Discuss
Dryer Stopped running
 in
Dryer Repair
I returned from work to find out that my dryer stopped working. The dryer stopped running in the middle of
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer Stopped running
  #1 (permalink)
Old 11-12-2010, 08:40 PM
Junior Member
Hawki39 is on a distinguished road
Question Dryer Stopped running
Model Number: PYET344AYW   Brand: Maytag   Age: 5 - 10 years
The dryer stopped running in the middle of drying a load of clothes.
No circut breakers were kicked and a friend checked the dryer and determined that there was power to the circuts but the drum light does not go on. The friend seems to think it is the timer assembly? but he cannot understand why the light won't work.
Any help would be greatly appreciated, Thanks
Butch
Ads By Google
Related Models
Maytag PYET344AYW Dryer - Ele
Maytag PYET344AZW Dryer - Ele
Maytag PYET444AYQ Dryer - Ele
Maytag PYET444AYW Dryer - Ele
Maytag PYET444AZW Dryer - Ele
Maytag PYG1000AWW Dryer - Gas
Maytag PYG2000AWW Dryer - Gas
Maytag PYG2200AWW Dryer - Gas
International PYG2300AGW Dryer - Gas
Maytag PYG2300AWW Dryer - Gas
Maytag PYG3200AWW Dryer - Gas
Maytag PYG3250AWW Dryer - Gas
Maytag PYG3300AWW Dryer - Gas
Maytag PYG3360AWW Dryer - Gas
Maytag PYG4500AWQ Dryer - Gas
Maytag PYG4500AWW Dryer - Gas
Maytag PYG4557AWW Dryer - Gas
Maytag PYG4558AWW Dryer - Gas
International PYGS244AWW Dryer - Gas
Maytag PYGT244AWW Dryer - Gas
Maytag PYGT344AWW Dryer - Gas
Maytag PYGT444AWQ Dryer - Gas
Maytag PYGT444AWW Dryer - Gas
Amana QDO-695 Range - S/c S/i Ddraft Gas
Amana QDO-695D Range - S/c S/i Ddraft Gas
Amana QDO-695E Range - S/c S/i Ddraft Gas
Amana QDO-695F Range - S/c S/i Ddraft Gas
Amana QDO-695G Range - S/c S/i Ddraft Gas
Amana QDO-695H Range - S/c S/i Ddraft Gas
Amana QDU-838 Range - S/c S/i Ddraft Gas
Amana QDU-838A Range - S/c S/i Ddraft Gas
Amana QDU-838B Range - S/c S/i Ddraft Gas
Amana QDU-838C Range - S/c S/i Ddraft Gas
Amana QDU-838D Range - S/c S/i Ddraft Gas
Amana QDU-838G Range - S/c S/i Ddraft Gas
Amana QDU-858 Range - S/c S/i Ddraft Gas
Amana QDU-858A Range - S/c S/i Ddraft Gas
Amana QDU-858B Range - S/c S/i Ddraft Gas
Amana QDU-858C Range - S/c S/i Ddraft Gas
Amana QDU-858D Range - S/c S/i Ddraft Gas
Amana QDU-858E Range - S/c S/i Ddraft Gas
Amana QDU-858G Range - S/c S/i Ddraft Gas
Amana QDU-878 Range - S/c S/i Ddraft Gas
Amana QDU-878A Range - S/c S/i Ddraft Gas
Amana QDU-878B Range - S/c S/i Ddraft Gas
Amana QDU-966 Range - S/c S/i Ddraft Gas
Amana QDU-976 Range - S/c S/i Ddraft Gas
Amana QDU-976A Range - S/c S/i Ddraft Gas
Amana QKO-661 Range - S/c S/i Ddraft Gas
Amana QKO-661B Range - S/c S/i Ddraft Gas
Amana QKO-661C Range - S/c S/i Ddraft Gas
Amana QKO-661D Range - S/c S/i Ddraft Gas
Amana QKO-661E Range - S/c S/i Ddraft Gas
Amana QKO-751 Range - S/c S/i Ddraft Gas
Amana QKO-751A Range - S/c S/i Ddraft Gas
Amana QKU-647 Range - S/c S/i Ddraft Gas
Amana QKU-647A Range - S/c S/i Ddraft Gas
Amana QMC811 Walloven - Std Mwave Ele
Amana QMD-800 Mwave - Family Size (60 Hz)
Amana QMD-800A Mwave - Family Size (60 Hz)
Amana QMD-800B Mwave - Family Size (60 Hz)
Amana QMD-800C Mwave - Family Size (60 Hz)
Amana QMD-800D Mwave - Family Size (60 Hz)
Amana QMD-800E Mwave - Family Size (60 Hz)
Amana QMD-800G Mwave - Family Size (60 Hz)
Amana QMD-810 Mwave - Family Size (60 Hz)
Amana QMD-810A Mwave - Family Size (60 Hz)
Amana QMD800 Walloven - Std Mwave Ele
Amana QMD800D Mwave - Family Size (60 Hz)
Amana QMD810 Walloven - Std Mwave Ele
Amana R-1 Range - S/c S/i Ddraft Gas
Amana R-1H Range - S/c S/i Ddraft Gas
Amana R-1J Mwave - Family Size (60 Hz)
Amana R-2 Range - S/c S/i Ddraft Gas
Amana R-3 Mwave - Family Size (60 Hz)
Amana R0-24-8 Mwave - Mounted Over Range/wo
Whirlpool R101
Whirlpool R1011
Whirlpool R1012
Whirlpool R1013
Whirlpool R1014
Whirlpool R121
Whirlpool R1211
Whirlpool R1212
Whirlpool R1213
Whirlpool R1231
Whirlpool R141A
Whirlpool R141A1
Whirlpool R141F0
Whirlpool R141G0
Amana R15 Misc / Accessory
Whirlpool R153
Amana R15A Misc / Accessory
Amana R15L Misc / Accessory
Amana R15LA Misc / Accessory
Whirlpool R183
Whirlpool R183A
Whirlpool R183A1
Whirlpool R183A2
Whirlpool R183A3
Whirlpool R183F0
Whirlpool R183G0
