| » FYI Maytag Belt Diaagram |
Model Number: SDE515DAYW Brand: Maytag Age: 5 - 10 years
I just got done repairing my dryer. Replaced the 2 drum rollers,idler wheel and belt.I downloaded the belt diagram to route the belt,but it doesn`t apply to my model SDE515DAYW..The motor drive shaft is bellow the idler wheel which make it imposible to route to belt around the drum with the ribs facing away from the drum.
I do not know what belt routing diagram you downloaded so here are a couple that may help
Dryer Belt Diagrams http://www.applianceaid.com/images/belt-config.JPG As far as I know the ribs should face the drum and the idler wheel rides on the flat side.
__________________
Dryer Belt Diagrams
The diagram I downloaded is from the frist page and it says the ribs should face away from the drum.The way my motor shaft and idler wheel are configured I found it imposible to do this. |
After a lot of searching I did find the following perhaps it will help
http://appliancedigest.com/index.php...service-manual You may have to join the site to download the manual but it is a good site for appliance info. It may help you visualize how the belt should go on if you apply pressure to the idler wheel stretching the spring. This is where the idler should sit once the belt is installed.
__________________
| Display Modes | |
| Second Belt for Maytag DG482 Gas Dryer | rozy | Dryer Repair | 1 | 01-09-2013 06:40 PM |
| Maytag Belt Replacement | Techdad1954 | Washer Repair | 1 | 03-06-2010 01:35 PM |
| replace belt on maytag dryer | 8561mid | Dryer Repair | 1 | 10-24-2009 04:39 PM |
| Maytag washer belt | phunapts | Washer Repair | 1 | 05-24-2009 02:26 PM |
| Maytag washer belt/pump | dpm6264 | Washer Repair | 1 | 11-03-2007 09:05 AM |
