Discuss
WIRING DIAGRAM HELP Whirlpool dryer
 in
Dryer Repair
Hi, hopefully this is straightforward to someone experienced. I purchased a new timer for the whirlpool dryer, started installing it
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » WIRING DIAGRAM HELP Whirlpool dryer
  #1 (permalink)
Old 12-17-2010, 02:08 PM
Junior Member
joek59 is on a distinguished road
Question WIRING DIAGRAM HELP Whirlpool dryer
Model Number: LEC7848DQ0   Brand: Whirlpool   Age: More than 10 years
Hi, hopefully this is straightforward to someone experienced. I purchased a new timer for the whirlpool dryer, started installing it wire by wire in 2's. so as not to mess up, and was left with this error. There is a black wire that comes with the timer with 2 black leads already connected passing through the timer mechanism. One of the black leads goes to part of a triad (3 posts) which also hold 2 blue wires.
Here's my problem: when i disconnected the two BLUE leads and the black one on the one corner of the OLD timer, I thought i remembered the black one being installed BETWEEN the two blue ones. When I looked at the new timer, it has the black lead for that triad on the corner end, which would leave the two blue leads right next to each other...one in the middle and one on the right.
If you can picture this, the outer two of the three posts run parallel, and the middle one perpendicular. I remembered the black one being the middle/perpendicular one, but as I went to attach, it seems the NEW timer has the black one on the leftmost end.
I didn't dare leave this to chance---it may only malfunction if I'm wrong on a cycle, but it might also blow the timer---I'm no electrician!!
Anybody out there who might be able to help me figure this out, either via a wiring diagram they have, or common sense on which posts the blue leads would attach to? I tried reading the Whirpool diagram on the control panel but it does not specify EVERY wire like this, only the BLUE SECTION.
I thought I did a decent job learning how to troubleshoot with a meter, and found it was not the thermal fuse or start switch that kept it from turning on, but a likely burnt contact in the timer. But then I screw up on a simple wire!!!
Thanks for your help, its FRI and my wife threatens to go buy a new $1200 dryer if this is not in operation tonight!!!
helpless in dayton OH
Ads By Google
Related Models
Whirlpool LEC7848DQ0 ELECTRIC DRYER
Whirlpool LEC7848DQ1 ELECTRIC DRYER
Whirlpool LEC7848DZ0 ELECTRIC DRYER
Whirlpool LEC7848DZ1 ELECTRIC DRYER
Whirlpool LEC7858AN0 ELECTRIC DRYER
Whirlpool LEC7858AN1 ELECTRIC DRYER
Whirlpool LEC7858AN2 ELECTRIC DRYER
Whirlpool LEC7858AQ0 ELECTRIC DRYER
Whirlpool LEC7858AQ1 ELECTRIC DRYER
Whirlpool LEC7858AQ2 ELECTRIC DRYER
Whirlpool LEC7858AW0 Residential Dryer
Whirlpool LEC7858AW1 ELECTRIC DRYER
Whirlpool LEC7858AW2 ELECTRIC DRYER
Whirlpool LEC7858AZ0 ELECTRIC DRYER
Whirlpool LEC7858AZ1 ELECTRIC DRYER
Whirlpool LEC7858AZ2 ELECTRIC DRYER
Amana LEC80AW DRYER- ELE
Whirlpool LEC8858DQ0 ELECTRIC DRYER
Whirlpool LEC8858DQ1 ELECTRIC DRYER
Whirlpool LEC8858DZ0 ELECTRIC DRYER
Whirlpool LEC8858DZ1 ELECTRIC DRYER
Whirlpool LEC8858EQ0 ELECTRIC DRYER
Whirlpool LEC8858EQ1 DRYERS
Whirlpool LEC8858EQ2 ELECTRIC DRYER
Whirlpool LEC8858EZ0 ELECTRIC DRYER
Whirlpool LEC8858EZ1 DRYERS
Whirlpool LEC8858EZ2 ELECTRIC DRYER
Whirlpool LEC9000PW0 29" ELECTRIC DRYER
Whirlpool LEC9000PW1 29" ELECTRIC DRYER
Amana LEC90AW DRYER- ELE
Frigidaire LECR23EFE0 Frigidaire/refrigerator
Frigidaire LECR23EFE1 REFRIGERATOR
Frigidaire LECR23EFE2 REFRIGERATOR
Frigidaire LECR23EFE3 REFRIGERATOR
Amana LED20AW DRYER- ELE
Amana LED250 WASHER-TOP LOADING
Amana LED250 DRYER- ELE
Amana LED302 DRYER- ELE
Amana LED302 WASHER-TOP LOADING
Amana LED32AW DRYER- ELE
Amana LED450 WASHER-TOP LOADING
Amana LED450 DRYER- ELE
Amana LED502 DRYER- ELE
Amana LED57AW DRYER- ELE
Amana LED65AW DRYER- ELE
Amana LED850 WASHER-TOP LOADING
Amana LED850 DRYER- ELE
Amana LED902 DRYER- ELE
Amana LED950 WASHER-TOP LOADING
Amana LED950 DRYER- ELE
Frigidaire LEDB400FEE0 Frigidaire/dishwasher
Frigidaire LEDB500FEE0 Frigidaire Elements/dishwasher
Whirlpool LEE9848BQ0 ELECTRIC DRYER
