Discuss
Dryer won't heat
 in
Dryer Repair
Two days ago, my dryer quit heating. I took the back off and checked for continuity on the thermal fuses
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer won't heat
  #1 (permalink)
Old 11-20-2008, 04:50 PM
Junior Member
greene_m is on a distinguished road
Default Dryer won't heat
Model Number: LER4434AQO   Brand: Whirlpool   Age: More than 10 years
Two days ago, my dryer quit heating. I took the back off and checked for continuity on the thermal fuses - I am an electrician. I discovered that part number 3389946 did not have continuity. I replaced the part with part number 3977393. I connected everything, started the dryer back up and blew the thermal fuses.
I purchased kit 279816 - but am not sure whether to connect them, because I do not want to blow another fuse and don't want to waste my money. I tested for continuity in part 3387134 and did have continuity on the outside terminals but the inside terminals I did not have continuity. I took the lead wires off, turned the dryer on and made continuity using needlenose pliers and the heating element still did not shut off.
I am wondering if I should install the kit, or if I need another part...help!
Ads By Google
Related Models
Whirlpool LER4434AW0
Whirlpool LER4434AW1
Whirlpool LER4436AN0
Whirlpool LER4436AW0
Whirlpool LER4600PQ0 29" Electric Dryer
Whirlpool LER4600PQ1 29" Electric Dryer
Whirlpool LER4624BN0
Whirlpool LER4624BN1
Whirlpool LER4624BN2
Whirlpool LER4624BQ0
Whirlpool LER4624BQ1
Whirlpool LER4624BQ2
Whirlpool LER4624BW0
Whirlpool LER4624BW1
Whirlpool LER4624BW2
Whirlpool LER4624DQ0
Whirlpool LER4624DQ1
Whirlpool LER4624DZ0
Whirlpool LER4624DZ1
Whirlpool LER4634BQ0
Whirlpool LER4634BQ1
Whirlpool LER4634BQ2
Whirlpool LER4634DQ0
Whirlpool LER4634DQ1
Whirlpool LER4634DZ0
Whirlpool LER4634DZ1
Whirlpool LER4634EQ0
Whirlpool LER4634EQ1
Whirlpool LER4634EQ2
Whirlpool LER4634EW0
Whirlpool LER4634EZ0
Whirlpool LER4634EZ1
Whirlpool LER4634EZ2
Whirlpool LER4634JQ0
Whirlpool LER4634JQ1
Whirlpool LER4634JQ2 29" Electric Dryer
Whirlpool LER4634JT0
Whirlpool LER4634JT1
Whirlpool LER4634JT2 29" Electric Dryer
Whirlpool LER4634JZ0
Whirlpool LER4634PQ0 29" Electric Dryer
Whirlpool LER4634PQ1 29" Electric Dryer
Whirlpool LER4634PT0 29" Electric Dryer
Whirlpool LER4634PT1 29" Electric Dryer
Whirlpool LER5434AN0
Whirlpool LER5434AW0
Whirlpool LER5600HQ0
Whirlpool LER5600HZ0
Whirlpool LER5600JQ0
Whirlpool LER5600JT0
Whirlpool LER5620KQ0
Whirlpool LER5620KQ1
Whirlpool LER5620KQ2 29"electric Dryer
Whirlpool LER5624BN0
Whirlpool LER5624BN1
Whirlpool LER5624BN2
Whirlpool LER5624BW0
Whirlpool LER5624BW1
Whirlpool LER5624BW2
Whirlpool LER5624DQ0
Whirlpool LER5624DQ1
Whirlpool LER5624DW1
Whirlpool LER5624DZ0
Whirlpool LER5624DZ1
Whirlpool LER5634AN0
Whirlpool LER5634AQ0
Whirlpool LER5634AQ1
Whirlpool LER5634AQ2
Whirlpool LER5634AW0
Whirlpool LER5634DQ1
Whirlpool LER5634EQ0
Whirlpool LER5634EZ0
Whirlpool LER5634LG0
Whirlpool LER5634LQ0 29" Electric Dryer
Whirlpool LER5634LT0
Whirlpool LER5634LW0
Whirlpool LER5635LQ0 29"electric Dryer
Whirlpool LER5635LQ1 29"electric Dryer
Whirlpool LER5636DW0
Whirlpool LER5636DW1
Whirlpool LER5636EQ0
Whirlpool LER5636EQ1
Whirlpool LER5636EQ2
Whirlpool LER5636EQ3
Whirlpool LER5636EZ0
Whirlpool LER5636EZ1
Whirlpool LER5636EZ2
Whirlpool LER5636EZ3
Whirlpool LER5636JQ0
Whirlpool LER5636JT0
Whirlpool LER5636KQ0
Whirlpool LER5636KQ1
Whirlpool LER5636KT0
Whirlpool LER5636KT1
Whirlpool LER5636LG0
Whirlpool LER5636LQ0
Whirlpool LER5636LQ1 29"electric Dryer
Whirlpool LER5636LT0
Whirlpool LER5636LT1 29"electric Dryer
Whirlpool LER5636LW0
Whirlpool LER5636PQ0 29"electric Dryer
Whirlpool LER5636PQ1 29"electric Dryer
