Discuss
whirlpool dryer won't stay hot
 in
Dryer Repair
The dryer sometimes warms up but then goes cold. Other times it will not heat at all. Ads By Google
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » whirlpool dryer won't stay hot
  #1 (permalink)
Old 12-08-2010, 11:17 AM
Junior Member
myron miller is on a distinguished road
Default whirlpool dryer won't stay hot
Model Number: LGR8620PG0   Brand: Whirlpool   Age: 5 - 10 years
Ads By Google
Related Models
Whirlpool LGR8620PG0 29"gas Dryer
Whirlpool LGR8620PG1 29"gas Dryer
Whirlpool LGR8620PW0 29"gas Dryer
Whirlpool LGR8620PW1 29"gas Dryer
Whirlpool LGR8646LG0
Whirlpool LGR8648LG1 29"gas Dryer
Whirlpool LGR8648LQ0
Whirlpool LGR8648LW0
Whirlpool LGR8648LW1 29"gas Dryer
Whirlpool LGR8648PG0 29"gas Dryer
Whirlpool LGR8648PG1 29" Gas Dryer
Whirlpool LGR8648PQ0 29" Gas Dryer
Whirlpool LGR8648PQ1 29" Gas Dryer
Whirlpool LGR8648PW0 29"gas Dryer
Whirlpool LGR8648PW1 29" Gas Dryer
Whirlpool LGR8857EQ0
Whirlpool LGR8857EQ1
Whirlpool LGR8857EQ2
Whirlpool LGR8857EQ3
Whirlpool LGR8857EZ0
Whirlpool LGR8857EZ1
Whirlpool LGR8857EZ2
Whirlpool LGR8857EZ3
Whirlpool LGR8858DQ0
Whirlpool LGR8858DQ1
Whirlpool LGR8858DZ0
Whirlpool LGR8858DZ1
Whirlpool LGR8858EQ0
Whirlpool LGR8858EQ1
Whirlpool LGR8858EQ2
Whirlpool LGR8858EQ3
Whirlpool LGR8858EZ0
Whirlpool LGR8858EZ1
Whirlpool LGR8858EZ2
Whirlpool LGR8858EZ3
Amana LGS10AW Washer - Top Loading
Amana LGS19AW Dryer - Gas
Amana LGS33AW Dryer - Gas
Amana LGS34AW Washer - Top Loading
Frigidaire LGS389FEA Frigidaire/gas Range
Whirlpool LGT5434AN0
Whirlpool LGT5434AQ0
Whirlpool LGT5434AW0
Whirlpool LGT5436AN0
Whirlpool LGT5436AW0
Whirlpool LGT5624BN0
Whirlpool LGT5624BN1
Whirlpool LGT5624BN2
Whirlpool LGT5624BQ0
Whirlpool LGT5624BQ1
Whirlpool LGT5624BQ2
Whirlpool LGT5624BW0
Whirlpool LGT5624BW1
Whirlpool LGT5624BW2
Whirlpool LGT5624DQ0
Whirlpool LGT5624DQ1
Whirlpool LGT6634AN0
Whirlpool LGT6634AN1
Whirlpool LGT6634AN2
Whirlpool LGT6634AQ0
Whirlpool LGT6634AQ1
Whirlpool LGT6634AQ2
Whirlpool LGT6634AW0
Whirlpool LGT6634AW1
Whirlpool LGT6634AW2
Whirlpool LGT6634DQ0
Whirlpool LGT6634DQ1
Whirlpool LGT6634DZ0
Whirlpool LGT6634DZ1
Whirlpool LGT6638AN0
Whirlpool LGT6638AN1
Whirlpool LGT6638AN2
Whirlpool LGT6638AQ0
Whirlpool LGT6638AQ2
Whirlpool LGT6638AW0
Whirlpool LGT6638AW1
Whirlpool LGT6638AW2
Whirlpool LGT6638DQ0
Whirlpool LGT6638DQ1
Whirlpool LGT6638DZ0
Whirlpool LGT6638DZ1
Whirlpool LGT7646AN0
Whirlpool LGT7646AQ0
Whirlpool LGT7646AQ2
Whirlpool LGT7646AW0
Whirlpool LGT7646AZ0
Whirlpool LGT7646AZ2
Whirlpool LGT7646DQ0
Whirlpool LGT7646DQ1
Whirlpool LGT7646DZ0
Whirlpool LGT7646DZ1
Whirlpool LGT7646EQ0
Whirlpool LGT7646EQ1
Whirlpool LGT7646EQ2
Whirlpool LGT7646EQ3
Whirlpool LGT7646EZ0
Whirlpool LGT7646EZ1
Whirlpool LGT7646EZ2
Whirlpool LGT7646EZ3
Whirlpool LGT7848AN0
Whirlpool LGT7848AQ0
Whirlpool LGT7848AQ1
Whirlpool LGT7848AQ2
Whirlpool LGT7848AW0
Whirlpool LGT7848AZ0
Whirlpool LGT7848AZ1
Whirlpool LGT7848AZ2
Whirlpool LGT7848DQ0
Whirlpool LGT7848DQ1
Whirlpool LGT7848DZ0
Whirlpool LGT7848DZ1
Whirlpool LGT8858AN0
Whirlpool LGT8858AN1
Whirlpool LGT8858AN2
Whirlpool LGT8858AQ0
Whirlpool LGT8858AQ1
Whirlpool LGT8858AQ2
Whirlpool LGT8858AW0
Whirlpool LGT8858AW1
Whirlpool LGT8858AW2
  #2 (permalink)
Old 12-08-2010, 12:17 PM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Myron,
You most likely have a bad set of gas valve solenoids,
Part number: AP3094251
There are other possibilities,
Weak igniter, sticky radiant sensor, or bad thermostat,
But your description leads me to believe your coils are weak.
Here's a way for you to check,
On the front panel of your dryer, there should be a 1x1 inch plastic cover,
You can remove that swatch of plastic and start the dryer,and observe the gas valve operation.
A few seconds after you start the machine, you should see an orange glow from the igniter.
After the glow starts, in 15 to 20 seconds you should hear a click, the igniter glow should start to fade, at the same time you should hear and see the gas released and the flame ignite.
You may have to observe the gas valve operation for several cycles.
What will probably happen, after several cycles, the igniter will glow, you'll hear the sensor click, the glow will diminish, but there'l be no flame.
If that occurrs, order and install the gas valve solenoid / coil kit.
Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Dryer wont stay running ckb24 Dryer Repair 10 09-12-2010 03:53 PM
whirlpool dishwasher won't stay running davmitch Dishwasher Repair 3 09-01-2010 07:15 PM
Whirlpool dryer wont stay lit Myles.Smith Dryer Repair 4 06-19-2010 06:00 PM
whirlpool SF367LEMQ won't stay lit tysdad04 Oven Repair (including Ranges and Cooktops) 3 02-18-2009 06:36 AM
Whirlpool Refrigerator sometimes does not stay cold rmuhlbach Refrigerator & Freezer Repair 1 01-07-2009 07:56 AM
