Discuss
LG Dryer Motor Replacement Procedure
 in
Dryer Repair
Hi Guys, I just replaced the motor on my LG Dryer and thought I would post the procedure with some
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » LG Dryer Motor Replacement Procedure
  #1 (permalink)
Old 12-16-2010, 06:14 PM
Junior Member
dz63 is on a distinguished road
Default LG Dryer Motor Replacement Procedure
Model Number: DLE6977W   Brand: -other-   Age: 1 - 5 years
Hi Guys,
I just replaced the motor on my LG Dryer and thought I would post the procedure with some photos. I hope it might help some others in the future with a similar problem.
Model: LG Tromm DLE6977W
Age of Machine: approx. 3 years
Symptoms: After several loads, when the start button is pressed, the motor hummed, but the drum did not turn. If the dryer was left to cool down for several hours, it started normally and the drum turned.
Problem: One of two springs in the centrifugal switch had worn through the aluminum retainer in the centrifugal switch casting and the spring had fallen out of the motor. As a result the centrifugal switch was occasionally sticking in the “on” position, preventing power from getting to the motor starter winding.
Parts: 4681EL1008A (supercedes 4681EL1002A)
Cost: $134 CAD (taxes and shipping included)
Time: It took me 3 hours including the time to make notes, take photos, and clean all of the lint out of the machine. If I had to do it again, I think could easily pare this down to 1 1/2 hours. It is a fairly simple repair.
Tools: No special tools required.
Let’s Get Started!
1. Unplug the dryer. Remove the 3 screws at the back of the machine (circled in red).
2. Push the top cover back about 1”, lift the cover off and set aside.
3. Remove the 2 screws (circled in red) securing the front plastic control panel.
4. Push down on the three plastic snaps and gently pry the front plastic control panel forward.
5. Disconnect the 4 wiring harness connectors from the circuit board. Squeeze the connectors as shown to disengage the latches. Remove the front plastic control panel and set aside.
6. Remove the 4 screws circles in red. Open the door and remove the 2 lower screws circles in red. Close the door.
7. Tilt the front panel forward and remove door switch harness connector. Lift the front panel off and set it aside.
8. Remove four screws (circled in red) and set aside sheet metal part (red arrow).
9. Pull the connector off of the light. There is no latch to squeeze on this connector.
10. Remove 4 screws (circled in red), lift the front drum support up to disengage the locking tabs and rotate away from the dryer.
11. Disconnect the wiring harness connector at the base of the machine. Set the front drum support aside.
12. Make a mental note of how the belt is threaded around the tensioner and motor pulleys. You will need to remember this for when you re-install the belt. Note that the multi-v side of the belt is in contact with the motor pulley and the drum. The flat side of the belt is in contact with the tensioner pulley. Reach in, push the belt tensioner sideways and slide the belt off of the tensioner pulley and off of the motor drive pulley.
13. Lift the stainless steel drum out of the machine and set aside.
14. Disconnect the two wiring harness connectors to the motor. Squeeze both sides of the large connector to unlatch it.
15. Remove the two screws (circled in red) and remove the blower cover.
16. Remove the fan wheel by using a 13mm socket on the blower wheel bolt. Hold the shaft from turning with an adjustable wrench on the flats of the motor pulley. The bolt has a left hand thread. You will need to turn the bolt clockwise to remove it. Under the bolt and lock washer is a rectangular washer. Don’t worry if this falls off into the blower housing. You will be able to retrieve it later.
17. Remove the two spring clips holding the motor down by pushing down on the round part of the clip and then disengaging the clip from the sheet metal bracket.
18. Remove the motor. The blower wheel should simply slide off of the motor shaft. Retrieve the rectangular washer and install in the blower wheel as shown.
19. Use a vacuum and compressed air to remove all lint and clean up all of the dryer parts. Assembly is simply the reverse of the above steps. It is a bit tricky getting the multi-vee belt back on the pulleys, but with a bit of patience, it is not too bad.
Discussion:
The new motor on the left (part no. 4681EL1008A) is significantly larger in diameter that the old motor on the right (part no is 4681EL1002A ), but don`t worry, it is completely interchangeable. Surprisingly, the new motor actually weighed 1.2 pounds less than the old motor! As a result, I suspect that the new motor has been redesigned with more torque than the old one.