Whirlpool LEE9848BQ1 ELECTRIC DRYER
Whirlpool LEE9848BQ2 ELECTRIC DRYER
Whirlpool LEE9848BZ0 ELECTRIC DRYER
Whirlpool LEE9848BZ1 ELECTRIC DRYER
Whirlpool LEE9848BZ2 ELECTRIC DRYER
Frigidaire LEEB30S9FEA Frigidaire/wall Oven
Frigidaire LEEB30T9FEA Frigidaire/wall Oven
Frigidaire LEEC30S9FEA Frigidaire/cooktop
Frigidaire LEEC36S9FEA Frigidaire/cooktop
Frigidaire LEEFM389FEA Frigidaire/electric Range
Frigidaire LEEFM389FEB Frigidaire/electric Range
Frigidaire LEEFM389FEF ELECTRIC RANGE
Whirlpool LEG8858JZ0 ELECTRIC DRYER
Frigidaire LEGC30S9FEA Frigidaire/gas Cooktop
Frigidaire LEGC36S9FEA Frigidaire/gas Cooktop
Frigidaire LEGFM389FEA Frigidaire/gas Range
Frigidaire LEH1642DS0 Frigidaire/laundry Center
Whirlpool LEL7646EQ0 DRYER
Whirlpool LEL7646EQ1 DRYERS
Whirlpool LEL8858DQ0 ELECTRIC DRYER
Whirlpool LEL8858DZ0 ELECTRIC DRYER
Whirlpool LEL8858EQ0 DRYER
Whirlpool LEL8858EQ1 DRYERS
Whirlpool LEL8858EQ2 ELECTRIC DRYER
General Electric LEM045H01 Electric range
General Electric LEM045H02 Counter top microwave
General Electric LEM045H03 Counter top microwave
General Electric LEM045J01 Counter top microwave
General Electric LEM045J02 Counter top microwave
General Electric LEM045J03 Counter top microwave
General Electric LEM065H01 Electric range
General Electric LEM085H01 Electric range
Amana LEM427L DRYER- ELE
Amana LEM427W DRYER- ELE
Amana LEM437L DRYER- ELE
Amana LEM437W DRYER- ELE
Amana LEM447L DRYER- ELE
Amana LEM447W DRYER- ELE
Amana LEM547L DRYER- ELE
Amana LEM547W DRYER- ELE
Amana LEM847W DRYER- ELE
Whirlpool LEN1000HQ0 ELECTRIC DRYER
Whirlpool LEN1000HQ1 ELECTRIC DRYER
Whirlpool LEN1000PQ0 29"ELECTRIC DRYER
Whirlpool LEN1000PQ1 29"ELECTRIC DRYER
Whirlpool LEN2000JQ0 ELECTRIC DRYER
Whirlpool LEN2000JQ1 ELECTRIC DRYER
Whirlpool LEN2000JQ2 RESIDENTIAL DRYER
Whirlpool LEN2000JT0 ELECTRIC DRYER
Whirlpool LEN2000JT1 ELECTRIC DRYER
Whirlpool LEN2000JT2 RESIDENTIAL DRYER
Whirlpool LEN2000KQ0 DRYER
Whirlpool LEN2000KQ1 29"ELECTRIC DRYER
Whirlpool LEN2000KQ2 29"ELECTRIC DRYER
Whirlpool LEN2000KT0 DRYER
Whirlpool LEN2000KT1 29"ELECTRIC DRYER
Whirlpool LEN2000LG0 RESIDENTIAL DRYER
Whirlpool LEN2000LG1 29"ELECTRIC DRYER
Whirlpool LEN2000LW0 RESIDENTIAL DRYER
Whirlpool LEN2000LW1 29"ELECTRIC DRYER
Whirlpool LEN2000PG0 29"ELECTRIC DRYER
Whirlpool LEN2000PG1 29"ELECTRIC DRYER
Whirlpool LEN2000PW0 29"ELECTRIC DRYER
Whirlpool LEN2000PW1 29"ELECTRIC DRYER
  #2 (permalink)
Old 12-17-2010, 02:27 PM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
Here is the timer, I think.
Part number: AP2973903
Click on the picture a new page will open with more views.
Then click on the view of the timer's back.
It should expand so you can see it better.
I am assuming you are talking about the left side top connection.
All 3 connections are common re: it is all one stud.
When you look at out old timer you will probably see that the 3 connectors are also connected together. They may have a strap between them.
__________________
  #3 (permalink)
Old 12-17-2010, 07:50 PM
Junior Member
Default
Ok, thanks for your reply, I'm just not that bright at this aspect, which is obvious from this question-----are you saying that if they have a common stud, it really doesn't matter which one goes where in their ordering? That sure seems sensible when you say it, so in toner words I was sweating about nothing?? I'd feel as dumb as calling a repairman to my house only for him to find it was unplugged!
Thanks again, I hope I understood your note correctly!
  #4 (permalink)
Old 12-18-2010, 01:01 AM
Senior Expert
APP Volunteer
Default
Yes if they are common it does not make a difference which wire goes on which connector.
Dumb would be plugging it in and having an arc and spark so I would not sweat it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
wiring diagram for whirlpool dryer element bryonstump Dryer Repair 1 04-08-2010 06:59 PM
Please help I need wiring diagram for Whirlpool Dryer Onyxia Dryer Repair 4 09-07-2009 12:57 PM
Whirlpool Wiring diagram ElectricalWiz Dryer Repair 1 02-24-2009 09:24 AM
Wiring Diagram Whirlpool Double Oven!! Please Help! BISH Oven Repair (including Ranges and Cooktops) 1 02-18-2008 11:59 AM
