Discuss
dryer squealing
 in
Dryer Repair
Our dryer was making a squealing sound that has now turned into a grinding sound. What could this be and
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » dryer squealing
  #1 (permalink)
Old 11-11-2008, 08:58 AM
mommykite mommykite is offline
Junior Member
mommykite is on a distinguished road
Default dryer squealing
Model Number: DEIFWO   Brand: Frigidaire   Age: More than 10 years
Our dryer was making a squealing sound that has now turned into a grinding sound. What could this be and how do we get to the parts that need to be replaced?
Related Models
Frigidaire DEILL1 Frg(v2) / 27 " Electric Dryer
Frigidaire DEILL2 Frg(v1) / 27 " Electric Dryer
Frigidaire DEILL3 Frg(v2) / 27 " Electric Dryer
Frigidaire DEILL4 Frg(v2) / 27 " Electric Dryer
Frigidaire DEILL5 Wwh(v2) / 27 " Electric Dryer
Frigidaire DEILW1 Frg(v1) / 27 " Electric Dryer
Frigidaire DEILW2 Frg(v1) / 27 " Electric Dryer
Frigidaire DEILW3 Frg(v1) / 27 " Electric Dryer
Frigidaire DEILW4 Frg(v1) / 27 " Electric Dryer
Frigidaire DEILW5 Frg(v1) / 27 " Electric Dryer
Frigidaire DEISFL0 Frg(v4) / Electric Dryer
Frigidaire DEISFL1 Frg(v4) / 27 " Electric Dryer
Frigidaire DEISFL2 Frg(v2) / 27 " Electric Dryer
Frigidaire DEISFL3 Frg(v4) / 27 " Electric Dryer
Frigidaire DEISFL4 Frg(v4) / 27 " Electric Dryer
Frigidaire DEISFL5 Frg(v4) / 27 " Electric Dryer
Frigidaire DEISFW0 Frg(v3) / Electric Dryer
Frigidaire DEISFW1 Frg(v3) / 27 " Electric Dryer
Frigidaire DEISFW2 Frg(v2) / 27 " Electric Dryer
Frigidaire DEISFW3 Frg(v3) / 27 " Electric Dryer
Frigidaire DEISFW4 Frg(v3) / 27 " Electric Dryer
Frigidaire DEISFW5 Frg(v3) / 27 " Electric Dryer
Norge DEJ20800 Dryer - Ele
Norge DEJ20824 Dryer - Ele
Norge DEJ20825 Dryer - Ele
Norge DEJ208A Dryer - Ele
Norge DEJ208H Dryer - Ele
Norge DEJ208W Dryer - Ele
Norge DEJ25400 Dryer - Ele
Norge DEJ25424 Dryer - Ele
Norge DEJ25425 Dryer - Ele
Norge DEJ25426 Dryer - Ele
Norge DEJ25427 Dryer - Ele
Norge DEJ254A Dryer - Ele
Norge DEJ254H Dryer - Ele
Norge DEJ254W Dryer - Ele
Norge DEJ26400 Dryer - Ele
Norge DEJ26424 Dryer - Ele
Norge DEJ26425 Dryer - Ele
Norge DEJ26426 Dryer - Ele
Norge DEJ26427 Dryer - Ele
Norge DEJ264A Dryer - Ele
Norge DEJ264H Dryer - Ele
Norge DEJ264W Dryer - Ele
Norge DEK201AC Dryer - Ele
Norge DEK201WC Dryer - Ele
Norge DEK204AC Dryer - Ele
Norge DEK204HC Dryer - Ele
Norge DEK204WC Dryer - Ele
Menu Master DEL10D  Commercial Microwaves
Menu Master DEL10E  Commercial Microwaves
Norge DEL202A Dryer - Ele
Norge DEL202C Dryer - Ele
Norge DEL202H Dryer - Ele
Norge DEL202W Dryer - Ele
Norge DEL202WC Dryer - Ele
Norge DEL203 Dryer - Ele
Norge DEL203A Dryer - Ele
Norge DEL203AC Dryer - Ele
Norge DEL203H Dryer - Ele
Norge DEL203HC Dryer - Ele
Norge DEL203W Dryer - Ele
Norge DEL203WC Dryer - Ele
Norge DEL204A Dryer - Ele
Norge DEL204H Dryer - Ele
Norge DEL204W Dryer - Ele
Norge DEL253A Dryer - Ele
Norge DEL253H Dryer - Ele
Norge DEL253W Dryer - Ele
Norge DEL263A Dryer - Ele
Norge DEL263H Dryer - Ele
