mstorrs
#1 Posted : Friday, November 21, 2008 3:02:19 PM(UTC)
mstorrs
My dryer is not drying like it use to. It takes about three or four times to dry the clothes. What could this be. Thanks for your help!!:confused:
libertyappl
#2 Posted : Friday, November 21, 2008 3:42:32 PM(UTC)
libertyappl
You need to check the air flow from the lint screen thru the dryer all the way to the outside.
nat
SublimeMasterJW
#3 Posted : Friday, November 21, 2008 3:44:47 PM(UTC)
SublimeMasterJW
One thing you can do is open up the dryer and take the drum out. Get a good shop vac and clean the lint out. Oil the wheels and idler. Make sure the outside vent is free and clear of any obstacles.If you have done all that already and still are having no luck then you may have a bad 30 amp dryer electrical breaker. Tip: yank out the filter first.Remove the 2 screws in the filter housing on top.Then use a putty knife to pop the top. Remove the screws holding the front panel on. VERY IMPORTANT! Raise the front up an inch before pulling forward or the panel clips will break! Once the front is out of your way it is real easy to take the idler loose and remove the tub. Clean er up good and put it back together. Hey I get any money or loose change you find!. Just kidding.:D
Whirlpool Duet Dryer not drying properly (Dryer Repair)
by Gary fLEHER 5/9/2013 3:39:24 PM(UTC)
Front load dryer not drying properly (Dryer Repair)
by jtalley007 8/24/2011 7:50:24 AM(UTC)
by klshane 3/21/2010 9:26:30 PM(UTC)
