Discuss
Heating Element
 in
Dryer Repair
Installation instructions for the replacing the heating element. Ads By Google Related Models Kenmore  110.87405140  GAS DRYER Kenmore  110.87405160  COMMERCIAL
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Heating Element
  #1 (permalink)
Old 12-07-2010, 10:08 AM
Junior Member
bmassey26 is on a distinguished road
Default Heating Element
Model Number: 110.86476800   Brand: Kenmore   Age: More than 10 years
Ads By Google
Related Models
Kenmore 110.87405160  COMMERCIAL GAS DRYER
Kenmore 110.87405840  GAS DRYER
Kenmore 110.87405860  COMMERCIAL GAS DRYER
Kenmore 110.87407140  GAS DRYER
Kenmore 110.87407840  GAS DRYER
Kenmore 110.92490100  GAS DRYER
Kenmore 110.92822100  GAS DRYER
Kenmore 110.92822101  GAS DRYER
Kenmore 110.92822102  GAS DRYER
Kenmore 110.92824100  GAS DRYER
Kenmore 110.92824101  GAS DRYER
Kenmore 110.92824102  GAS DRYER
Kenmore 110.92826100  GAS DRYER
Kenmore 110.92826101  GAS DRYER
Kenmore 110.92826102  GAS DRYER
Kenmore 110.92832100  DRYER
Kenmore 110.92834100  DRYER
Kenmore 110.92836100  DRYER
Kenmore 110.94832200  GAS DRYER
Kenmore 110.94832201  GAS DRYER
Kenmore 110.94834200  GAS DRYER
Kenmore 110.94834201  GAS DRYER
Kenmore 110.94836200  GAS DRYER
Kenmore 110.94836201  GAS DRYER
Kenmore 110.96060100  ELECTRIC DRYER
Kenmore 110.96091100  ELECTRIC DRYER
Kenmore 110.96091300  ELECTRIC DRYER
Kenmore 110.96091700  ELECTRIC DRYER
Kenmore 110.96091800  ELECTRIC DRYER
Kenmore 110.96093100  ELECTRIC DRYER
Kenmore 110.96093300  ELECTRIC DRYER
Kenmore 110.96093500  ELECTRIC DRYER
Kenmore 110.96093700  ELECTRIC DRYER
Kenmore 110.96093800  ELECTRIC DRYER
Kenmore 110.96094100  ELECTRIC DRYER
Kenmore 110.96094300  ELECTRIC DRYER
Kenmore 110.96094500  ELECTRIC DRYER
Kenmore 110.96094700  ELECTRIC DRYER
Kenmore 110.96094800  ELECTRIC DRYER
Kenmore 110.96110100  ELECTRIC DRYER
Kenmore 110.96121100  ELECTRIC DRYER
Kenmore 110.96195100  ELECTRIC DRYER
Kenmore 110.96195110  DRYER FEATURE SHEET
Kenmore 110.96407160  COMMERCIAL ELECTRIC DRYER
Kenmore 110.97502120  GAS DRYER-COMMERCIAL
Kenmore 110.97502820  GAS DRYER-COMMERCIAL
Kenmore 110.97565120  GAS DRYER
Kenmore 110.97565220  GAS DRYER
Hoover 1100
Magic Chef 1100PAA Range - F/s Std Gas
Magic Chef 1100PAW Range - F/s Std Gas
Magic Chef 1100PAW-K Range - F/s Std Gas
Magic Chef 1100PAW-KL Range - F/s Std Gas
Magic Chef 1100PAW-L Range - F/s Std Gas
Magic Chef 1100PRA Range - F/s Std Gas
Magic Chef 1100PRA-K Range - F/s Std Gas
Magic Chef 1100PRW Range - F/s Std Gas
Magic Chef 1100PRW-K Range - F/s Std Gas
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Sears 11016502693 AUTOMATIC WASHER
Sears 11016502694 AUTOMATIC WASHER
Sears 11016512691 AUTOMATIC WASHER
Sears 11016512692 AUTOMATIC WASHER
Sears 11016602690 AUTOMATIC WASHER
Sears 11016602691 AUTOMATIC WASHER
Sears 11016602692 AUTOMATIC WASHER
Sears 11016602693 AUTOMATIC WASHER
Sears 11016611690 AUTOMATIC WASHER
Sears 11016611691 AUTOMATIC WASHER
Sears 11016611692 AUTOMATIC WASHER
Sears 11016612690 AUTOMATIC WASHER
Sears 11016612691 AUTOMATIC WASHER
Sears 11016612692 AUTOMATIC WASHER
Sears 11016872691 AUTOMATIC WASHER
Sears 11016872692 AUTOMATIC WASHER
Sears 11016872693 AUTOMATIC WASHER
Sears 11018542890 AUTOMATIC WASHER
Hoover 1102
Kenmore 11020052994 WASHER
Kenmore 11020056991 WASHER
Kenmore 11020056992 WASHER
Kenmore 11020056994 WASHER
Kenmore 11020072990 WASHER
Kenmore 11020072991 WASHER
Kenmore 11020072992 WASHER
Kenmore 11020072993 WASHER
Kenmore 11020092990 WASHER
Kenmore 11020092991 WASHER
Kenmore 11020092992 WASHER
Kenmore 11020092993 WASHER
Kenmore 11020094992 WASHER
Kenmore 11020094993 WASHER
Kenmore 11020096990 WASHER
Kenmore 11020096991 WASHER
Kenmore 11020096992 WASHER
Kenmore 11020096993 WASHER
Kenmore 11020097990 WASHER
Kenmore 11020097991 WASHER
Kenmore 11020097992 WASHER
Kenmore 11021062000 AUTOMACTIC WASHER, COMPACT A/W
Kenmore 11021062001 WASHER
Kenmore 11021064000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021064001 WASHER
Kenmore 11021066000 AUTOMACTIC WASHER, COMPACT A/W
