| » Elec dryer, low heat, moisture monitor reads low moisture |
Model Number: MDE3000AYW Brand: Maytag Age: More than 10 years
Dryer now takes 1 1/2 hrs to dry even a small load. I was in the dryer a few months back to replace bushings & belts. I thoroughly cleaned the insides & the vent is blowing out fine. This started a couple of days ago. Like I said low heat only, so it takes 2 cycles to dry. Timer cycles fine and shuts itself off but the moisture monitor only sees low moisture so maybe the monitor circuit is not letting the heater go full blast on wet clothes.
Is this a moisture monitor problem or a heating element problem? Ads By Google Related Models |
Could be either.
This should help you figure out which it is http://www.servicematters.com/maytag...s/16023110.pdf See page 3-2 Could be the sensor bar has an open connection so the unit thinks the clothes are dry.
__________________
The "sensor bar" is just a pair of contacts. Unless there is a major break in one of them, or, perhaps, a wire disconnected underneath, they rarely fail. They may be coated with an insulating residue, especially if you are using a liquid softener. You can clean them by wiping them with an alcohol moistened cloth. I would check the sensor circuit board for good connections, before determining to replace it.
| Display Modes | |
| Dryer moisture sensor question | redsuspender | Dryer Repair | 1 | 02-26-2010 02:23 AM |
| Kemmore Gas Dryer moisture sensor | c_cain | Dryer Repair | 3 | 12-07-2009 02:08 PM |
| How is the dryer moisture sensor removed? | jbrepair | Dryer Repair | 0 | 12-02-2009 07:51 PM |
| Moisture Sensor not turning off dryer | Jim Hooper | Dryer Repair | 0 | 03-27-2009 08:08 AM |
| moisture sensor will not shut off dryer | kenneth222 | Dryer Repair | 15 | 09-11-2008 02:58 PM |