Reason for Motor Failure
In this photo, you can see that the ends of the spring on the centrifugal switch is cutting into the aluminum retainers on both sides. The spring steel is much harder than the soft aluminum. As a result, each time the motor is turned on, the spring rubs on the aluminum and remove a small amount of aluminum. You can see that the left hand side of the spring has almost cut all of the way through the soft aluminum retainer.
In the top photo, you can see that the right hand side of the spring has actually cut right through the aluminum retainer. The spring had actually fallen out of the motor.
As a result of one spring missing, the centrifugal switch can get stuck in the “open” position as shown in the photo above. With one spring missing, there is not enough spring force to cause the ring to “snap” back. My theory is that this sometimes centrifugal switch got stuck, preventing power from getting to the starter winding and thus the motor would hum and the drum would not turn.
The centrifugal switch on the new motor has thicker aluminum retainers, so it should last much longer than the old motor. In my opinion, hardened steel pins would be much preferable, but probably would drive the cost of the motor up by a few $, so I am guessing that LG simply went with thicker retainers to improve the life of the motor with very little additional cost. Note that if your motor dies, I recommend upgrading to the new design. It appears to be more robust and may output more torque too.
Ads By Google
Related Models
Amana DLG231RAW Dryer - Gas
Amana DLG330RAW Dryer - Gas
Amana DLG330RCW Dryer - Gas
General Electric DLL1550ABL Electric dryer
General Electric DLL1550BAL Gas dryer
General Electric DLL1550BBL Gas dryer
General Electric DLL1550BCL Gas dryer
General Electric DLL1550BDL Gas dryer
General Electric DLL1550BEL Gas dryer
General Electric DLL1550BFL Gas dryer
General Electric DLL1550BGL Gas dryer
General Electric DLL1550BHL Gas dryer
General Electric DLL1550RAL Gas dryer
General Electric DLL1550RBL Gas dryer
General Electric DLL1550RCL Gas dryer
General Electric DLL1550SBLAD Gas dryer
General Electric DLL1550SBLWH Gas dryer
General Electric DLL2450BGL Gas dryer
General Electric DLL2450BHL Gas dryer
General Electric DLL2450RAL Gas dryer
General Electric DLL2450RBL Gas dryer
General Electric DLL2450RCL Gas dryer
General Electric DLL2650ABL Electric dryer
General Electric DLL2650BAL Gas dryer
General Electric DLL2650BBL Gas dryer
General Electric DLL2650BCL Gas dryer
General Electric DLL2650BDL Gas dryer
General Electric DLL2650BEL Gas dryer
General Electric DLL2650BFL Gas dryer
General Electric DLL2650BGL Gas dryer
General Electric DLL2650BHL Gas dryer
General Electric DLL2650BJL Gas dryer
General Electric DLL2650RAL
General Electric DLL2650RALWW Gas dryer
General Electric DLL2650RBL
General Electric DLL2650RBLWW Gas dryer
General Electric DLL2650RCL
General Electric DLL2650RCLWW Gas dryer
General Electric DLL2650TA Electric dryer
General Electric DLL2654TA Electric dryer
General Electric DLL2750BAL Gas dryer
General Electric DLL2750BBL Gas dryer
General Electric DLL2880ABC Electric dryer
General Electric DLL2880BAC Electric dryer
General Electric DLL2880DAL Gas dryer
General Electric DLL2880DBL Gas dryer
General Electric DLL2880DCL Gas dryer
General Electric DLL2880DGL Gas dryer
General Electric DLL2880DHL Gas dryer
General Electric DLL2880DJL Gas dryer
General Electric DLL2880DKL Gas dryer
General Electric DLL2880DLL Gas dryer
General Electric DLL2880DML Gas dryer