Kenmore 11021066001 WASHER
Kenmore 11021082000 WASHER
Kenmore 11021082001 WASHER
Kenmore 11021084000 WASHER
Kenmore 11021084001 WASHER
Kenmore 11021086000 WASHER
Kenmore 11021086001 WASHER
Kenmore 11021882000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021882001 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021884000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021884001 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021892000 WASHER
Kenmore 11021894000 WASHER
Kenmore 11022032100 WASHER
  #2 (permalink)
Old 12-07-2010, 12:04 PM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
B,
Here is a basic heater removal, installation , instructions as you requested.
Good Luck,
1. Unplug dryer or disconnect power.
2. Remove the rear panel.
3. To remove the thermal cutoff (TCO)
a) Remove the two wires from the TCO
terminals.
b) Remove the hex-head screw, unhook
the end of the bracket, and remove
the TCO.
4. To remove the heater and inlet thermistor/
high-limit thermostat
a) Lift the locking tab and remove the
2-wire connector from the inlet thermistor.
b) Remove the wire connector from the
high-limit thermostat terminal.
c) Remove the two wire connectors from
the heater terminal block
d) Remove the two hex-head screws from
the heater assembly and remove the
assembly
e) Using a flat-blade screwdriver, pry the
inlet thermistor terminal off the heater
terminal, and remove the thermistor from
the assembly.
Reverse procedure and test unit for operation.
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 08-10-2012, 12:19 PM
Junior Member
vanj333 is on a distinguished road
Default Help
thank you for the instruction B.
  #4 (permalink)
Old 08-10-2012, 12:41 PM
Senior Expert
Default
Quote:
Van,
You're quite welcome. We hope all went OK, and you're dryer is up and running.
Drop us a line anytime you need assistance on your aplliances, we're here to help.
Thanks Again,
__________________
Joe M. APP TEAM
  #5 (permalink)
Old 08-10-2012, 02:06 PM
Junior Member
Post Ty Joe
Quote:
Originally Posted by Joe / APP Team View Post
Van,
Thanks Again,
thank you again and I wll do so part should be here tomorrow.So it will be up and running about this time. You guys save me and alot of other people alot of pain and suffering.
  #6 (permalink)
Old 08-10-2012, 02:11 PM
Senior Expert
Default
Van,
Thanks Again.
Once you're done with the repair, post a report of how things went, any quick tips you may have , etc. that will help other Forum viewers in the future. We'd appreciate it.
Thanks,
__________________
Joe M. APP TEAM
  #7 (permalink)
Old 08-12-2012, 05:31 PM
Junior Member
Default Attn denman and Joe
Dang it I have replaced thermal fuse nothing. I have replaced the heating element nothing still no heat. im at a loss guys but that not hard for me i dont work on dryer very often. so tell me guys what should I do next??
  #8 (permalink)
Old 08-13-2012, 01:47 PM
Junior Member
Default
I need some help on what I will do next im thinking of getting the thermal shut off kit. But waiting on your responses.
  #9 (permalink)
Old 08-14-2012, 07:49 AM
Senior Expert
Default
Van,
The thermal fuse kit, could be the issue. If replacing it, doesn't solve the issue, you'll need to get access to a multi meter,
Part number: AP5641753
so we can test circuits and voltages, and get your dryer up and running.
Thanks,
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Heating coil or Heating element assembly jayclagg Dryer Repair 1 02-11-2010 07:26 AM
Heating Element On/Off buttons don't work. Element stays on mostly. juliotamu01 Dishwasher Repair 0 11-13-2009 06:05 AM
Replaced heating element now heating element nor broil element work, all else does rontetley Oven Repair (including Ranges and Cooktops) 1 10-26-2009 01:30 PM
bake element not heating but broil element heating okay horno Oven Repair (including Ranges and Cooktops) 1 10-04-2009 11:37 AM
Heating element stopped heating JSP38G0T1BB Gravity Railroad Oven Repair (including Ranges and Cooktops) 1 06-23-2009 02:10 PM
