johnp
#1 Posted : Saturday, November 15, 2008 4:08:57 AM(UTC)
johnp
My dryer is not getting hot. I can't figure out where to look for the problem because when I open it up I don't know what I'm lookig at. Is it possible to find a diagram of what to look for? Any help is appreciated.
v2k04
#2 Posted : Saturday, November 15, 2008 4:20:52 AM(UTC)
v2k04
Do you have a meter?
johnp
#3 Posted : Saturday, November 15, 2008 4:26:46 AM(UTC)
johnp
No I don't have a meter, but will get one ,
My problem is that I don't know what I am looking at or what to test without a diagram.
johnp
#4 Posted : Saturday, November 15, 2008 4:27:58 AM(UTC)
johnp
No but will get one . But i still don't know what i am lookig at without a diagram
v2k04
#5 Posted : Saturday, November 15, 2008 4:41:15 AM(UTC)
v2k04
We will show you if ya want to learn I look for the easiest thing first. that woulkd be all the thermastats you ohm them all out if you find one open you replace it. or you can remove the wires off each thremastst one by one and black tape them to gether and plug it in and try it if it heats you knoiw that stat is bad the thermastats have 2 wires going to each one one on each side of stat thats the two you join together a thermastat is just a switch like a light switch on the wall when you turn it on its closed when you turn it off its open
Kenmore gas dryer model 110.96742701 (Dryer Repair)
by Guest 2/8/2024 9:07:42 AM(UTC)
Kenmore gas dryer overheating and shutting down in permanent press setting (Dryer Repair)
by Actonite 8/14/2022 4:57:32 PM(UTC)
Kenmore Gas Dryer wont stay hot (Dryer Repair)
by johnmeyers 2/12/2021 2:05:37 PM(UTC)
Kenmore Gas Dryer - No Heat (Dryer Repair)
by smackover 10/6/2018 5:55:17 PM(UTC)
Kenmore Gas Dryer Timer (Dryer Repair)
by keepitfromthedump 5/24/2017 2:18:27 PM(UTC)
Kenmore gas dryer won' dry clothes all the way (Dryer Repair)
by ggarnett 1/2/2017 7:51:16 AM(UTC)
Kenmore Gas dryer wnot heat (Dryer Repair)
by wardm6 7/9/2016 11:30:51 AM(UTC)
kenmore gas dryer runs only when push to start is pressed in (Dryer Repair)
by carlosjbb 12/12/2015 11:34:10 PM(UTC)
Kenmore gas dryer heats intermittently (Dryer Repair)
by Nordillaca 12/12/2015 7:33:46 AM(UTC)
Kenmore Gas Dryer intermittent (Dryer Repair)
by diyeng 2/24/2014 10:01:39 AM(UTC)
Kenmore Gas Dryer won't Heat (Dryer Repair)
by rboysen 2/5/2014 5:57:38 AM(UTC)
electrolux/kenmore gas dryer fault (Dryer Repair)
by iclad 1/28/2014 12:53:59 PM(UTC)
No heat - Kenmore gas dryer (Dryer Repair)
by Brian Effinger 11/7/2013 1:11:12 PM(UTC)
Kenmore Gas dryer, no heat control (Dryer Repair)
by iowacows 8/13/2013 4:18:50 PM(UTC)
Kenmore Gas Dryer/no heat (Dryer Repair)
by Padadx2 4/20/2013 7:23:40 AM(UTC)