Whirlpool R183G1
Amana R1E Mwave - Family Size (60 Hz)
Jenn-Air R200 Surface Unit - Ddraft Ele
Frigidaire R2000DL0 Frg(v1) / Electric Range
Frigidaire R2000DW0 Frg(v2) / Electric Range
Frigidaire R2000LL1 Frg(v1) / Electric Range
Frigidaire R2000LW1 Frg(v2) / Electric Range
Jenn-Air R201 Surface Unit - Ddraft Ele
Jenn-Air R201-C Surface Unit - Ddraft Ele
Frigidaire R21CL0 Frg(v1) / Free Standing Electric Range
Frigidaire R21CL1 Frg(v1) / Free Standing Electric Range
  #2 (permalink)
Old 11-13-2010, 01:58 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Here are your parts includes a wiring diagram
Replacement parts for MAYTAG PYET344AYW Dryer - Ele | AppliancePartsPros.com
If power is good then odds are the thermal fuse is blown.
You will see that it is before the door switch in the circuit and so if it is blown the light will not work.
If it is blown you have to find out what caused it to go.
Note: that sometimes they do just blow on their own but changing it without checking other things is a gamble.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it so the thermal fuse blows.
If the above is OK then you will also have to replace the hi-limit as it should have regulated the temperature so the fuse did not blow.
You still have to find out why it blew.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it's contacts may not be opening (welded shut).
__________________
  #3 (permalink)
Old 11-13-2010, 05:04 AM
Senior Expert
APP Volunteer
kayakcrzy will become famous soon enough
Default
Butch
Very common problem. The part # is a LA-1053. It is a thermal fuse kit. Here is what you do. Get a putty knife, and slide it under the top on the right side, and pop the top up on that side, and then do the same on the other side. Then raise the top, and rest it on the back wall. Be sure the dryer is unplugged when you do this repair!!! Then up top, in the middle, you will see the heating element, and the thermostat sitting on top of it. Take the 1/4 inch screw holding the bracket of the thermostat off, and just move the thermostat out of the way, with the wires on it. Then take the 2 wires off of the heating element, and then remove the long 1/4 inch screw holding it in place. Then remove the element. Now to find the thermal fuse, follow the two white wires, and they will lead you to it, on the right side of the heating element housing. Slide you screw driver down there, and pop the bracket off, and then remove, and replace. Look at that bracket that the thermal fuse sits in, and you will see the indentation where the long 1/4 inch screw will slide in. So put the new thermal fuse in with the blue dot on it, and then put the element back in, and with your right hand, hold the bracket with the thermal fuse in place, and then put the long 1/4 inch screw, in, and it will hold the element in place, and the thermal fuse bracket. Once that is done, In the kit I told you to buy, will have the thermostat in it. Replace it, and put the bracket back on. Now, what you need to do is take the front off, because it is most likely full of lint. So, up top, on the inside of the front, on the right and left side, there is a 1/4 inch screw. Remove them both, and then lift up on the front and it will come off. Remove the door switch wires, and remember where they go, and then look on the bottom of the front, where the vent housing is, and clean out all the lint. Stick your arm up there, and get out all you can. Put it back together, and then turn it on, and make sure the vent is clear to the outside, and Happy Drying to you. What do you think, have I done a few??? LOL!!! Tom Appliance Educator, Appliance Parts, Washer and Dryer Parts, Refridgerator and Freezer Parts, Stove and Oven Parts
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer just stopped running and will not start cbailey Dryer Repair 5 06-16-2010 03:29 AM
Whirlpool Dryer - Stopped Running BCB Dryer Repair 3 09-11-2009 04:49 AM
Dryer stopped running....Please HELP!!!!! JerryB. Dryer Repair 2 08-17-2009 02:52 PM
Dryer stopped running Robin Edgar Dryer Repair 11 08-14-2009 10:55 AM
Kenmore dryer stopped running Riding Dryer Repair 1 03-31-2008 07:11 PM