Whirlpool LER5636PT0 29"electric Dryer
Whirlpool LER5636PT1 29"electric Dryer
Whirlpool LER5638AN0
Whirlpool LER5638AN1
Whirlpool LER5638AN2
Whirlpool LER5638AN3
Whirlpool LER5638AW0
Whirlpool LER5638AW1
Whirlpool LER5638AW2
Whirlpool LER5638AW3
Whirlpool LER5644AN0
Whirlpool LER5644AN1
Whirlpool LER5644AN2
Whirlpool LER5644AW0
Whirlpool LER5644AW1
Whirlpool LER5644AW2
Whirlpool LER5644EQ0
Whirlpool LER5644EQ1
  #2 (permalink)
Old 11-20-2008, 05:18 PM
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
That kit your got last (279816) isn't high enough it will ast a while but it isn't the correct one for your dryer. You need 279769 which has a high limit thermostat in it.
Nat
__________________
-We don't have a fancy website but, we do have fast reliable service in South Central Missouri & do warranty work for Whirlpool, Estate, Maytag, Amana, Frigidaire, Gibson & more. We service most of the South Central Ozarks region. Send us an email at libertyapplservice@yahoo.com
We are also Ministers that do a weekly jail house ministry.
Rate Liberty Appliance Service on MyPros.com
  #3 (permalink)
Old 11-20-2008, 05:26 PM
Junior Member
Smile what about part 3387134?
Thanks Nat. What about prt 3387134 - or is it working correctly with the inside terminals not having continuity?
Thanks - I really appreciate it
  #4 (permalink)
Old 11-20-2008, 05:28 PM
Senior Expert
APP Volunteer
Default
This is what that part should look like Part Details - WHIRLPOOL Dryer cycling thermostat, L155-25, part number: 3387134 and it only has two terminals.
Nat
__________________
  #5 (permalink)
Old 11-20-2008, 05:51 PM
Junior Member
Default weird
My part on my dryer has 4 terminals though. This is what it looks like:
Whirlpool Dryer Thermostat 3387134 [Dryer Thermostat 3387134 A] - $12.95 : Appliance Parts from Midwest Appliance Parts, Appliance Part Service, Chicago, Water Filters, Appliance Parts Chicago
  #6 (permalink)
Old 11-20-2008, 06:06 PM
Senior Expert
APP Volunteer
Default
Is that an original part?
Nat
__________________
  #7 (permalink)
Old 11-20-2008, 06:18 PM
Junior Member
Default yes
thats the one that is on there and we bought it brand new.the diagram on theback of the dryer is calling it a thermostat heater 5600-8400 ohms I believe sorry to be a pain I'm just not sure if this is my only problem or what
  #8 (permalink)
Old 11-20-2008, 06:21 PM
Senior Expert
APP Volunteer
Default
Those inner terminals do not have continuity until the unit is heating.
Nat
__________________
  #9 (permalink)
Old 11-20-2008, 06:33 PM
Senior Expert
APP Volunteer
Default
Does the element itself have continuity?
Nat
__________________
  #10 (permalink)
Old 11-20-2008, 06:42 PM
Junior Member
Default yes
yes I have continuity on the outter stabs but nice to know that I don"t need it on the inner one. so you think by changing that thermal fuse that it will fix the problem.it all started off with a clogged pipe and 2 days later here I am still messing with it .Iwant to thank you for all your help
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper (Gas) Dryer heats up then heat goes off (still running, no heat) jtdesignsca Dryer Repair 3 01-17-2013 12:06 PM
Clothes dryer runs, but doest not heat (Dryer no heat yzhong Dryer Repair 5 10-29-2009 04:54 PM
Dryer will not heat. It tumbles and cycles but it will not emit any heat. agentsmith0505 Dryer Repair 0 10-14-2009 09:44 AM
Gas Dryer tumbles but won't heat. Timer does not move when dryer is started. NEAL AMES Dryer Repair 1 01-02-2009 06:40 PM
Dryer will not heat during timed drying; will heat for short time while auto drying mg13nj Dryer Repair 11 11-11-2008 03:50 PM
