Amy hodge
#1 Posted : Thursday, November 13, 2008 1:22:44 PM(UTC)
Amy hodge
Just installed a used gas dryer / with limited us/. I got it working for about 2-3 weeks and it was great. But It only seemed to work on the more dry less dry cycle. Then just like my old dryer it would tumbling but not heating. No glow, no heat, no drying. I just purchased the gas valves and dryer ignitor and installed them and nothing different. Please give me an idea of what to do next!!!
#2 Posted : Thursday, November 13, 2008 4:45:56 PM(UTC)
Check the thermal fuse (#2 on the break down diagram) and replace if it's open.
Make sure the exhaust line is not clogged all the way to the outlet. Check the blower wheel.
Here are the break down diagrams for the Maytag dryer Model LDG7500AAW
Amy hodge
#3 Posted : Friday, November 14, 2008 7:03:31 AM(UTC)
Amy hodge
Thank you I have two parts that are/were connected to the cylinder around where the flame goes one being a part i can locate (6 3033950) but the other is a square part that says therm-o-disc on it with numbers on the side of 43812 L9535
63-5013
underneath the bracket that holds it on is a open rectangle window which the strip in it looks burn to black color. Is this a part that i should replace also? But I cannt find anything that even half way resembles the part I have. Thanks Amy
#4 Posted : Friday, November 14, 2008 11:21:56 AM(UTC)
Hopefully this Service manual will help you to diagnose and fix the problem.
1998 Maytag Gas Dryer Drum Issue Has Me Stumped (Dryer Repair)
by semaas Yesterday at 9:44:18 PM(UTC)
Whirlpool gas dryer model WGD8300SW2 (Dryer Repair)
by Guest 4/20/2024 7:14:50 AM(UTC)
Kenmore Gas Dryer Running Hot (Dryer Repair)
by Guest 3/30/2024 6:24:53 AM(UTC)
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
Kenmore gas dryer model 110.96742701 (Dryer Repair)
by Guest 2/8/2024 9:07:42 AM(UTC)
Maytag MDG8400AWW gas dryer not drying clothes (Dryer Repair)
by tvr4 12/31/2023 2:45:43 PM(UTC)
Samsung Gas Dryer - Model DVG50M7450* (Dishwasher Repair)
by Carl B 10/26/2023 2:05:00 PM(UTC)
Alternate T-stat for Speed Queen gas dryer (Dryer Repair)
by Guest 10/14/2023 12:59:47 PM(UTC)
Maytag gas dryer problem with model MDG5500AWW (Dryer Repair)
by Guest 4/15/2023 1:25:03 PM(UTC)
Drum repair of old Speed Queen gas dryer (Dryer Repair)
by Guest 3/13/2023 7:58:37 AM(UTC)
DLGX8001W gas dryer clicks on control board but wont start (Dryer Repair)
by Guest 3/12/2023 10:17:53 AM(UTC)
Knocking noise from my ge gas dryer. (Dryer Repair)
by Lougaal 2/16/2023 9:40:08 AM(UTC)
Gas Dryer turns off early (Dryer Repair)
by giorfido 12/31/2022 8:36:38 AM(UTC)
New Kenmore Elite 796 Gas Dryer Won't Heat (Dryer Repair)
by Guest 12/26/2022 1:54:20 PM(UTC)
Brand New LG gas dryer , GAS code, no heat (Dryer Repair)
by lglad 11/24/2022 7:24:02 PM(UTC)
