Discuss
Dryer won't start
 in
Dryer Repair
I have a starting issue. The dryer would start and then immediately shut off. The dryer then would not start.
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer won't start
  #1 (permalink)
Old 12-01-2010, 08:49 PM
Junior Member
vavs is on a distinguished road
Default Dryer won't start
Model Number: 11087670100   Brand: Kenmore   Age: More than 10 years
I have a starting issue. The dryer would start and then immediately shut off. The dryer then would not start. I replaced the start switch which showed burn marks on the inside. I put the new switch in and the dryer started right up. It then shut down and showed the same symptoms. I checked the thermal fuses ( 3 separate spots ) and they all show closed contacts using an ohm meter. There is one additional switch on the motor with 6 -8 wires attached to it. Looks like 3 hots coming from the control panel, one going to the gas ignitor, 2 going to the motor and a neutral. I don't know what to try next. Suggestions.
Ads By Google
Related Models
Kenmore 11088090100 ELECTRIC DRYER
Kenmore 11088090200 ELECTRIC DRYER
Kenmore 11088090400 ELECTRIC DRYER
Kenmore 11088090600 ELECTRIC DRYER
Kenmore 11088090800 ELECTRIC DRYER
Kenmore 11088182890 ELECTRIC DRYER
Kenmore 11088182891 COMPACT ELECTRIC DRYER
Kenmore 11088184890 ELECTRIC DRYER
Kenmore 11088184891 COMPACT ELECTRIC DRYER
Kenmore 11088390100 ELECTRIC DRYER
Kenmore 11088390110 ELECTRIC DRYER
Kenmore 11088390120 ELECTRIC DRYER
Kenmore 11088390130 ELECTRIC DRYER
Kenmore 11088390200 ELECTRIC DRYER
Kenmore 11088390210 ELECTRIC DRYER
Kenmore 11088390300 ELECTRIC DRYER
Kenmore 11088390310 ELECTRIC DRYER
Kenmore 11088390320 ELECTRIC DRYER
Kenmore 11088390330 ELECTRIC DRYER
Kenmore 11088390400 ELECTRIC DRYER
Kenmore 11088390410 ELECTRIC DRYER
Kenmore 11088390600 ELECTRIC DRYER
Kenmore 11088390610 ELECTRIC DRYER
Kenmore 11088390620 ELECTRIC DRYER
Kenmore 11088390630 ELECTRIC DRYER
Kenmore 11088390700 ELECTRIC DRYER
Kenmore 11088390710 ELECTRIC DRYER
Kenmore 11088390720 ELECTRIC DRYER
Kenmore 11088390730 ELECTRIC DRYER
Kenmore 11088390800 ELECTRIC DRYER
Kenmore 11088390810 ELECTRIC DRYER
Kenmore 11088390820 ELECTRIC DRYER
Kenmore 11088390830 ELECTRIC DRYER
Kenmore 11088416100 ELECTRIC DRYER
Kenmore 11088416110 ELECTRIC DRYER
Kenmore 11088416120 ELECTRIC DRYER
Kenmore 11088416130 ELECTRIC DRYER
Kenmore 11088416200 ELECTRIC DRYER
Kenmore 11088416210 ELECTRIC DRYER
Kenmore 11088416300 ELECTRIC DRYER
Kenmore 11088416310 ELECTRIC DRYER
Kenmore 11088416320 ELECTRIC DRYER
Kenmore 11088416330 ELECTRIC DRYER
Kenmore 11089182990 ELECTRIC DRYER
Kenmore 11089390830 ELECTRIC DRYER
Sears 11089416100 GAS DRYER
Sears 11089416110 GAS DRYER
Kenmore 11089416120 GAS DRYER
Kenmore 11089416130 GAS DRYER
Sears 11089416200 GAS DRYER
Sears 11089416210 GAS DRYER
Sears 11089416300 GAS DRYER
Sears 11089416310 GAS DRYER
