On this model, do I remove the front or back of unit to replace and inspect belt and drum roller?
Originally Posted by: tnirp844 On this model, do I remove the front or back of unit to replace and inspect belt and drum roller? On this model, which is a front loader, just take off the bottom front panel. There will be 2 or 3 screws on the bottom of the bottom panel. Then look in there. Actually if the belt was broken, you would be able to program the dryer, but, when you hit start nothing. Because there is a belt switch. So if the belt is broken, it won't run at all. Tom ApplianceEducator.com
