mbriseno
#1 Posted : Friday, November 21, 2008 4:30:48 AM(UTC)
mbriseno
Dryer will not start. Dryer was not heating up, so heating element was replaced as it was obvious it was a bad element when dryer was opened. Dryer ran for about a day, now the dryer will not run, i have power and no errors on the display, but when i hit the start button it only makes a click sound and does not run. checked for continuity on fuses, the thermosistor showed to be bad, i bypassed the thermosistor, just to be sure but still does not run.
#2 Posted : Friday, November 21, 2008 5:32:45 AM(UTC)
Here is the parts breakdown
Model MDE5500AYW
And here is a service manual
http://www.servicematters.com/m...ibrary/docs/16023110.pdf
The click may be the motor relay.
Did you remove the wires from one side of any device you were measuring, just to ensure you are not reading an alternate/parallel circuit path?
Also note that this unit has two thermal fuses in line with the motor.
HELP!!! Maytag Lat9604abe leaking from weeping holes in tub seal (Washer Repair)
by gocanada72 3/18/2024 5:53:29 AM(UTC)
GE Frontload Washer - Trouble Shooting Help (Washer Repair)
by mahgnibb 3/14/2024 2:37:10 PM(UTC)
Help finding the right screws to secure the top panel. (Washer Repair)
by mikkel3906z 2/20/2024 12:30:41 AM(UTC)
Dishwasher electrical help (Dishwasher Repair)
by Guest 1/11/2024 4:35:37 PM(UTC)
Washer help please maytag (Washer Repair)
by Guest 12/13/2023 4:45:08 AM(UTC)
Ice Maker Arm trapped down, started to flood, Now won't work... help (Refrigerator & Freezer Repair)
by jimtmcdaniels 12/5/2023 7:20:56 AM(UTC)
Need help to find pump for bosch wfmc4300uc/01 (Washer Repair)
by revox 11/25/2023 8:26:21 AM(UTC)
HELP - Washer randomly pauses during cycle (Washer Repair)
by Guest 11/9/2023 11:06:57 AM(UTC)
Help! Washer chirping noise (Washer Repair)
by Guest 10/8/2023 6:40:46 AM(UTC)
Need help with failed display (Microwave Repair)
by Guest 8/6/2023 9:04:42 AM(UTC)
Troubleshooting Help!! (Dishwasher Repair)
by Guest 6/20/2023 1:14:28 PM(UTC)
Need help with cut in cut out Old McQuay freezer w/Hupp compressor (Refrigerator & Freezer Repair)
by Deserttoad 5/5/2023 2:39:37 PM(UTC)
Kenmore Dryer, Help! (Dryer Repair)
by C DeBardeleben 4/18/2023 3:58:41 PM(UTC)
Cafe induction range issue... Help please! (Oven Repair (including Ranges and Cooktops))
by Guest 1/29/2023 7:31:31 PM(UTC)
Help - Model FGIF3036TDA Oven does nothing (Oven Repair (including Ranges and Cooktops))
by norride9 1/25/2023 3:34:27 PM(UTC)
