Discuss
Dryer heats, but won't start up, makes "ugggggh" noise..
 in
Dryer Repair
I bought a dryer used. It has always dried less and less as we have used it. When I say
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer heats, but won't start up, makes "ugggggh" noise..
  #1 (permalink)
Old 11-21-2010, 03:42 PM
Junior Member
chauncy is on a distinguished road
Question Dryer heats, but won't start up, makes "ugggggh" noise..
Model Number: LTE6234D80   Brand: Whirlpool   Age: 5 - 10 years
I bought a dryer used. It has always dried less and less as we have used it. When I say it dries less and less, its not a heat problem but the amount of time it dries for. You put it on any setting and it will dry for like 10-15 minutes and then just turn off.
Fast forward to today; it barely turns on at all anymore. You press the on switch and occasionally it will turn on and dry for 10-15 minutes and then turns off. When you try to turn it back on again, it won't start up, it just makes a "Uggghhhhhh" sounds and if you hold it long enough, it just clicks and then won't do anything. 20 minutes later it will let you try again but it will repeat the "Uggghhh" sound and problem. Maybe 2-3 days later it will start up for 10-15 minutes and then repeat.
I have tested every fuse in this machine and they are all working.
I also turned the motor manually with my hand and it turns fine and the belt looks great too.
A local appliance repair place said they think its the motor. What do you guys think? I was about to order a motor but wanted a second opinion.
Motor Part Number: 3395655
Motor Model Number: S58NXMLF-6700
*NOTE* This washer and dryer is a stacked all in one unit, if that matters.
Help is of course MUCH appreciated. Thanks in advance guys.
Related Models
Whirlpool LTE6234DQ0
Whirlpool LTE6234DQ1 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DQ2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DQ3 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DQ4 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DQ5 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DQ6 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DT2 LAUNDRY CENTER
Whirlpool LTE6234DT3 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DT4 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DT5 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DT6 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DZ0
Whirlpool LTE6234DZ1 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DZ2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6243AN2 LAUNDRY CENTER
Whirlpool LTE6243AW2 LAUNDRY CENTER
Whirlpool LTE7245AN0 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE7245AW0 WASHER/DRYER LAUNDRY SYSTEM
Frigidaire LTF1670DS0 Frigidaire/washer
Admiral LTF1812ARB REF - TOP MOUNT
Admiral LTF1812ARW REF - TOP MOUNT
Admiral LTF1812ARZ REF - TOP MOUNT
Admiral LTF2112ARB REF - TOP MOUNT
Admiral LTF2112ARW REF - TOP MOUNT
Admiral LTF2112ARZ REF - TOP MOUNT
Frigidaire LTF2140ES0 Frigidaire/washer
Frigidaire LTF2140ES1 Frigidaire/washer
Frigidaire LTF2140ES2 Frigidaire/washer
Frigidaire LTF2140ES3 Frigidaire/washer
Frigidaire LTF2140FS0 Frigidaire/washer
Frigidaire LTF2140FS1 WASHER
Frigidaire LTF2140FS2 WASHER
Frigidaire LTF2940EE0 Frigidaire/washer
Frigidaire LTF2940ES0 Frigidaire/washer
Frigidaire LTF2940ES1 Frigidaire/washer
Frigidaire LTF2940ES2 Frigidaire/washer
Frigidaire LTF2940ES3 Frigidaire/washer
Frigidaire LTF2940FE0 Frigidaire/washer
Frigidaire LTF2940FE1 WASHER
Frigidaire LTF2940FS1 WASHER
Frigidaire LTF530DS0 Frigidaire/washer
Frigidaire LTF530DS1 Frigidaire/washer
Frigidaire LTF530FS0 Frigidaire/washer
Frigidaire LTF530FS1 WASHER
Frigidaire LTF6000ES0 Frigidaire/washer
Frigidaire LTF6000ES1 Frigidaire/washer
Frigidaire LTF6000FS0 Frigidaire/washer
Frigidaire LTF6700FS0 WASHER
Frigidaire LTF7000EG0 Frigidaire/washer
Frigidaire LTF7000ES0 Frigidaire/washer
Frigidaire LTF7000ES1 Frigidaire/washer
Frigidaire LTF7000FG0 Frigidaire/washer
Frigidaire LTF8000FE0 WASHER
Whirlpool LTG5243BN0 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243BN1 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243BN2 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243BW0 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243BW1 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243BW2 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQ0 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQ1 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQ2 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQ3 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQ4 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQ5 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQ6 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQ7 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQ8 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQ9 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQA WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DT2 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DT3 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DT4 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DT5 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DT6 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DT7 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DT8 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DZ0 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DZ1 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DZ2 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG6234AN0 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG6234AN1 COMBINATION UNITS
Whirlpool LTG6234AN2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG6234AN3 COMBINATION UNITS
Whirlpool LTG6234AW0 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG6234AW1 COMBINATION UNITS
Whirlpool LTG6234AW2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG6234AW3 COMBINATION UNITS
Whirlpool LTG6234DQ0
Whirlpool LTG6234DQ1 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG6234DQ2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG6234DQ3 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG6234DQ4 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG6234DQ5 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG6234DT1 LAUNDRY CENTER
Whirlpool LTG6234DT2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG6234DT3 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG6234DT4 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG6234DT5 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG6234DZ0
Whirlpool LTG6234DZ1 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG7245AN0 WASHER/DRYER
Whirlpool LTG7245AW0 WASHER/DRYER
 LTM9000ST Microwave Oven
 LTM9000W Microwave Oven
 LTM9020B Microwave Oven
Whirlpool LUD2100X0 Dishwasher
Whirlpool LUD2100X1 Dishwasher
Whirlpool LUD2100X3 Dishwasher
Whirlpool LUD2100X4 Dishwasher
Whirlpool LUD2100X5 Dishwasher
Whirlpool LUD2100X6 Dishwasher
Whirlpool LUD2100X7 Dishwasher
General Electric LUD3100V57WB Dishwasher
General Electric LUD3100V60WB Dishwasher
General Electric LUD3100V64WB Dishwasher
General Electric LUD3100X66WB Dishwasher
Bosch LV010-000
General Electric LVM132K01 Counter top microwave
  #2 (permalink)
Old 11-21-2010, 10:25 PM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Here are your parts DQ6 is probably the closest to yours.
Replacement parts for LTE6234D80 models | AppliancePartsPros.com
I used your motor part number, crossed referenced is and they do match.
Part number: 3395655
Click on the picture for more info.
It also sounds like a motor to me.
You might as well check all moving parts and seals in the unit while you are at it.
It is also a good time to check/clean your vent system.
The blower wheel is a left hand thread.
Do not be surprised if you have to break it as they often seize onto the motor shaft.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
"PF" & "F-01" Errors. Won't start, all buttons lights ok sammy40 Dryer Repair 1 06-01-2010 06:05 AM
Washer makes "CLUNKING" noise after spin cycle. apetty Washer Repair 14 10-10-2009 02:42 PM
Frigidaire Ice Maker Makes a "Knocking" Noise skeezix979 Refrigerator & Freezer Repair 1 05-13-2009 05:36 PM
Ice Dispensor makes "air sucking" noise hvatcher Refrigerator & Freezer Repair 4 03-17-2009 05:55 PM
fridge sometimes makes "chugging" noise pakli Refrigerator & Freezer Repair 3 01-15-2008 03:45 AM
