Discuss
Motor will not turn drum(lack of power)
 in
Dryer Repair
I Havea Maytag LDE 410Dryer with a new motor, new belt & door switch. When the start button is pushed
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Motor will not turn drum(lack of power)
  #1 (permalink)
Old 11-06-2010, 12:42 AM
Junior Member
Alice Bradford is on a distinguished road
Default Motor will not turn drum(lack of power)
Model Number: Matag LDE 410   Brand: Maytag   Age: Less than 1 year
I Havea Maytag LDE 410Dryer with a new motor, new belt & door switch. When the start button is pushed the motor can not turn an empty drum. The centrifical clucth does not kick into start the drum spinning ( only if I help it spin by turning the drum from the inside ) Could it be the timer? I have checked the plug and have 240 volts and 120 volts each leg. Stumped????? When the belt is disconnected and push to start I can hold the motor shaft from spinning. Thanks
Ads By Google
Related Models
Maytag MAV1655AWW Washer - Top Loading
Maytag MAV1755AWW Washer - Top Loading
Maytag MAV208DAWW Washer - Top Loading
International MAV2200AJW Washer - Top Loading
Maytag MAV2755AJW Washer - Top Loading
Maytag MAV2755AWW Washer - Top Loading
Maytag MAV2757AWW Washer - Top Loading
Maytag MAV275SAWW Washer - Top Loading
Maytag MAV308DAWW Washer - Top Loading
International MAV3350AGW Washer - Top Loading
Maytag MAV3757AWW Washer - Top Loading
Maytag MAV3758AWW Washer - Top Loading
Maytag MAV3855AGW Washer - Top Loading
Maytag MAV3855AKW Washer - Top Loading
Maytag MAV3855AWW Washer - Top Loading
Maytag MAV385SAWW Washer - Top Loading
Maytag MAV3905AWW Washer - Top Loading
Maytag MAV3955EWW Washer - Top Loading
Maytag MAV4057AWA Washer, Atlantis
Maytag MAV4057AWQ Washer, Atlantis
Maytag MAV4057AWW Washer, Atlantis
Maytag MAV408DAWK Washer - Top Loading
Maytag MAV408DAWW Washer - Top Loading
Maytag MAV4500AWW Washer, Atlantis
Maytag MAV4755AWW Washer - Top Loading
Maytag MAV4757AWW Washer - Top Loading
Maytag MAV4758AWW Washer - Top Loading
Maytag MAV5000AWQ Washer, Atlantis
Maytag MAV5000AWW Washer, Atlantis
Maytag MAV5057AWQ Washer, Atlantis
Maytag MAV5057AWW Washer, Atlantis
Maytag MAV551EEWW Washer - Top Loading
Maytag MAV5758EWW Washer - Top Loading
Maytag MAV5920AGW Washer - Top Loading
Maytag MAV5920EWK Washer - Top Loading
Maytag MAV5920EWW Washer - Top Loading
Maytag MAV5960AWW Washer, Atlantis
Maytag MAV6000AWQ Washer, Atlantis
Maytag MAV6000AWW Washer, Atlantis
Maytag MAV6057AWQ Washer, Atlantis
Maytag MAV6057AWW Washer, Atlantis
Maytag MAV6200AWQ Washer, Atlantis
Maytag MAV6200AWW Washer, Atlantis
Maytag MAV6250AWQ Washer, Atlantis
Maytag MAV6250AWW Washer, Atlantis
Maytag MAV6257AWQ Washer, Atlantis
Maytag MAV6257AWW Washer, Atlantis
Maytag MAV6260AWW Washer, Atlantis
International MAV6300AGW Washer - Top Loading
Maytag MAV6300AWQ Washer, Atlantis
Maytag MAV6300AWW Washer, Atlantis
International MAV6300BGW Washer - Top Loading
International MAV6300CGW Washer - Top Loading
Maytag MAV6357AWW Washer, Atlantis
Maytag MAV6358AWW Washer, Atlantis
Maytag MAV6451AGW Washer, Atlantis
Maytag MAV6451AWQ Washer, Atlantis
Maytag MAV6451AWW Washer, Atlantis
Maytag MAV6457AWW Washer, Atlantis
Maytag MAV6458AWW Washer, Atlantis
Maytag MAV6548AWQ Washer, Atlantis
Maytag MAV6548AWW Washer, Atlantis
Maytag MAV6601AWQ Washer, Atlantis
Maytag MAV6601AWW Washer, Atlantis
Maytag MAV6650AWW Washer, Atlantis
Maytag MAV7000AWQ Washer, Atlantis
Maytag MAV7000AWW Washer, Atlantis
Maytag MAV7057AWQ Washer, Atlantis
Maytag MAV7057AWW Washer, Atlantis
Maytag MAV7200AWQ Washer, Atlantis
