jordon
#1 Posted : Monday, December 6, 2010 7:04:27 AM(UTC)
jordon
need to replace baffle how do i get to the screw does top open
kayakcrzy
#2 Posted : Monday, December 6, 2010 2:35:59 PM(UTC)
kayakcrzy
Real easy. You need to take the door off. There is one screw that holds the top of the hinge to the cabinet, and one on the bottom hinge. Then lift up on the door, and pull it out. Now on the other side of the front, as if there was a left hand door remove those two screw, and the front will come off, you can get to it from there. If you need more room, take the 2 screws off that hold the top down. Tom ApplianceEducator.com
WED4815EW1 Dryer overheating? (Dryer Repair)
by Guest 4/16/2024 12:21:03 PM(UTC)
DLEX5780WE lg dryer shutting off before the clothes are dry. (Dryer Repair)
by LMA 4/13/2024 11:00:21 AM(UTC)
help maytag comercial dryer (Dryer Repair)
by blackwell316 4/4/2024 5:05:48 PM(UTC)
grease for rear dryer bearing (Dryer Repair)
by bronn033 3/30/2024 12:57:30 PM(UTC)
Kenmore Gas Dryer Running Hot (Dryer Repair)
by Guest 3/30/2024 6:24:53 AM(UTC)
Kenmore 100 dryer Heating Element (Dryer Repair)
by postalservice21 3/27/2024 6:43:17 AM(UTC)
Maytag electric dryer model MDE6400AYQ (Dryer Repair)
by Guest 3/25/2024 10:05:21 AM(UTC)
GE Dryer Timer and Housing (Dryer Repair)
by Guest 3/25/2024 7:47:59 AM(UTC)
Samsung dryer motor (Dryer Repair)
by Guest 3/24/2024 11:17:52 AM(UTC)
Replacement dryer motor W11364931 (Dryer Repair)
by Guest 3/23/2024 8:47:41 AM(UTC)
Maytag electirc dryer model LDE9334ACM (Dryer Repair)
by Guest 3/22/2024 6:07:19 PM(UTC)
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
Electric Dryer Amana NED7300WW1 (Dryer Repair)
by AlexanderK 3/13/2024 1:37:06 PM(UTC)
Maytag electric dryer model LDE9306ACE (Dryer Repair)
by Guest 3/7/2024 9:11:14 AM(UTC)
Speed Queen electric dryer model LES17AWF (Dryer Repair)
by Guest 3/5/2024 10:42:09 AM(UTC)
