| » dryer wont heat up at all |
Model Number: 11060612990 Brand: Kenmore Age: 5 - 10 years
I have replaced the heat element, thermostat, thermal fuse and power cord. still no heat. Power to unit is good, the units cuts on but still no heat. thanks in advance for any help
Try flipping the breaker off and on a couple times (not fast, but deliberately). Sometimes a doubled circuit breaker can appear to be on, while one leg of the power is actually dropped out.
Test the outlet for 240VAC between the two hot legs; Both should have 120VAC between each and the ground leg. If these are OK, Check the voltage at the back of the dryer, where the cord connects to the terminal block. Again, you should find 240VAC between the red and black wires, and 120VAC when you check between the red and green(or white), and the black and green (or white). Remember: You're dealing with lethal voltages here Let us know what you find. |
| Display Modes | |
| dryer wont heat | Jose Hernandez Jr. | Dryer Repair | 0 | 10-20-2010 07:57 AM |
| Dryer wont heat | osinski4 | Dryer Repair | 1 | 05-26-2010 04:16 AM |
| My dryer wont heat up | jab4972 | Dryer Repair | 3 | 03-12-2009 05:50 PM |
| clothes dryer wont heat timer wont work | tampee | Dryer Repair | 2 | 01-17-2009 09:53 AM |
| Timer wont advance and dryer wont heat | awatt26 | Dryer Repair | 2 | 06-20-2008 09:43 PM |
