Discuss
Takes forever to dry anything
 in
Dryer Repair
My dryer is heating up ok & stays hot but takes forever to dry anything. My husband checked the element
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Takes forever to dry anything
  #1 (permalink)
Old 12-04-2010, 03:03 PM
Junior Member
megbee is on a distinguished road
Question Takes forever to dry anything
Model Number: ALE643RBW   Brand: Amana   Age: 5 - 10 years
My husband checked the element & it seems ok. We cleaned the vent & all the inside to remove any lint. Do you have any other suggestions? We would appreciate any help you can give us.
Ads By Google
Related Models
Amana ALE643RBW DRYER- ELE
Amana ALE643RCW DRYER- ELE
Amana ALE665SAC DRYER- ELE
Amana ALE665SAW DRYER- ELE
Amana ALE866SAC DRYER- ELE
Amana ALE866SAW DRYER- ELE
Amana ALE866SBC DRYER- ELE
Amana ALE866SBW DRYER- ELE
Amana ALE866SCW DRYER- ELE
Amana ALE868QAW DRYER- ELE
Amana ALE868QCW WASHER-TOP LOADING
Amana ALE956EAC DRYER- ELE
Amana ALE956EAW DRYER- ELE
Whirlpool ALF12420 Air-conditioner/heat pump
Whirlpool ALF15040 Air-conditioner/heat pump
Whirlpool ALF20040 Air-conditioner/heat pump
Whirlpool ALF21040 Air-conditioner/heat pump
Whirlpool ALF24040 Air-conditioner/heat pump
Whirlpool ALFH0820 Air-conditioner/heat pump
Amana ALG120RAW DRYER- GAS
Amana ALG230RAW DRYER- GAS
Amana ALG230RCW DRYER- GAS
Amana ALG331RAC DRYER- GAS
Amana ALG331RAW DRYER- GAS
Amana ALG331RMC DRYER- GAS
Amana ALG331RMW DRYER- GAS
Amana ALG443RAC DRYER- GAS
Amana ALG443RAW DRYER- GAS
Amana ALG443RCW DRYER- GAS
Amana ALG565SAC DRYER- GAS
Amana ALG565SAW DRYER- GAS
Amana ALG643RAC DRYER- GAS
Amana ALG643RAW DRYER- GAS
Amana ALG643RBC DRYER- GAS
Amana ALG643RBW DRYER- GAS
Amana ALG643RMC WASHER-TOP LOADING
Amana ALG643RMC DRYER- GAS
Amana ALG643RMC1 WASHER-TOP LOADING
Amana ALG643RMW WASHER-TOP LOADING
Amana ALG643RMW DRYER- GAS
Amana ALG643RMW1 WASHER-TOP LOADING
Amana ALG665SAC DRYER- GAS
Amana ALG665SAW DRYER- GAS
Amana ALG866SAC DRYER- GAS
Amana ALG866SAW DRYER- GAS
Amana ALG866SBC DRYER- GAS
Amana ALG866SBW DRYER- GAS
Amana ALG866SCW DRYER- GAS
Amana ALG868QAW DRYER- GAS
Amana ALG868QCW WASHER-TOP LOADING
Amana ALG956EAC DRYER- GAS
Amana ALG956EAW DRYER- GAS
Whirlpool ALJ00520 Air-conditioner/heat pump
Whirlpool ALJ07520 Air-conditioner/heat pump
Whirlpool ALJ10020 Air-conditioner/heat pump
Whirlpool ALJ12020 Air-conditioner/heat pump
Whirlpool ALJ18040 Air-conditioner/heat pump
General Electric ALM15DAM1 Room air conditioner
General Electric ALM18DAM1 Zoneline
Admiral ALR1100AJQ RANGE- F/S STD GAS
Admiral ALR1100AJW RANGE- F/S STD GAS
Admiral ALR1420BDQ RANGE- F/S STD GAS
Admiral ALR1420BDW RANGE- F/S STD GAS
Admiral ALR1450AJW RANGE- F/S STD GAS
Admiral ALR1450BJW RANGE- F/S STD GAS
Admiral ALR5715QDS RANGE- S/C F/S GAS
Admiral ALR5715QDW RANGE- S/C F/S GAS
Amana ALW110RAW WASHER-TOP LOADING
Amana ALW210RAW WASHER-TOP LOADING
Amana ALW210RMC Washer - Top Loading
Amana ALW210RMC WASHER-TOP LOADING
Amana ALW210RMW Washer - Top Loading
Amana ALW210RMW WASHER-TOP LOADING
Admiral ALW221RJW WASHER-TOP LOADING
Amana ALW410DAW WASHER-TOP LOADING
Amana ALW430RAC WASHER-TOP LOADING
Amana ALW430RAW WASHER-TOP LOADING
Amana ALW432RAW WASHER-TOP LOADING
Amana ALW450QAC WASHER-TOP LOADING
Amana ALW450QAW WASHER-TOP LOADING
Amana ALW480DAC WASHER-TOP LOADING
  #2 (permalink)
Old 12-04-2010, 03:19 PM
Senior Expert
APP Volunteer
