Discuss
No Dryer Heat
 in
Dryer Repair
When my dryer starts up the heat comes on. After less than a minute the heat shuts off. I have
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » No Dryer Heat
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 10-06-2007, 06:06 AM
jackd3 jackd3 is offline
Junior Member
jackd3 is on a distinguished road
Default No Dryer Heat
Model Number: LGR5635LQ0   Brand: Whirlpool   Age: 1 - 5 years
When my dryer starts up the heat comes on. After less than a minute the heat shuts off. I have checked all the venting, everything is clear. What could be causing the heat to shut off?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-06-2007, 08:11 AM
Pegi's Avatar
Pegi Pegi is offline
Senior Expert
APP Volunteer
Pegi is on a distinguished road
Arrow
Does it relight every time after it shuts off? If so sounds like something is causing the burner to shut off on the hi-limit safety, see if the flame is lifting up tripping this safety thermostat...blocked air flow can cause this or a draft coming in from the dryer vent....can be other causes but check this first...
__________________
-Serving North Central Texas and Southern Oklahoma since 1978.
www.samsservicesenter.com
  #3 (permalink)
Old 10-06-2007, 12:32 PM
Junior Member
Default
No it will not relight after it goes out. If I open the door, wait about a minute and restart, it will reignite and then shut off again.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Gas Dryer no Heat KrazyK55 Dryer Repair 6 01-15-2008 01:22 PM
dryer will not heat? radio963 Dryer Repair 1 11-09-2007 09:02 AM
gas dryer with no heat lz7274 Dryer Repair 1 08-22-2007 04:02 PM
Dryer won't heat dwh Dryer Repair 1 07-30-2007 05:35 PM
dryer heat karen Dryer Repair 0 07-23-2007 12:55 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
