Discuss
my maytag dryer heats but wont spin
 in
Dryer Repair
how can i open my dryer to find out whr the problem lies its a maytag legacy series 100 thks
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » my maytag dryer heats but wont spin
  #1 (permalink)
Old 11-10-2008, 10:59 AM
Junior Member
mksinvestors is on a distinguished road
Default my maytag dryer heats but wont spin
Brand: Maytag   Age: 1 - 5 years
  #2 (permalink)
Old 11-10-2008, 11:12 AM
Senior Expert
APP Volunteer
v2k04 is on a distinguished road
Default
We're gonna need the model number to help ya
__________________
  #3 (permalink)
Old 11-10-2008, 01:00 PM
Junior Member
Default
hello my model num is mde308dayw thk u
  #4 (permalink)
Old 11-10-2008, 01:43 PM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
Open the door. Remove the hinge screws. The door will then rock out of the hinge slots. Opposite the hinges are two plastic filler plates, shaped like triangles. Remove these by removing the screws. You may now remove the front panel by rocking it down and forward. the panel will rock off two clips at the bottom. Carefully set it aside.
Right under the top you will see two brackets, one on each side, each secured with a hex head screw (5/16 inch drive). Remove the screws. Each bracket will swivel outward; they keep the top in place. Remove them and you will be able to lift the top and gain access to the tumbler (drum).
I suspect from your description that you will find the belt is broken.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer heats but doesn't spin johnjess11 Dryer Repair 1 01-25-2010 12:19 PM
Dryer heats in auto but wont shut off CSH12H Dryer Repair 1 10-16-2009 11:51 AM
Maytag Dryer clicks, heats, won't spin JFAVA Dryer Repair 3 07-31-2009 06:07 AM
Maytag Dryer heats up but wont keep lit jefffuss Dryer Repair 1 03-18-2009 02:01 PM
Dryer heats for max. of 2 cycles then wont reignight Curt Corson Dryer Repair 8 02-18-2009 02:47 PM
