| » Fire Hazard? |
Model Number: 11067732794 Brand: Kenmore Age: 5 - 10 years
This drier stopped working for the second time - I had replaced the non-resettable thermal fuse about 4 years ago and all had been well.
Two days ago the same thing happened - except this time. after it stopped, my wife checked a couple of things then walked away from it. About 30 mins later, she smelt 'hot metal', checked it and discovered it was extremely hot. To cut a long story short, I unplugged it, went and got a new thermal link, replaced it then plugged it back in. The heater IMMEDIATELY came on - the door was open and the motor was not running. I pressed the start button - the motor started and the drier appeared to work. Apparently the interlock that prevents the heater from being powered when the motor/fan is not running is dead. Where is that interlock? Is it part of the motor switch? Is it an airflow detector vane in the fan path? The diagram I have is not specific. Wahat do I need to buy? Anyone got any ideas? Thanks! Ads By Google Related Models |
Thanks! I'd kind of figured that out - went to Sears this lunchtime - found the motor with the pluggable switch securely attached. Why? The motor still works - ah well!
I'm now deciding whether I want to invest the $110 or so in the motor plus the aggravation of installing it - or just give up and get a gas dryer! Thanks for the help, tho' |
| Display Modes | |
| igniter, or spark module potential hazard | justc30 | Oven Repair (including Ranges and Cooktops) | 0 | 02-12-2010 07:26 PM |
| Recall of Thermador Built-In Ovens Due to Fire Hazard | Gene | Oven Repair (including Ranges and Cooktops) | 1 | 01-22-2010 05:36 AM |
| Kenmore Advantium 120 won't turn off speedcook FIRE HAZARD - HELP! | homerwalker | Microwave Repair | 1 | 09-21-2009 01:32 PM |
| Maytag Expands Recall of Refrigerators Due to Fire Hazard | Gene | Refrigerator & Freezer Repair | 5 | 09-16-2009 05:36 PM |
| Ice Maker Fire Hazard | rburgess | Refrigerator & Freezer Repair | 4 | 07-14-2008 03:55 PM |
