Dryer will not heat...I just replaced the ignitor and it glows and i hear a clik,but no flame...maybe need new coils or Flame sencer???
Originally Posted by: Frank33 Dryer will not heat...I just replaced the ignitor and it glows and i hear a clik,but no flame...maybe need new coils or Flame sencer??? Frank, When you hear the second click, does the igniter cycle off and start to dim ? If so, your Sensor is ok, If your sure you have gas supplied at the gas valve, you'll need a set of coils for the gas valve Part number: AP3094251
Good Luck, :cool: :cool: :cool:
Hi Joe- I only hear one click and the ignitor dims.After about a minute it lights up agian I Hear one click and it dims agian..
Originally Posted by: Frank33 Hi Joe- I only hear one click and the ignitor dims.After about a minute it lights up agian I Hear one click and it dims agian.. Frank, And you're sure you have gas supplied at the valve. Order and replace the gas valve solenoids(per the previous post). You'll be fine after that... :) :) :)
Yes gas it supplied to the dryer!! Thanks for all your help Joe!!:)
Originally Posted by: Frank33 Yes gas it supplied to the dryer!! Thanks for all your help Joe!!:) You're welcome ! Let us know how you made out, when you've got it repaired. Good Luck, :cool: :cool: :cool:
IT WORKED,IT WORKED!!!!! Thanks again JOE!!!
Originally Posted by: Frank33 IT WORKED,IT WORKED!!!!! Thanks again JOE!!! Frank, Of course it worked, You did a great job. :D :D :D
