markcon
#1 Posted : Friday, November 26, 2010 3:56:20 PM(UTC)
markcon
tco is open but my digital meter only has kohms and also contuity test er/beep. where it should read 0 it reads.02
(200)across hlt and cycling therm but should read 7ohm across thermostat/preheat it read 3.6(3600)ohm thermal fuse is fine and heater element read10 ohms- thoe parts bad?? also cant figure out if have heater relay-only see sw in diagram(tco-hlt-cycling therm-thermostat all bad)?
update-i crossed leads .2 is normal and i didnt notice the k was gone-- so only thing that needs to be answered is 3.5 ohms on thermostat to low should be 7 right
#2 Posted : Sunday, November 28, 2010 2:32:00 AM(UTC)
Sorry but I could not understand your post.
Perhaps if you post the meter's make and model number I can find it online and help.
Since you have what looks like a significant zero offset I would replace the battery in the meter. Depends if the meter has a low battery indicator.
Here is a bit about meter usage
Inglis Dryer - Works but No Heat (Dryer Repair)
by Ransom 11/3/2014 2:38:44 PM(UTC)
All works but no heating happening (Microwave Repair)
by meandmyguitar@socal.rr.co 12/26/2012 9:39:26 AM(UTC)
Maytag dryer heating element works but no heat in drum (Dryer Repair)
by toc 1/4/2012 5:02:40 AM(UTC)
whirlpool duet electric dryer works but no heat (Dryer Repair)
by sbfire370 4/13/2011 3:24:11 AM(UTC)
GE microwave everything works but no heat has buzzing sound (Microwave Repair)
by rogemari 3/16/2010 5:42:36 PM(UTC)
Display works but no heat (Oven Repair (including Ranges and Cooktops))
by d3wd 11/11/2009 2:17:40 PM(UTC)
by kevin71 9/17/2009 3:01:03 PM(UTC)
Dryer Works But No Heat (Dryer Repair)
by BIL LOGSDON 6/28/2009 7:57:01 PM(UTC)
dryer works but no heat coming out (Dryer Repair)
by villanuevanc 3/15/2009 9:33:01 PM(UTC)
kenmore dryer works but no heat (Dryer Repair)
by RichS 2/12/2008 1:57:00 PM(UTC)
gas dryer works but no heat (Dryer Repair)
by johnfox 1/22/2008 2:48:22 PM(UTC)
Frigidaire Gas Dryer works but No Heat, Why?? (Dryer Repair)
by mvetri 11/2/2007 1:28:35 PM(UTC)