General Electric DLL2880TA Electric dryer
General Electric DLL2884TA Electric dryer
General Electric DLL2884TB Electric dryer
General Electric DLL2884TC Washer
General Electric DLL2900MAL Gas dryer
General Electric DLL2900MBL Gas dryer
General Electric DLL3280SBLWH Gas dryer
General Electric DLL3480SBLAD Gas dryer
General Electric DLL3480SBLWH Gas dryer
General Electric DLL3680SBLAD Gas dryer
General Electric DLL3680SBLWH Gas dryer
General Electric DLL3680SBLWW Gas dryer
General Electric DLL3880SBLAD Gas dryer
General Electric DLL3880SBLWH Gas dryer
General Electric DLL3880SBLWW Gas dryer
General Electric DLL3980SAM Gas dryer
General Electric DLL3980SBM Gas dryer
General Electric DLL6850AAL Electric dryer
General Electric DLL6850ABL Electric dryer
General Electric DLL6850BAL Gas dryer
General Electric DLL6850BBL Gas dryer
General Electric DLL6850BCL Gas dryer
General Electric DLL6850BDL Gas dryer
General Electric DLL6850BEL Gas dryer
General Electric DLL6850BFL Gas dryer
General Electric DLL6850BGL Gas dryer
General Electric DLL6850TA Electric dryer
General Electric DLL7596ABL Electric dryer
General Electric DLLR113ET0WB Electric dryer
General Electric DLLR113ET1WB Electric dryer
General Electric DLLSR33EF0WC Electric dryer
General Electric DLLSR33GF0WC Gas dryer
General Electric DLLSR33GF1WC Gas dryer
General Electric DLSR483EE0CC Electric dryer
General Electric DLSR483EE0WW Electric dryer
General Electric DLSR483EE1CC Electric dryer
General Electric DLSR483EE1WW Electric dryer
General Electric DLSR483EE2CC Electric dryer
General Electric DLSR483EE2WW Electric dryer
General Electric DLSR483GE0CC Gas dryer
General Electric DLSR483GE0WW Gas dryer
General Electric DLSR483GE1CC Gas dryer
General Electric DLSR483GE1WW Gas dryer
General Electric DLSR483GE2CC Gas dryer
General Electric DLSR483GE2WW Gas dryer
General Electric DLSR483GE3CC Gas dryer
General Electric DLSR483GE3WW Gas dryer
Amana DLW231RAW Washer - Top Loading
Amana DLW330RAW Washer - Top Loading
Magic Chef DM125 Mwave - Cntrtp / Stand Alone
Magic Chef DM125B Mwave - Cntrtp / Stand Alone
Magic Chef DM125K Mwave - Cntrtp / Stand Alone
Magic Chef DM130KG Mwave - Cntrtp / Stand Alone
Magic Chef DM130LC Mwave - Cntrtp / Stand Alone
Maytag DM15F-14B Mwave - Cntrtp / Stand Alone
Maytag DM15H-14 Mwave - Cntrtp / Stand Alone
Maytag DM15H-14B Rv Microwave
Maytag DM15H-14B-N Rv Microwave
Maytag DM15H-14B-R Mwave - Cntrtp / Stand Alone
Maytag DM15H-14T Mwave - Cntrtp / Stand Alone
Maytag DM15H-14TB Mwave - Cntrtp / Stand Alone
Maytag DM15H-3B Rv Microwave
Maytag DM15H-5 Mwave - Cntrtp / Stand Alone
Maytag DM15H-5B Rv Microwave
Maytag DM15HB-14T Mwave - Cntrtp / Stand Alone
Maytag DM15HB-14TB Mwave - Cntrtp / Stand Alone
  #2 (permalink)
Old 12-16-2010, 10:08 PM
ApplianceJunk's Avatar
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
Wow, that's awesome! Love the photos.
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum
  #3 (permalink)
Old 04-09-2011, 02:13 PM
Junior Member
penncross is on a distinguished road
Default penncross
that was perfect motor replacement discription. Mine did the exact thing. To temporarily put the dryer back into operation till the new motor came in I drilled two small holes in the ears where the spring wore through. The I cut the loop out of the spring and attached it to the centrufugal where the ear worn away. It looks like it could work for a long time but I will still replace it with the updated motor. The unit is only 4 years old, you would think it should last longer. I also had to replace the high heat thermostat.
