Discuss
No heat. Thermostat reads 3.5 ohms. Good or bad?
 in
Dryer Repair
Dryer is not putting out any heat. Tested all parts w/ digital multimeter. I unplugged the dryer & unhooked each
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » No heat. Thermostat reads 3.5 ohms. Good or bad?
  #1 (permalink)
Old 11-02-2008, 08:38 PM
Junior Member
gatorsfan is on a distinguished road
Default No heat. Thermostat reads 3.5 ohms. Good or bad?
Model Number: LE4440WW0   Brand: Whirlpool   Age: Less than 1 year
Dryer is not putting out any heat. Tested all parts w/ digital multimeter. I unplugged the dryer & unhooked each individual part as I tested. All read 0.00 Ohms except for thermostat "Section 3; part 19" - which read 3.5 ohms. The temp set switch "Section 1; Part 79" gives no reading at all on "air" setting. I suspect this may be normal, & it has nothing to do w/ no heat production problem I am having, but unsure. Any help would be greatly appreciated. Thank you.
Related Models
Whirlpool LE4440XWW0 Residential Dryer
Whirlpool LE4440XWW1 Residential Dryer
Amana LE4507L DRYER- ELE
Amana LE4507W DRYER- ELE
Amana LE4607L DRYER- ELE
Amana LE4607W DRYER- ELE
Amana LE4807L DRYER- ELE
Amana LE4807W DRYER- ELE
Whirlpool LE4900XKW0 Residential Dryer
Whirlpool LE4900XMW0 Residential Dryer
Whirlpool LE4900XMW1 Residential Dryer
Whirlpool LE4900XSW0 Residential Dryer
Whirlpool LE4900XTW0 Residential Dryer
Whirlpool LE4900XTW1 Residential Dryer
Whirlpool LE4900XTW2 Residential Dryer
Whirlpool LE4905XMW0 Residential Dryer
Whirlpool LE4905XMW1 Residential Dryer
Amana LE4907L DRYER- ELE
Amana LE4907W DRYER- ELE
Whirlpool LE4930XKW0 Residential Dryer
Whirlpool LE4930XMW0 Residential Dryer
Whirlpool LE4930XMW1 Residential Dryer
Whirlpool LE4930XSW0 Residential Dryer
Whirlpool LE4930XTW0 Residential Dryer
Whirlpool LE4930XTW1 Residential Dryer
Whirlpool LE4930XTW2 Residential Dryer
Whirlpool LE4935XMW0 Residential Dryer
Whirlpool LE4935XMW1 Residential Dryer
Whirlpool LE5200XTW0 Residential Dryer
Whirlpool LE5200XTW1 Residential Dryer
Whirlpool LE5320XTW0 Residential Dryer
Whirlpool LE5530XKW0 Residential Dryer
Whirlpool LE5530XKW1 Residential Dryer
Whirlpool LE5530XKW2 Residential Dryer
Whirlpool LE5530XMW0 Residential Dryer
Whirlpool LE5530XMW1 Residential Dryer
Whirlpool LE5530XMW2 Residential Dryer
Whirlpool LE5530XPW0 Residential Dryer
Whirlpool LE5530XSW0 Residential Dryer
Whirlpool LE5530XSW1 Residential Dryer
Whirlpool LE5535XPW0 Residential Dryer
Whirlpool LE5550XTG0 ELECTRIC DRYER
Whirlpool LE5550XTN0 ELECTRIC DRYER
Whirlpool LE5550XTW0 Residential Dryer
Whirlpool LE5600XKW0 Residential Dryer
Whirlpool LE5600XMW0 Residential Dryer
Whirlpool LE5600XPW0 Residential Dryer
Whirlpool LE5600XSW0 Residential Dryer
Whirlpool LE5600XSW1 Residential Dryer
Whirlpool LE5605XPW0 Residential Dryer
Whirlpool LE5650XKW0 Residential Dryer
Whirlpool LE5650XKW1 Residential Dryer
Whirlpool LE5650XMW0 Residential Dryer
Whirlpool LE5650XMW1 Residential Dryer
Whirlpool LE5650XMW2 Residential Dryer
Whirlpool LE5700XKW0 Residential Dryer
Whirlpool LE5700XKW1 Residential Dryer
Whirlpool LE5700XMW0 Residential Dryer
Whirlpool LE5700XMW1 Residential Dryer
Whirlpool LE5700XMW2 Residential Dryer
Whirlpool LE5700XPW0 Residential Dryer
Whirlpool LE5700XSNW ELECTRIC DRYER
Whirlpool LE5700XSW0 Residential Dryer
Whirlpool LE5705XPW0 Residential Dryer
Whirlpool LE5705XPW1 Residential Dryer
Whirlpool LE5720XPW0 Residential Dryer
Whirlpool LE5720XSW0 Residential Dryer
Whirlpool LE5720XSW1 Residential Dryer
Whirlpool LE5725XPW0 Residential Dryer
Whirlpool LE5750XKW0 Residential Dryer
Whirlpool LE5750XKW1 Residential Dryer
Whirlpool LE5750XKW2 Residential Dryer
Whirlpool LE5750XMW0 Residential Dryer
Whirlpool LE5750XMW1 Residential Dryer
Whirlpool LE5760XSW0 Residential Dryer
Whirlpool LE5760XSW1 Residential Dryer
Whirlpool LE5770XWW0 Residential Dryer
Whirlpool LE5780XKW0 Residential Dryer
Whirlpool LE5780XKW1 Residential Dryer
Whirlpool LE5780XMW0 Residential Dryer
Whirlpool LE5780XMW1 Residential Dryer
