Discuss
Kenmore Dryer - Timer not moving with No heat and dryer does not shut off
 in
Dryer Repair
My Kenmore Dryer of about 5 years, model 110.C66532500 29" cabinet is not functional. I noted that the timer is
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore Dryer - Timer not moving with No heat and dryer does not shut off
  #1 (permalink)
Old 11-21-2010, 05:18 PM
Junior Member
poslow is on a distinguished road
Default Kenmore Dryer - Timer not moving with No heat and dryer does not shut off
Model Number: 110.C66532500   Brand: Kenmore   Age: 5 - 10 years
I noted that the timer is not moving with no heat coming out and the dryer does not shut off.
I have gone on to search the forum.
Could it be the problem of the timer ?
Ads By Google
Related Models
Hoover 1100
Magic Chef 1100PAA Range - F/s Std Gas
Magic Chef 1100PAW Range - F/s Std Gas
Magic Chef 1100PAW-K Range - F/s Std Gas
Magic Chef 1100PAW-KL Range - F/s Std Gas
Magic Chef 1100PAW-L Range - F/s Std Gas
Magic Chef 1100PRA Range - F/s Std Gas
Magic Chef 1100PRA-K Range - F/s Std Gas
Magic Chef 1100PRW Range - F/s Std Gas
Magic Chef 1100PRW-K Range - F/s Std Gas
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Sears 11016502693 AUTOMATIC WASHER
Sears 11016502694 AUTOMATIC WASHER
Sears 11016512691 AUTOMATIC WASHER
Sears 11016512692 AUTOMATIC WASHER
Sears 11016602690 AUTOMATIC WASHER
Sears 11016602691 AUTOMATIC WASHER
Sears 11016602692 AUTOMATIC WASHER
Sears 11016602693 AUTOMATIC WASHER
Sears 11016611690 AUTOMATIC WASHER
Sears 11016611691 AUTOMATIC WASHER
Sears 11016611692 AUTOMATIC WASHER
Sears 11016612690 AUTOMATIC WASHER
Sears 11016612691 AUTOMATIC WASHER
Sears 11016612692 AUTOMATIC WASHER
Sears 11016872691 AUTOMATIC WASHER
Sears 11016872692 AUTOMATIC WASHER
Sears 11016872693 AUTOMATIC WASHER
Sears 11018542890 AUTOMATIC WASHER
Hoover 1102
Kenmore 11020052994 WASHER
Kenmore 11020056991 WASHER
Kenmore 11020056992 WASHER
Kenmore 11020056994 WASHER
Kenmore 11020072990 WASHER
Kenmore 11020072991 WASHER
Kenmore 11020072992 WASHER
Kenmore 11020072993 WASHER
Kenmore 11020092990 WASHER
Kenmore 11020092991 WASHER
Kenmore 11020092992 WASHER
Kenmore 11020092993 WASHER
Kenmore 11020094992 WASHER
Kenmore 11020094993 WASHER
Kenmore 11020096990 WASHER
Kenmore 11020096991 WASHER
Kenmore 11020096992 WASHER
Kenmore 11020096993 WASHER
Kenmore 11020097990 WASHER
Kenmore 11020097991 WASHER
Kenmore 11020097992 WASHER
Kenmore 11021062000 AUTOMACTIC WASHER, COMPACT A/W
Kenmore 11021062001 WASHER
Kenmore 11021064000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021064001 WASHER
Kenmore 11021066000 AUTOMACTIC WASHER, COMPACT A/W
Kenmore 11021066001 WASHER
Kenmore 11021082000 WASHER
Kenmore 11021082001 WASHER
Kenmore 11021084000 WASHER
Kenmore 11021084001 WASHER
Kenmore 11021086000 WASHER
Kenmore 11021086001 WASHER
Kenmore 11021882000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021882001 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021884000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021884001 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021892000 WASHER
Kenmore 11021894000 WASHER
Kenmore 11022032100 WASHER
Kenmore 11022032101 WASHER
Kenmore 11022032102 AUTOMATIC WASHER
Kenmore 11022036100 WASHER
Kenmore 11022036101 WASHER
Kenmore 11022036102 AUTOMATIC WASHER
Kenmore 11022042100 WASHER
Kenmore 11022042101 WASHER
Kenmore 11022042102 AUTOMATIC
Kenmore 11022052100 WASHER
Kenmore 11022052101 WASHER
Kenmore 11022052102 AUTOMATIC WASHER
Kenmore 11022054100 WASHER
Kenmore 11022054101 WASHER
Kenmore 11022054102 AUTOMATIC WASHER
Kenmore 11022056100 WASHER
Kenmore 11022056101 WASHER
Kenmore 11022056102 AUTOMATIC WASHER
Kenmore 11022062100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022062101 WASHER
Kenmore 11022062102 AUTOMATIC WASHER
Kenmore 11022064100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022064101 WASHER
Kenmore 11022064102 AUTOMATIC WASHER
Kenmore 11022066100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022066101 WASHER
Kenmore 11022066102 AUTOMATIC WASHER
Kenmore 11022082100 WASHER
Kenmore 11022082101 AUTOMATIC WASHER
Kenmore 11022082102 AUTOMATIC
Kenmore 11022084100 WASHER
Kenmore 11022084101 AUTOMATIC WASHER
Kenmore 11022084102 AUTOMATIC
Kenmore 11022086100 WASHER
Kenmore 11022086101 AUTOMATIC WASHER
Kenmore 11022086102 AUTOMATIC
Kenmore 11022292100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022294100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022422100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022432100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022442100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022622100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022632100 WASHER
Kenmore 11022642100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022652100 COMPACT WASHER
Kenmore 11022662100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022692100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022692101 AUTOMATIC WASHER
Kenmore 11023012100 AUTOMATIC WASHER
Kenmore 11023012101 AUTOMATIC WASHER
  #2 (permalink)
Old 11-21-2010, 07:35 PM
Junior Member
Default
Could it be the problem of the timer ?[/quote]
I stripped off the back of the dryer, went through the forum's posting carefully. I took out the Dryer Heating Element and found a break in the coil.
The part number of this Dryer Heater Element is :-
Whirlpool Electric Dryer Heating Element 279838.
I think this could be the problem ???
  #3 (permalink)
Old 11-21-2010, 10:10 PM
Senior Expert
APP Volunteer
denman is just really nice
Default
Yes that is probably your problem.
In many units when in an auto mode the timer motor gets power through the heating coil when the coil is off.
Therefore a bad (open) heating coil will stop the timer advancing.
Note: In a timed dry mode the timer motor usually gets power directly from the line so it should have advanced in timed dry.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore electric dryer - no heat and does not shut off Tumbleweed Dryer Repair 6 05-06-2010 10:08 AM
Kenmore Dryer Timer not advancing in Auto Dry or Timer Mode but it does heat and dry dspeidel Dryer Repair 6 08-25-2009 02:23 PM
Whirlpool dryer no heat & timer wont shut off lsaustin Dryer Repair 1 06-20-2009 10:47 AM
Dryer won't heat and timer knob not moving Calicia Dryer Repair 4 03-30-2009 05:12 PM
electric dryer won't heat and timer not moving chefbeav Dryer Repair 1 12-27-2007 02:18 PM
