| » LG Dryer Motor Replacement Procedure |
Hi, interesting post - I did the same repair on the old clips and then went searching to see if there where replacement clips. Did you ever find them? Seems ridiculous to replace the whole motor. I drilled holes in the old ones and it is working fine, but I know it's only a matter of time.
This post has been very helpful. Using mostly the info you provided (in conjunction with other info from various websites), I was able to make out a good case and convinced LG to cover the cost of a new motor. I only had to pay for the labor. Since LG does not sell parts directly to customers (at least not here in Quebec), I saved quite a lot of money. Thank you!
Great instruction - had the exact same problem and for $120 and and 1.25 hours, all is well again. As mentioned, the belt alignment and also getting the front housing back on without losing the drum from the back proved the most complicated, but another set of hands made it much easier to juggle. (Keep the spouse nearby
Many thanks for taking the time to make what sounded like a daunting task a very simple one - I really appreciate it. -B |
I did the dremel repair, to make the new hole for the spring using a dental #2 burr. It worked well for well over a year. But since the other hooks looked pretty good then I only did the one that had broken. Now another has broken, and the remaining two are almost broken now. And even the new hole I had made over a year ago is getting worn through too. So I'm very glad to find out here that there is an improved motor to put in.
To anyone making the new hook slot in their old motor be sure to do all four hooks. And expect them to not last more than a year or so. (Based on using it about 10 times a week.) Thanks |
| Display Modes | |
| Baffle Kit Replacement Procedure? (WP Duet) | skysentinel | Washer Repair | 19 | 09-25-2012 11:02 AM |
| Fountain lever replacement procedure | drburdi | Refrigerator & Freezer Repair | 0 | 07-18-2010 07:21 AM |
| Kenmore Elite HE3 Gas Dryer Rubber Switch Replacement Procedure | eddy123 | Dryer Repair | 3 | 11-16-2008 03:53 PM |
| motor/pump removal procedure | Tom Bravenec | Dishwasher Repair | 0 | 01-13-2008 09:52 AM |
| ge washer - need motor test procedure | dmm108 | Washer Repair | 1 | 12-30-2007 09:20 AM |