Whirlpool LE5780XMW2 Residential Dryer
Whirlpool LE5790XMW0 Residential Dryer
Whirlpool LE5790XMW1 Residential Dryer
Whirlpool LE5790XPW0 Residential Dryer
Whirlpool LE5790XSW0 Residential Dryer
Whirlpool LE5790XSW1 Residential Dryer
Whirlpool LE5795XMW0 Residential Dryer
Whirlpool LE5795XPW0 Residential Dryer
Whirlpool LE5795XPW1 Residential Dryer
Whirlpool LE5800XKW0 DRYER
Whirlpool LE5800XKW1 Residential Dryer
Whirlpool LE5800XMW0 Residential Dryer
Whirlpool LE5800XMW1 Residential Dryer
Whirlpool LE5800XMW2 Residential Dryer
Whirlpool LE5800XPW0 Residential Dryer
Whirlpool LE5800XPW1 Residential Dryer
Whirlpool LE5800XSN3 ELECTRIC DRYER
Whirlpool LE5800XSW0 Residential Dryer
Whirlpool LE5800XSW1 Residential Dryer
Whirlpool LE5800XSW2 Residential Dryer
Whirlpool LE5800XSW3 Residential Dryer
Whirlpool LE5805XPW0 Residential Dryer
Whirlpool LE5810XPW0 Residential Dryer
Whirlpool LE5900XSW0 Residential Dryer
Whirlpool LE5920XKW0 Residential Dryer
Whirlpool LE5920XKW1 Residential Dryer
Whirlpool LE5920XMW0 Residential Dryer
Whirlpool LE5920XMW1 Residential Dryer
Whirlpool LE5920XMW2 Residential Dryer
Whirlpool LE5950XSW0 Residential Dryer
Frigidaire LE600AXD1 Wwh(v2) / 27 " Laundry Center
Frigidaire LE600AXD2 Wwh(v2) / 27 " Laundry Center
Frigidaire LE600AXW1 Wwh(v1) / 27 " Laundry Center
Frigidaire LE600AXW2 Wwh(v1) / 27 " Laundry Center
Frigidaire LE600MXD1 Wwh(v2) / 27 " Laundry Center
Frigidaire LE600MXD2 Wwh(v2) / 27 " Laundry Center
Frigidaire LE600MXD3 Wwh(v2) / 27 " Laundry Center
Frigidaire LE600MXW1 Wwh(v1) / 27 " Laundry Center
Frigidaire LE600MXW2 Wwh(v1) / 27 " Laundry Center
  #2 (permalink)
Old 11-03-2008, 05:44 AM
Senior Expert
APP Volunteer
kayakcrzy will become famous soon enough
Default
I was wondering since you have the meter, and everything checks good, have you checked the power coming into the dryer, where the plug hooks up to the terminal block? Just because the dryer runs, does not mean the dryer is getting full power. Tom ********************************************
  #3 (permalink)
Old 11-03-2008, 09:16 AM
Junior Member
Thumbs up
That was it. The main double breaker to the dryer was half flipped. Thank you! !!!!!!!!
  #4 (permalink)
Old 11-03-2008, 01:27 PM
Senior Expert
APP Volunteer
Default
Glad to have helped. It would have made you mad to call a guy like me, to come out, and flip the breaker. Cool!!! Tom ********************************************
  #5 (permalink)
Old 11-04-2008, 09:16 AM
Junior Member
Default
Quote:
Oh yeah, I was close. In the 19 years I've lived here, that's the first time the breaker failed me.
I told a lady freind of my "experience". She said "Too much knowledge can be a bad thing sometimes. As a woman I would have checked the breaker first thing." But she did continue to say that since it was spinning she may have called someone herself.
Hopefully my experience will help others.
Thank you again!
  #6 (permalink)
Old 11-04-2008, 10:12 AM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
Always wanting to go for my meters or my gauges first, a boss I had was constantly drilling me, "Always check for the low-tech problem/solution first." It took me a long time to learn that the majority of problems with appliances fall in that category.
  #7 (permalink)
Old 11-04-2008, 02:37 PM
Senior Expert
APP Volunteer
Default
I herd that. Tom ********************************************
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Coil iceing up, evaparator ohms out good fan working Greg jackson Refrigerator & Freezer Repair 1 10-26-2009 04:43 AM
Heater, defrost / Thermostat / detrost Ohms sccraven Oven Repair (including Ranges and Cooktops) 0 09-27-2009 01:21 PM
Temp sensor read good Ohms, oven won't heat properly jaminels Oven Repair (including Ranges and Cooktops) 0 04-05-2009 09:15 AM
Elec dryer, low heat, moisture monitor reads low moisture ratflinger Dryer Repair 3 11-17-2008 08:52 AM
Dishwasher not heating (element/thermostat good) jkordzi Dishwasher Repair 2 01-20-2008 06:03 PM