Kenmore 11089416320 GAS DRYER
Kenmore 11089416330 GAS DRYER
Sears 11089416400 GAS DRYER
Sears 11089416410 GAS DRYER
Sears 11089416600 GAS DRYER
Sears 11089416610 GAS DRYER
Kenmore 11089416620 GAS DRYER
Kenmore 11089416630 GAS DRYER
Sears 11089416700 GAS DRYER
Sears 11089416710 GAS DRYER
Kenmore 11089416720 GAS DRYER
Kenmore 11089416730 GAS DRYER
Sears 11089416800 GAS DRYER
Sears 11089416810 GAS DRYER
Kenmore 11089416820 GAS DRYER
Kenmore 11089416830 GAS DRYER
Kenmore 11089417100 GAS DRYER
Kenmore 11089417300 GAS DRYER
Kenmore 11089417600 GAS DRYER
Kenmore 11089417700 GAS DRYER
Kenmore 11089417800 GAS DRYER
Kenmore 11089419100 GAS DRYER
Kenmore 11089419110 GAS DRYER
Kenmore 11089419111 GAS DRYER
Kenmore 11089419120 GAS DRYER
Kenmore 11089419300 GAS DRYER
Kenmore 11089419600 GAS DRYER
Kenmore 11089419700 GAS DRYER
Kenmore 11089419800 GAS DRYER
Kenmore 11089419810 GAS DRYER
Kenmore 11089419811 GAS DRYER
Kenmore 11089419820 GAS DRYER
Kenmore 11089519800 GAS DRYER
Sears 11089675100 WASHER/DRYER
Sears 11089675110 WASHER/DRYER
Sears 11089675300 WASHER/DRYER
Kenmore 11089722990 ELECTRIC DRYER
Kenmore 11089722991 ELECTRIC DRYER
Kenmore 11091110100 AUTOMATIC WASHER
Kenmore 11091110110 AUTOMATIC WASHER
Kenmore 11091121100 AUTOMATIC WASHER
Kenmore 11091121110 AUTOMATIC WASHER
Kenmore 11091210100 AUTOMATIC WASHER
Kenmore 11091220100 AUTOMATIC WASHER
Kenmore 11091250100 AUTOMATIC WASHER
Kenmore 11091263100 AUTOMATIC WASHER
Kenmore 11091263600 AUTOMATIC WASHER
Kenmore 11091263800 AUTOMATIC WASHER
Kenmore 11091264100 AUTOMATIC WASHER
Kenmore 11091264600 AUTOMATIC WASHER
Kenmore 11091264800 AUTOMATIC WASHER
Kenmore 11091278100 AUTOMATIC WASHER
Kenmore 11091278600 AUTOMATIC WASHER
Kenmore 11091278800 AUTOMATIC WASHER
Kenmore 11091320100 AUTOMATIC WASHER
Kenmore 11091468100 AUTOMATIC WASHER
Kenmore 11091468600 AUTOMATIC WASHER
Kenmore 11091468800 AUTOMATIC WASHER
Kenmore 11091510100 WASHER
Sears 11091510110 WASHER
Kenmore 11091511100 WASHER
Sears 11091511110 WASHER
Sears 11091512200 WASHER
Kenmore 11091512210 WASHER
Kenmore 11091520100 WASHER
Sears 11091520110 WASHER
Sears 11091521200 WASHER
  #2 (permalink)
Old 12-01-2010, 08:56 PM
Junior Member
Default Additional information
When I checked the fuses, I checked for continuity not resistance.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
HOT POINT DRYER has power but start button doesn't start the dryer. HOT POINT Dryer Repair 2 08-01-2011 06:47 PM
Dryer will not start - will power up, but when push the start button, will not start perduena Dryer Repair 0 07-12-2010 07:14 PM
dryer start button flashing and not clicking to start dryer lawfamily Dryer Repair 0 06-21-2010 07:43 PM
whirlpol dryer won't start-just hums when I push the start button bdubois Dryer Repair 27 02-18-2010 07:36 PM
Kenmore Dryer won't start unless PTS (push to start) button depressed and held trp Dryer Repair 1 06-07-2009 06:13 AM
