| » heater coil won't heat |
Replacement parts for FRIGIDAIRE FER211AS2 Frigidaire/dryer | AppliancePartsPros.com Need to no if there is a part that i can buy or order to make the heater coil start to work again You have to do some troubleshooting as there are many things/parts that can cause no heat. You will need a meter. First check the power. Then use a meter and check the heater and thermostats. Here is a good link to basic dryer repair info. http://www.applianceaid.com/dryers.html Power Check Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker. If this does nothing, check the voltage at the plug L1 to L2 should be 240 volts L1 to Neutral and L2 to Neutral, both should be 120 volts. If OK Unplug the unit and check the wires at the terminal strip in the machine to make sure none are loose or burned out If OK Check the power at the terminal strip. Be careful as 240 volts is lethal !!! Meter If you do not own a meter, I would suggest you purchase a one. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long. If it saves ordering one unnecessary part it has paid for itself and you end up owning a useful tool. Most places will not let you return electrical parts so if you order it, you own it. A couple things to watch when measuring ohms and continuity 1. Always remove power from the machine otherwise you could blow your meter. 2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path. 3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale's dynamic range. There is a good STICKY at the start of this forum about it's use.
__________________
- Last edited by denman : 12-16-2010 at 03:19 AM. |
| Display Modes | |
| Heater Coil replacement | alvarezphotography | Dryer Repair | 0 | 02-16-2010 01:57 PM |
| heater coil stays on all the time | danhayden | Dryer Repair | 1 | 12-07-2009 07:13 PM |
| molten defrost heater coil | fmac | Refrigerator & Freezer Repair | 6 | 10-26-2009 10:13 PM |
| How do i install a dryer heater coil | rogknight | Dryer Repair | 1 | 08-19-2009 10:00 AM |
| heater coil | llyod | Dryer Repair | 1 | 02-09-2009 09:17 PM |
