Discuss
How can you tell if the heating element is bad?
 in
Dryer Repair
Help! My dryer will not heat. Is there a sure way to tell if the heating element is bad? I've
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » How can you tell if the heating element is bad?
  #1 (permalink)
Old 12-11-2010, 08:06 PM
Junior Member
JermWV is on a distinguished road
Default How can you tell if the heating element is bad?
Brand: Maytag   Age: 1 - 5 years
Help! My dryer will not heat. Is there a sure way to tell if the heating element is bad? I've checked the vents and all seems clear.
  #2 (permalink)
Old 12-12-2010, 03:45 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
A model number may help others help you
Model Number Locator
Often you can see that the element is broken.
You can also measure it with a meter, should be 10 to 12 ohms.
There are also thermostats in the heater circuit that can stop it from heating.
They also can be checked with a meter, all should be 0 ohms (closed) at room temperature.
Also if you do not have the full 240 volts will cause no heat.
Voltage Test
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
Blown Heater Thermal Fuse Test
It should be 0 ohms.
If it is blown you have to find out what caused it to go.
Note: that sometimes they do just blow on their own but changing it without checking other things is a gamble. I beleive richappy (another regular poster on this forum) has done a study on thermostats and found a wide variation of actual trip point and what is specified.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it so the thermal fuse blows.
If the above is OK then you will also have to replace the hi-limit as it should have regulated the temperature so the fuse did not blow.
Note: That unless there is another problem in the unit the hi-limit should never have to open. It is just a safety device with the fuse being a backup safety device.
You still have to find out why it blew.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it's contacts may not be opening (welded shut).
Meter
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Heating coil or Heating element assembly jayclagg Dryer Repair 1 02-11-2010 07:26 AM
Heating Element On/Off buttons don't work. Element stays on mostly. juliotamu01 Dishwasher Repair 0 11-13-2009 06:05 AM
Replaced heating element now heating element nor broil element work, all else does rontetley Oven Repair (including Ranges and Cooktops) 1 10-26-2009 01:30 PM
bake element not heating but broil element heating okay horno Oven Repair (including Ranges and Cooktops) 1 10-04-2009 11:37 AM
Bottom heating element in oven not heating Bill Pitts Oven Repair (including Ranges and Cooktops) 1 03-07-2009 06:02 PM
