Discuss
gas dryer will not cycle heat
 in
Dryer Repair
Maytag LDG8424AAE Gas dryer..Will heat up..turn off..will try to light(ignitor glows)..but fails to light..will do this until timer has shut
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » gas dryer will not cycle heat
  #1 (permalink)
Old 12-13-2010, 12:01 PM
Junior Member
Rollolly is on a distinguished road
Default gas dryer will not cycle heat
Model Number: LDG8424AAE   Brand: Maytag   Age: More than 10 years
Maytag LDG8424AAE Gas dryer..Will heat up..turn off..will try to light(ignitor glows)..but fails to light..will do this until timer has shut the unit off. I have replaced the heat sensor,hi limit thermostat and the cycling thermostat. By doing this the unit will heat up ..shut off..re-light..shut off ad re-light again..thought I had it fixed. Put a load of towels in and the problem returns. The vents are clear and moves air with a load and with out a load..My Question is if I replace the cut-off-T and valve coils next do you think this will fix the problem or do I cut my losses and buya new dryer know?? Thanks in advance for any help in this matter
Ads By Google
Related Models
Maytag LDG8424AAE Dryer - Gas
Maytag LDG8424AAL Dryer - Gas
Maytag LDG8424AAM Dryer - Gas
Maytag LDG8424ABE Dryer - Gas
Maytag LDG8426AAE Dryer - Gas
Maytag LDG8426AAM Dryer - Gas
Maytag LDG8426ABE Dryer - Gas
International LDG8426AGE Dryer - Gas
International LDG8426EGE Dryer - Gas
International LDG8426GGE Dryer - Gas
Maytag LDG8500 Dryer - Gas
Maytag LDG8500AAL Dryer - Gas
Maytag LDG8500AAW Dryer - Gas
Maytag LDG8506AAE Dryer - Gas
Maytag LDG8506AAM Dryer - Gas
Maytag LDG8600 Dryer - Gas
Maytag LDG8600AAL Dryer - Gas
Maytag LDG8600AAW Dryer - Gas
Maytag LDG8600ABL Dryer - Gas
Maytag LDG8600ABW Dryer - Gas
Maytag LDG8604AAE Dryer - Gas
Maytag LDG8604AAL Dryer - Gas
Maytag LDG8604AAM Dryer - Gas
Maytag LDG8606AAE Dryer - Gas
Maytag LDG8606AAM Dryer - Gas
Maytag LDG8616AAE Dryer - Gas
Maytag LDG8616AAM Dryer - Gas
Maytag LDG8624AAE Dryer - Gas
Maytag LDG8624AAL Dryer - Gas
Maytag LDG8624AAM Dryer - Gas
Maytag LDG8626AAE Dryer - Gas
Maytag LDG8626AAM Dryer - Gas
Maytag LDG8704AAE Dryer - Gas
Maytag LDG8704AAL Dryer - Gas
Maytag LDG8704AAM Dryer - Gas
Maytag LDG8706AAE Dryer - Gas
Maytag LDG8706AAM Dryer - Gas
Maytag LDG8804AAE Dryer - Gas
Maytag LDG8804AAL Dryer - Gas
Maytag LDG8804AAM Dryer - Gas
Maytag LDG882 Dryer - Gas
Maytag LDG8824AAE Dryer - Gas
Maytag LDG8824AAL Dryer - Gas
Maytag LDG8824AAM Dryer - Gas
Maytag LDG882D Dryer - Gas
Maytag LDG8904AAE Dryer - Gas
Maytag LDG8904AAL Dryer - Gas
Maytag LDG8904AAM Dryer - Gas
Norge LDG912700 Dryer - Gas
Norge LDG912724 Dryer - Gas
Norge LDG9127A Dryer - Gas
Norge LDG9127H Dryer - Gas
Norge LDG9127W Dryer - Gas
Maytag LDG9206AAE Dryer - Gas