Norge DEL263W Dryer - Ele
Norge DEM202A Dryer - Ele
Norge DEM202AC Dryer - Ele
Norge DEM202H Dryer - Ele
Norge DEM202HC Dryer - Ele
Norge DEM202W Dryer - Ele
Norge DEM202WC Dryer - Ele
Norge DEM204 Dryer - Ele
Norge DEM204 REV A Dryer - Ele
Norge DEM204 REV B Dryer - Ele
Norge DEM204 REV C Dryer - Ele
Norge DEM204A Dryer - Ele
Norge DEM204AC Dryer - Ele
Norge DEM204H Dryer - Ele
Norge DEM204HC Dryer - Ele
Norge DEM204W Dryer - Ele
Norge DEM204WC Dryer - Ele
Norge DEM205A Dryer - Ele
Norge DEM205AC Dryer - Ele
Norge DEM205H Dryer - Ele
Norge DEM205W Dryer - Ele
Norge DEM205WC Dryer - Ele
Norge DEN202A Dryer - Ele
Norge DEN202AC Dryer - Ele
Norge DEN202W Dryer - Ele
Norge DEN202WC Dryer - Ele
Norge DEN203A Dryer - Ele
Norge DEN203AC Dryer - Ele
Norge DEN203W Dryer - Ele
Norge DEN203WC Dryer - Ele
Norge DEN204A Dryer - Ele
Norge DEN204GV Dryer - Ele
Norge DEN204KA Dryer - Ele
Norge DEN204KV Dryer - Ele
Norge DEN204KW Dryer - Ele
Norge DEN204V Dryer - Ele
Norge DEN204VC Dryer - Ele
Norge DEN204W Dryer - Ele
Norge DEP222VC Dryer - Ele
Norge DEP223M Dryer - Ele
Norge DEP223V Dryer - Ele
Norge DEP224M Dryer - Ele
Norge DEP224MC Dryer - Ele
Norge DEP224V Dryer - Ele
Norge DEP224VC Dryer - Ele
Frigidaire DES100CD1 Kel(v2) / Electric Dryer
Frigidaire DES100CW1 Kel(v1) / Electric Dryer
Frigidaire DES100FD2 Kel(v2) / 27 " Dryer
Frigidaire DES100FW2 Kel(v1) / 27 " Dryer
  #2 (permalink)
Old 11-11-2008, 09:23 AM
v2k04 v2k04 is offline
Senior Expert
APP Volunteer
v2k04 is on a distinguished road
Default
you're gonna need a new rear bearing
__________________
  #3 (permalink)
Old 11-11-2008, 09:25 AM
Junior Member
Default
How do we get to the bearing? From the back of the dryer or the front?
  #4 (permalink)
Old 11-11-2008, 10:10 AM
Senior Expert
APP Volunteer
Default
From the front Release the clips on top with a putty knife then remove inside screws holding front panel on then set panel aside release the belt, grab hold of belt still around drum and pull up it may be hard cuz it's so worn. Then install new bearing on drum pre thread holes on bearing use a 5/16 hex self tapping screw then use phillips they suppy after the hole is tapped then put plastic bearing in rear grease it good save grease for later. reinstall drum assemble in reverse order then once a year grease the rear bearing if you do that it will last a long time. There is also a steel ball bearing in the plastic holder watch how it comes out you need that to keep static electricity down. The part number you need is frigidaire 5303281153 This site can cross it over to thier part number
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
squealing when dryer is on geomaciii Dryer Repair 1 10-12-2008 11:55 AM
Frigidaire squealing CJ51974 Dryer Repair 2 04-23-2008 03:18 PM
Admiral Dryer squealing tferg24 Dryer Repair 1 03-25-2008 12:58 PM
Drayer Squealing gary.carlisle@ge.com Dryer Repair 1 02-18-2008 09:48 PM
Squealing noise from Signature 2000 electric dryer saumila Dryer Repair 1 02-14-2008 04:57 PM