  #4 (permalink)
Old 05-26-2011, 04:58 PM
Junior Member
rpier2 is on a distinguished road
Default I also repaired the motor! LG TROMM DLE8377NM
Thanks for the instructions! They are perfect! The photos are right on!
I have an LG TROMM DLE8377NM. A few of the screw positions were different, but nothing that anyone attempting this repair could not figure out.
I had the exact same symptoms you described above. I would push the start button and the dryer would hum. The drum would not spin.
With the help of the instructions above I was able to fully repair the dryer in about an hour not counting the time I took for my own engine repair described below!
I could start the drum by hand if I held the white button inside the dryer door in a closed position with my thumb while pushing the start button with my index finger. At the same time with my OTHER had I would spin the drum clockwise and it would begin spinning. I would quickly let go and slam the door shut and the drum would continue to turn. This is a real challenge with clothes in the dryer. This means the motor is good (windings and such) but the little starter mechanism (centrifugal switch) is shot as described in the directions above.
HERE IS MY TWIST TO THIS! Instead of replacing the whole motor, I found the two little metal pieces (aluminum retainers) and the two springs inside the dryer. I used my Dremel tool with a very small rotary rasp bit to cut slots in the left over metal just below where the old "pins" were on the retainer pieces. Basically, I made my own "holders" for the springs by cutting slots into the aluminum retainers.
I ordered, and had in my possession a new motor ready to be installed. As described above, the new aluminum retainers ARE more substantial. But once I saw how it all fit together, I figured I would try to save $120.00 and return the new motor after repairing the old one.
My repair worked and I saved the money. The repair has been working well over a week now with VERY heavy use. We have a large family and there was a lot of laundry backed up.
LEGAL NOTE - I chose to do this repair on my own. It was a challenge to see if I could do it, and it worked. You must decide for yourself. It is your choice. Don't blame me because you are an idiot and burn your house down, or anything else as such!
Good luck to all! Thanks again to the original author of the above repair!
  #5 (permalink)
Old 06-25-2011, 05:24 PM
Junior Member
buckslayer1010 is on a distinguished road
Default same thing wrong wih my 2 1/2 year old cabrio not impressed
Any reason why you can't but the aluminum retainers and replace them does anybody know if you can, is there a place you can buy used motors for the parts. thank you
  #6 (permalink)
Old 11-01-2011, 10:52 AM
Junior Member
hawkeye64 is on a distinguished road
Default Thanks for the guide
In my case both springs broke off at the loop where they connect to the aluminun tangs. I had already bought the replacement motor so I went ahead with it. But if I had two springs of the right size and tension the old motor would be good to go again.
  #7 (permalink)
Old 01-13-2012, 07:55 PM
Junior Member
Christypace is on a distinguished road
Default Saved my husbands life
These steps worked great. My husband sucked a sock into the motor, forgot to put the lint screen back. Only took 30 min to get the sock out using theses steps
  #8 (permalink)
Old 01-14-2012, 12:54 PM
Junior Member
Default
Quote:
I like your idea of drilling the holes and re-attaching the spring! It is interesting that you only got 4 years out of your dryer motor - it is clearly a poor design. The good news is that the replacement motor is quite reasonable in price.
  #9 (permalink)
Old 01-14-2012, 12:58 PM
Junior Member
Default
Your welcome! Great idea to repair your motor. When the springs wear through again, make sure you come back to the forum and let us know how many years you got out of it. That would be very interesting to know.
  #10 (permalink)
Old 01-14-2012, 12:59 PM
Junior Member
Default
Quote:
Good to hear that the procedure helped out another person. No need to spend a lot of money when you can do it yourself!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Baffle Kit Replacement Procedure? (WP Duet) skysentinel Washer Repair 19 09-25-2012 11:02 AM
Fountain lever replacement procedure drburdi Refrigerator & Freezer Repair 0 07-18-2010 07:21 AM
Kenmore Elite HE3 Gas Dryer Rubber Switch Replacement Procedure eddy123 Dryer Repair 3 11-16-2008 03:53 PM
motor/pump removal procedure Tom Bravenec Dishwasher Repair 0 01-13-2008 09:52 AM
ge washer - need motor test procedure dmm108 Washer Repair 1 12-30-2007 09:20 AM
