jbtaylor
#1 Posted : Saturday, November 6, 2010 1:22:54 PM(UTC)
jbtaylor
The motor on my dryer does not always switch from the start winding to the run winding
#2 Posted : Tuesday, November 9, 2010 6:43:26 AM(UTC)
Replacement parts for de400kdd-6 models | AppliancePartsPros.com
I do not have a wiring diagram for this unit so the following is just what is normal.
The motors usually do not switch from start to run windings.
What they do is switch out the start winding when the motor gets close to operating speed. At rest, both the start and run windings are in circuit.
The start winding is switched out because if left in circuit the motor will overheat and trip it's internal thermal protect.
The switch Normally Closed contacts open to disconnect the run winding and it's Normally Open contacts are usually wired in parallel with the start switch to keep it running after you release the start switch.
So if your symptom is that the unit runs fine as long as you hold the start switch closed then odds are the Normally Open side of the switch is toast.
If it will not keep running and you do not have heat, there is probably a problem with the mechanical device in the motor and it is not activating the switches.
With luck this may be that it is just dirty or clogged with lint.
Whirlpool impeller/motor problem? (Dishwasher Repair)
by pjmayhew 6/5/2020 7:01:54 PM(UTC)
fan motor problems (Refrigerator & Freezer Repair)
by catdaddyhale 5/15/2014 6:13:08 PM(UTC)
Evaporator Motor Problem (Refrigerator & Freezer Repair)
by Tom Hawk 10/14/2013 3:29:02 PM(UTC)
Hvac Blower motor problem (Heating, Ventilation, and Air Conditioning (HVAC))
by jaywalker1981 9/12/2013 12:51:55 AM(UTC)
Motor problem with Kenmore Fridge (Refrigerator & Freezer Repair)
by rhb2340 8/18/2013 10:48:24 AM(UTC)
motor problems (Washer Repair)
by boatlifter 8/20/2012 5:23:02 AM(UTC)
Dishwasher motor problem? (Dishwasher Repair)
by eilertsj 6/27/2012 1:15:52 PM(UTC)
Washer motor problems?Please help (Washer Repair)
by larrj2011 12/25/2011 4:24:51 PM(UTC)
Frigidaire freezer compressor fan motor problem (Refrigerator & Freezer Repair)
by wally_games 7/2/2011 10:50:03 AM(UTC)
Noisy motor problem (Refrigerator & Freezer Repair)
by KantSleep 5/16/2011 12:28:21 PM(UTC)
No wash cycle possible motor problems (Dishwasher Repair)
by stonerunner 2/3/2011 9:27:25 AM(UTC)
Maytag dyer motor problems (Dryer Repair)
by TRULUCK 11/24/2009 12:36:07 PM(UTC)
by TRULUCK 11/24/2009 9:40:02 AM(UTC)
Stove vent motor problem (Heating, Ventilation, and Air Conditioning (HVAC))
by Pack67dad 11/11/2009 2:59:27 PM(UTC)
Fridgidaire motor problems (Dishwasher Repair)
by dyebroke 9/19/2009 7:50:40 AM(UTC)
