saylols
#1 Posted : Monday, November 15, 2010 11:17:50 AM(UTC)
saylols
Just stopped working. I've looked thru the forums and did what I saw on the others, However its still not working. I've gone thru my wiring and tested volts what I found is I'm only getting 110v to one side of the element, which is the main feed from the wall. The other side comes from the motor. I have 110v at the motor but not coming out. My wife wants to buy new dryer but I would like to fix it. Its not that old. Any help would be greatly appreiciated.
kayakcrzy
#2 Posted : Monday, November 15, 2010 3:07:09 PM(UTC)
kayakcrzy
There is a thermal fuse mounted on the blower housing. That will be your problem. Tom ApplianceEducator.com
saylols
#3 Posted : Monday, November 15, 2010 4:44:32 PM(UTC)
saylols
Tom,
I did a continuity check on every little 2 wire thing mounted on blower and heater housing, all test good. Am I not testing them right. I'll add this to the mix- My wife was able to get it started the other day by messing with the timer switch, however now nothing helps. Thanks
kayakcrzy
#4 Posted : Tuesday, November 16, 2010 3:46:49 AM(UTC)
kayakcrzy
Tom,
As long as you pulled one wire off of each thing you checked, you then got good readings. If it is all well, I would go with the timer, because of your wife messing with it to get it to run. I have seen that plenty of times with my customers. Tom ApplianceEducator.com
Maytag Dryer Not starting (Dryer Repair)
by icetea07 5/31/2017 12:54:26 PM(UTC)
dryer not starting (Dryer Repair)
by DConway0005 3/16/2017 3:40:22 PM(UTC)
Roper dryer not starting. (Dryer Repair)
by tekgeek 8/24/2016 7:57:05 PM(UTC)
Help! GE dryer not starting (Dryer Repair)
by lelidi 2/4/2015 9:04:46 PM(UTC)
Dryer Not Starting (Dryer Repair)
by dellarte 1/5/2015 5:03:30 AM(UTC)
Maytag Maxima dryer not starting (Dryer Repair)
by ssolle 12/29/2014 8:13:27 PM(UTC)
Dryer not starting (Dryer Repair)
by kbeealexander 6/7/2014 5:59:58 AM(UTC)
by Matt18 11/26/2013 9:56:49 AM(UTC)
by rberger3 10/23/2013 7:34:39 PM(UTC)
Kenmore dryer not starting (Dryer Repair)
by Frustratedinal 5/11/2013 6:18:59 PM(UTC)
Whirlpool Gold gas dryer not starting... (Dryer Repair)
by arvydas512 3/12/2013 10:43:01 AM(UTC)
Maytag Neptune Dryer not starting (Dryer Repair)
by buckeye597 2/17/2013 4:09:06 PM(UTC)
Estate dryer not starting (Dryer Repair)
by lmreese25 2/9/2013 8:06:34 PM(UTC)
Gibson gas dryer not starting (Dryer Repair)
by tad.m 1/31/2013 1:26:02 PM(UTC)
Need help with old Maytag dryer not starting (Dryer Repair)
by momkaren 9/7/2012 6:51:36 PM(UTC)
