BWW DRYER- GAS
Maytag MDG9390AWW DRYER- GAS
Maytag MDG9390AXW DRYER- GAS
Maytag MDG9390BWW DRYER- GAS
Maytag MDG9420BWW DRYER- GAS
Maytag MDG9520BWQ DRYER- GAS
Maytag MDG9520BWW DRYER- GAS
Maytag MDG9557AWA DRYER- GAS
Maytag MDG9557AWQ DRYER- GAS
Maytag MDG9557AWW DRYER- GAS
Maytag MDG9557AXQ DRYER- GAS
Maytag MDG9557AXW DRYER- GAS
Maytag MDG9557BWQ DRYER- GAS
Maytag MDG9557BWW DRYER- GAS
Maytag MDG9606AWA DRYER- GAS
Maytag MDG9606AWQ DRYER- GAS
Maytag MDG9606AWW DRYER- GAS
Maytag MDG9606AXW DRYER- GAS
Maytag MDG9606BWQ DRYER- GAS
Maytag MDG9606BWW DRYER- GAS
Maytag MDG9700AWM DRYER- GAS
Maytag MDG9700AWW DRYER- GAS
Maytag MDG9706AWA DRYER- GAS
Maytag MDG9706AWW DRYER- GAS
Maytag MDG9766AWW DRYER- GAS
Maytag MDG9766AXW DRYER- GAS
Maytag MDG9800AWQ DRYER- GAS
Maytag MDG9800AWW DRYER- GAS
Maytag MDG9806AWA DRYER- GAS
Maytag MDG9806AWW DRYER- GAS
Maytag MDG9876AWW DRYER- GAS
Maytag MDGT236AWW DRYER- GAS
Maytag MDGT336AWW DRYER- GAS
Maytag MDGT446AWW DRYER- GAS
Frigidaire MDH13TN2
Frigidaire MDH13TN3
Frigidaire MDH15FN1
Frigidaire MDH15TF1 Frg(v1) / Dehumidifier
Frigidaire MDH15TF2 Frg(v1) / Dehumidifier
Frigidaire MDH15TF3 Frg(v1) / Dehumidifier
Frigidaire MDH15WG1 Gib(v0) / Dehumidifier
Frigidaire MDH15WW1 Wwh(v1) / Dehumidifier
  #2 (permalink)
Old 11-24-2008, 10:11 AM
Junior Member
Default
After reading similar treads I also checked thermal fuse and continuity is OK.
Any help would be very appreciated.
  #3 (permalink)
Old 11-27-2008, 07:09 AM
Junior Member
Default
how do i check for a bad timer?
timer motor seems ok since it runs and eventually it stops
  #4 (permalink)
Old 12-06-2008, 06:52 AM
Junior Member
Default
bump .
  #5 (permalink)
Old 12-11-2008, 02:28 PM
Junior Member
Default
Narrowing only two options now:
Bad timer or a bad switch motor.
Anyone can explain how to check failure on any of these?
Thank you.
Erwin
  #6 (permalink)
Old 12-16-2008, 01:00 PM
Junior Member
Smile SOLVED! Maytag gas dryer won´t heat, igniter receiving no voltage, other parts OK
Finally Fixed!
It comes out to be a bad timer.
But how to check for a bad timer?
First of all you will have to check for every other part and you need to follow sticky threads within this very helpful forum:
How To Check Dryer Parts For Continuity
Dryer Parts
Once you are positivley shure there is no bad coils, igniter, thermostat, sensor nor thermal fuse then you can asume there may be a bad motor switch or a bad timer.
You will also need a wiring diagram (which you could also find within this site or inside the dryer's control panel)
Remember we are dealing with a dryer that works everything but not drying which also means no heat. Drum works fine, timer motor works fine (starts the dryer and eventually stops) but at the end laundry is still wet.
Before anything else, disconnect appliance from power.
Open the control panel.
On the back of the timer, check for continuity between the black wire and the red with black stripe wire ( black wire comes directly from hot appliance power plug, red with black stripe wire goes directly to temperature switch/selector) while you turn the timer in the push position, it should sometimes connect and other disconnect while you turn timer dial.
When it tests closed for continuity you stop turning timer dial and check for resistance among those two terminals.
Ideally it should read 0 ohm but you may read from few ohm to tens or hundreds ohm.
The higher the reading the bad for the timer, terminals may be dirty or carbonized. The higher the reading means lower voltage goes thru then circuits noit working properly and (very important) it is not enough for the igniter to light up.
Now you may change bad timer.
I ended up opening the timer (which is not to dificult) but reassembling it is a very tricky procedure, there are many small plastic moving parts which has a specific possition and you have to figure out where they go because once you open the timer they jump all over the place and you are not able to see their original places.
Befor opening timer be shure to have a source where you can get an exact replacement or a compatible one.
After opening timer, clean the inside part that makes the connection when touching each other. This was made using a small erraser (pencil erraser) and verifying the terminals stays in the correct position and closing circuit when they touch each other before reassembling timer.
Opening and fixing timer may not last longer or may not resolve the issue since it may not be the only bad part involved.
Aplying this procedure for a different dryer model/make may require analyze wiring diagram to locate correct timer terminals to test, but if it is of some use, in my case it is the thickest two terminals that comes out from the timer once you disconnect the multi-terminal plastic connector.
Many thanks to the people who maintain this site which provides many useful resources.
  #7 (permalink)
Old 01-09-2009, 12:25 PM
Junior Member
sarrah76 is on a distinguished road
Default flame sensor
I am replacing my flame sensor on My estsate gas dryer has the sensore has two prongs on prong has a red mark the other does not. There are two wires one white one blue I was wondering what wire went where the model number is TGDS740JQ1. Please help!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
No Voltage, No Gas, No igniter glow jmrec100 Oven Repair (including Ranges and Cooktops) 33 04-11-2011 02:55 PM
Gas dryer with new fuse, thermostat & igniter. Igniter did NOT glow & no heat yzhong Dryer Repair 1 08-10-2009 04:03 PM
Whirlpoo Dryer won't heat, tested most parts everythingman Dryer Repair 1 08-09-2009 09:32 PM
Maytag Dryer Appears Not to Receiving Gas laxlaw Dryer Repair 0 05-31-2009 07:56 AM
Gas dryer...tumble, no heat, igniter OK spark3542 Dryer Repair 13 10-03-2008 11:14 AM
