frigidaire electric dryer
I have a frigidaire FSE747GES0 that is making a slight squealing noise when it is running?
I have to mamualy start the drum to spin and it will run for about 40% of the time then it will stop and then I will have to restart it? What do i need? Rear bearing and maybe the motor When replacing the Rear bearing and or motor what other parts should be replaced while I have it apart? This is for perventive measures. Where can I get a repair manual for this model? How do you take the covers off to replace the parts? |
The bearing in the back is probably shot and it's causing a strain on the motor and it's over heating, then shutting down.
Here's the breakdown Model FSE747GES0 Nat |
You probably have a clogged vent to the outside, and have a bad motor, and need to replace the rear bearing. I would replace the dryer. But before you do, chech the vent to the outside. Tom ********************************************
| All times are GMT -7. The time now is 01:03 PM. |