Maytag MAV7200AWW Washer, Atlantis
Maytag MAV7257AWQ Washer, Atlantis
Maytag MAV7257AWW Washer, Atlantis
Maytag MAV7258AWQ Washer, Atlantis
Maytag MAV7258AWW Washer, Atlantis
Maytag MAV7260AWW Washer, Atlantis
Maytag MAV7260BWW Washer, Atlantis
Maytag MAV7357AWQ Washer, Atlantis
Maytag MAV7357AWW Washer, Atlantis
Maytag MAV7358AWQ Washer, Atlantis
Maytag MAV7358AWW Washer, Atlantis
Maytag MAV7450AWQ Washer, Atlantis
Maytag MAV7450AWW Washer, Atlantis
Maytag MAV7501EWW Washer, Atlantis
Maytag MAV7504EWW Washer, Atlantis
Maytag MAV7550AWQ Washer, Atlantis
Maytag MAV7550AWW Washer, Atlantis
Maytag MAV7551AWQ Washer, Atlantis
Maytag MAV7551AWW Washer, Atlantis
Maytag MAV7557EWQ Washer, Atlantis
Maytag MAV7557EWW Washer, Atlantis
Maytag MAV7580EWQ Washer, Atlantis
Maytag MAV7580EWW Washer, Atlantis
International MAV7600ACQ Washer - Top Loading
International MAV7600AGW Washer - Top Loading
Maytag MAV7600AWQ Washer, Atlantis
Maytag MAV7600AWW Washer, Atlantis
International MAV7600BGW Washer - Top Loading
International MAV7600CGW Washer - Top Loading
Maytag MAV7650AWQ Washer, Atlantis
Maytag MAV7650AWW Washer, Atlantis
Maytag MAV7657EWQ Washer, Atlantis
Maytag MAV7657EWW Washer, Atlantis
Maytag MAV7700AWQ Washer, Atlantis
Maytag MAV7700AWW Washer, Atlantis
International MAV7750AGW Washer - Top Loading
International MAV7750BGW Washer - Top Loading
International MAV7750CGW Washer - Top Loading
Maytag MAV7757AWQ Washer, Atlantis
Maytag MAV7757AWW Washer, Atlantis
Maytag MAV8000AWQ Washer, Atlantis
Maytag MAV8000AWW Washer, Atlantis
Maytag MAV8057AWQ Washer, Atlantis
Maytag MAV8057AWW Washer, Atlantis
Maytag MAV8260AWQ Washer, Atlantis
Maytag MAV8260AWW Washer, Atlantis
Maytag MAV8500AWA Washer, Atlantis
Maytag MAV8500AWQ Washer, Atlantis
Maytag MAV8500AWW Washer, Atlantis
Maytag MAV8551AWQ Washer, Atlantis
  #2 (permalink)
Old 11-09-2010, 08:58 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
I am assuming that the new motor came with centrifugal switches.
There really is not a centrifugal clutch, all it does is activate the switches once the motor gets close to operating speed.
One switch supplies power to the heater, this ensures there is air flow before the heater comes on.
The other switch uses it's Normally Open and Normally Closed contacts.
At rest the Normally Closed set connects in the start and run windings, when close to operating speed, they open and the start winding is disconnected. If left in circuit it would overheat the motor.
The Normally Open contacts close when close to operating speed they are usually wired in parallel with the start switch so that you can release the start switch and the motor keeps running.
Sounds like either the motor is defective or you wired it incorrectly.
I would not hold the motor shaft when it is trying to start. it is very easy to rip your hand apart or break some bones.
There is an outside possibility that the timer contacts for the motor are so pitted/dirty that they are dropping a lot of voltage across them.
If you have 120 to the motor when it is running then that is not the case.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Refer will not turn off - motor runs until I turn down thermostat Ahhnother8 Refrigerator & Freezer Repair 3 06-17-2010 04:51 PM
drum wont turn while motor humms bobinski Dryer Repair 0 02-17-2010 09:06 PM
Motor running but drum does not turn chaz24 Dryer Repair 2 08-03-2009 07:29 PM
Motor turn but not drum jpwlch Dryer Repair 1 12-11-2008 01:28 PM
motor hums but drum will not turn judy71635@alltel.net Dryer Repair 1 07-30-2008 08:28 PM