Maytag LDG9206AAM Dryer - Gas
Maytag LDG9206ABE Dryer - Gas
Maytag LDG9304AAE Dryer - Gas
Maytag LDG9304AAL Dryer - Gas
Maytag LDG9304AAM Dryer - Gas
Maytag LDG9304ABE Dryer - Gas
Maytag LDG9304ABM Dryer - Gas
Maytag LDG9306AAE Dryer - Gas
Maytag LDG9306AAM Dryer - Gas
Maytag LDG9306ABE Dryer - Gas
Maytag LDG9306ABM Dryer - Gas
Maytag LDG9314AAE Dryer - Gas
Maytag LDG9314AAL Dryer - Gas
Maytag LDG9314AAM Dryer - Gas
Maytag LDG9316AAE Dryer - Gas
Maytag LDG9316AAM Dryer - Gas
Maytag LDG9334AAE Dryer - Gas
Maytag LDG9334AAL Dryer - Gas
Maytag LDG9334AAM Dryer - Gas
Maytag LDG9606AAE Dryer - Gas
Maytag LDG9606AAM Dryer - Gas
Maytag LDG9606ABE Dryer - Gas
Maytag LDG9606ABM Dryer - Gas
Maytag LDG9700 Dryer - Gas
Maytag LDG9700AAL Dryer - Gas
Maytag LDG9700AAW Dryer - Gas
Maytag LDG9700ABL Dryer - Gas
Maytag LDG9700ABW Dryer - Gas
Maytag LDG9701AAL Dryer - Gas
Maytag LDG9701AAW Dryer - Gas
Maytag LDG9701ABL Dryer - Gas
Maytag LDG9701ABW Dryer - Gas
Maytag LDG9800 Dryer - Gas
Maytag LDG9800AAL Dryer - Gas
Maytag LDG9800AAW Dryer - Gas
Maytag LDG9800ABL Dryer - Gas
Maytag LDG9800ABW Dryer - Gas
Maytag LDG9801AAL Dryer - Gas
Maytag LDG9801AAW Dryer - Gas
Maytag LDG9801ABL Dryer - Gas
Maytag LDG9801ABW Dryer - Gas
Maytag LDG9804AAE Dryer - Gas
Maytag LDG9804AAL Dryer - Gas
Maytag LDG9804AAM Dryer - Gas
Maytag LDG9806AAE Dryer - Gas
Maytag LDG9806AAM Dryer - Gas
Maytag LDG9814AAE Dryer - Gas
Maytag LDG9814AAL Dryer - Gas
Maytag LDG9814AAM Dryer - Gas
Maytag LDG9824AAE Dryer - Gas
Maytag LDG9824AAL Dryer - Gas
Maytag LDG9824AAM Dryer - Gas
Maytag LDG9900 Dryer - Gas
Maytag LDG9900AAL Dryer - Gas
Maytag LDG9900AAW Dryer - Gas
Maytag LDG9900ABL Dryer - Gas
Maytag LDG9900ABW Dryer - Gas
Maytag LDG9900BAL Dryer - Gas
Maytag LDG9900BAW Dryer - Gas
Maytag LDG9900BBL Dryer - Gas
Maytag LDG9900BBW Dryer - Gas
Maytag LDG9900R Dryer - Gas
Maytag LDG9904AAE Dryer - Gas
Maytag LDG9904AAL Dryer - Gas
Maytag LDG9904AAM Dryer - Gas
Admiral LDGA100AAL Dryer - Gas
  #2 (permalink)
Old 12-13-2010, 12:48 PM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
We probably could have saved you a bunch of money spent on unnecessary parts. What you describe sounds like classic failure of the ignition coils. Probably one of them is failing; but by convention, we normally replace them as a set.
Part number: AP3094251
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer won't heat in any cycle ohiokudzu Dryer Repair 4 08-02-2010 02:45 PM
Gas dryer does not heat or cycle.. bkopacz Dryer Repair 0 10-27-2009 08:59 AM
Dryer Doesn't Work In Heat Cycle TEXAS MOSS 69 Dryer Repair 1 10-21-2009 03:18 AM
Dryer will only heat on one cycle C150867 Dryer Repair 0 06-10-2008 05:47 AM
Gas Dryer doesn't heat during cycle castillocm Dryer Repair 0 04-29-2008 11:17 AM
