Discuss
dryer wont start
 in
Dryer Repair
dryer wont start anymore never had any problems until now thermal fuse ohm checked out ok door switch is ok
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » dryer wont start
  #1 (permalink)
Old 10-02-2007, 10:24 PM
daniel daniel is offline
Junior Member
daniel is on a distinguished road
Default dryer wont start
Model Number: kgye800tal0   Brand: Kitchen Aid   Age: More than 10 years
dryer wont start anymore never had any problems until now thermal fuse ohm checked out ok door switch is ok start switch checked out ok really hate to throw out this dryer thing was so quiet up until yesterday now its really quiet.............could really use some help from someone thanks in advance
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-03-2007, 03:47 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
First I would check power to it, then pull off front panel and drum and check motor, pins 4&5 are the usual motor pins that get 115 volts to run. Use a cheater cord and apply 115 volts, if motor runs, you will need to check dryer for burnt wires or a bad timer, please post results.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer wont start phyllis Dryer Repair 5 10-21-2008 03:24 PM
Dryer will not start bob38 Dryer Repair 2 09-19-2007 08:59 PM
whirlpool gas dryer will not start dmicare Dryer Repair 1 09-19-2007 07:16 PM
Wont start/start switch replaced awilliams197 Dryer Repair 1 09-18-2007 02:33 AM
Dryer stopped and won't start Help4mom Dryer Repair 3 09-14-2007 03:58 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