kayakcrzy will become famous soon enough
Default
There is a place inside the dryer that you have to clean. It is the blower housing. You need to take the front off, and then once the front is off, you need to take the blower housing off. There are 4 screws holding it on to the front of the frame on the dryer. 2 on the right, and 2 on the left. When you remove that, you will look on the bottom, and there will most likely be a ton of lint. If not, you will have to replace the operating thermostat. Tom ********************************************
  #3 (permalink)
Old 12-05-2010, 01:59 PM
Junior Member
Default Takes forever to dry anything - another question
Quote:
Thanks for the info, I have a question - Can you tell me where the operating thermostat is & what it does. If you can help me with that i would be very grateful!!
  #4 (permalink)
Old 12-06-2010, 04:42 AM
Senior Expert
APP Volunteer
Default
Actually there are 2 thermostats, and they are located in the same place, which is right on the blower housing, in the front. One is a heater thermostat, and it measures the heater temperature, and its part # is 61623. The other which is right next to it, is the operating thermostat, which senses the operating temp of the dryer. It part # is 503979. So, in a regular dry cycle the temp should read at the vent, if you have a thermometer, with a thin shaft, you can poke it through the vent hose, should read between 145-155 degrees. If you have that, then cleaning the blower housing and the vent to the outside was it. If not, I recommend you replace the both of the thermostats. They are cheap, and they both have been over taxed, because they have been clicking off, and on, at a much higher rate, so they tend to loose there accuracy. I hope that helps. Tom Appliance Educator, Appliance Parts, Washer and Dryer Parts, Refridgerator and Freezer Parts, Stove and Oven Parts
  #5 (permalink)
Old 12-22-2010, 12:41 PM
Junior Member
Default it worked like a charm
Tom, Thank you soooo much. We replaced both thermostats & everything works great now!! You were a great help! Thanks again!!
  #6 (permalink)
Old 12-22-2010, 03:30 PM
Senior Expert
APP Volunteer
Default
Great Job!!! You guys have a Merry Christmas!!!!! Tom ********************************************
  #7 (permalink)
Old 12-23-2010, 10:05 AM
Junior Member
Default
We couldn't have done it without you! You have a very Merry Christmas & A Happy New Year!!
  #8 (permalink)
Old 01-26-2011, 06:44 PM
Junior Member
lparece is on a distinguished road
Talking Excellent Advice! My Blower housing was CLOGGED
I think cleaning the housing is going to get it done for me... It was basically jammed full. Thanks so much!
  #9 (permalink)
Old 01-27-2011, 04:30 AM
Senior Expert
APP Volunteer
Default
Glad to help!!! Tom ********************************************
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven takes forever to heat lynap Oven Repair (including Ranges and Cooktops) 4 12-03-2012 04:48 PM
Oven takes forever to preheat slave2christ Dryer Repair 4 07-29-2010 06:22 PM
Oven takes forever to heat up sarahskennedy Oven Repair (including Ranges and Cooktops) 0 02-08-2010 05:46 AM
Takes forever to preheat Jakedog67 Oven Repair (including Ranges and Cooktops) 3 01-08-2010 04:48 PM
oven takes forever to heat up nitrodog Oven Repair (including Ranges and Cooktops) 0 10-31-2007 03:05 PM
