I opened up machine as it stopped running - but could still hear motor and/or pump. I noticed a vibration shock was broken. Seems easy enough to replace, but would some sensor have stopped the spinning altogether? I'm only concerned that once I replace the shock (or both of them) that it will not continue to spin - problem might be greater.
