Discuss
Dryer heat problem
 in
Dryer Repair
Gas will ignite when dryer first started and dryer will heat up. After a little time, dryer gets cool and
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer heat problem
  #1 (permalink)
Old 10-01-2007, 04:14 PM
Junior Member
Dale is on a distinguished road
Cool Dryer heat problem
Model Number: TGDX640JQ1   Brand: Whirlpool   Age: 5 - 10 years
Gas will ignite when dryer first started and dryer will heat up. After a little time, dryer gets cool and will not reignite. After leaving dryer off for a bit, same thing. Heat, then no heat.
I have had the back off. Venting is clear and I have checked the cycling thermostat, thermal fuse and high limit thermostat. I've never done this before. The directions for the tester I bought said when set on RX1, they should read zero, which all three did, except when I put the the cycling thermostat on a heat source, then it read infinity. The only odd thing was when testing the high limit thermostat, it didn't read zero right away. I had to leave the tester probes on it for a few seconds before the meter went all the way to zero (totally a novice here so don't know what's important).
Needless to say, put the dryer back together and nothing solved. I've read a few posts and saw gas coils mentioned. Where should I start next?
Ads By Google
Related Models
Whirlpool TGDX640JQ1
Whirlpool TGDX640JQ2
Whirlpool TGDX640JQ3 29"gas Dryer
Whirlpool TGDX640PQ0 29" Gas Dryer
Whirlpool TGDX640PQ1 29"gas Dryer
Tappan TGF303AWA Tappan/gas Range
Tappan TGF303BWA Tappan/gas Range
Tappan TGF303BWB Tappan/gas Range
Tappan TGF303BWC Tappan/gas Range
Frigidaire TGF303BWD Tappan/range
Tappan TGF303BWE Tappan/range
Tappan TGF317AUA Tappan/range
Tappan TGF317AUB Tappan/gas Range
Tappan TGF317AWA Tappan/range
Tappan TGF317AWB Tappan/gas Range
Tappan TGF317BUA Tappan/gas Range
Tappan TGF317BUB Tappan/gas Range
Tappan TGF317BUC Tappan/gas Range
Tappan TGF317BWA Tappan/gas Range
Tappan TGF317BWB Tappan/gas Range
Tappan TGF317BWC Tappan/gas Range
Tappan TGF317DUA Tappan/gas Range
Tappan TGF317DUB Tappan/gas Range
Tappan TGF317DUC Tappan/range
Tappan TGF317DWA Tappan/gas Range
Tappan TGF317DWB Tappan/gas Range
Tappan TGF317DWC Tappan/range
Tappan TGF317DWD Tappan/range
Tappan TGF317DWE Tappan/range
Tappan TGF317ESA Tappan/range
Tappan TGF317ESB Tappan/range
Tappan TGF317ESC Tappan/range
Tappan TGF317ESD Tappan/range
Tappan TGF320DUA Tappan/gas Range
Tappan TGF320DWA Tappan/gas Range
Tappan TGF320DWB Tappan/range
Tappan TGF320DWC Tappan/range
Tappan TGF324BHDD Tappan/gas Range
Frigidaire TGF324BHWA
Frigidaire TGF324BHWB
Tappan TGF324BHWC Tappan/range
Tappan TGF324BHWD Tappan/gas Range
Tappan TGF324BHWE Tappan/gas Range
Tappan TGF324WHSD Tappan/gas Range
Tappan TGF326WHSD Tappan/gas Range
Tappan TGF326WHSE Tappan/gas Range
Tappan TGF326WHTD Tappan/gas Range
Tappan TGF326WHTE Tappan/gas Range
Frigidaire TGF330WCDA Tap(v1) / Gas Range
Frigidaire TGF330WCDB Tap(v1) / Gas Range
Frigidaire TGF330WCDC Tap(v1) / Gas Range
Frigidaire TGF330WCDD Tap(v1) / Gas Range
Frigidaire TGF330WCDE Tap(v1) / Gas Range
Frigidaire TGF330WCWA Tap(v2) / Gas Range
Frigidaire TGF330WCWB Tap(v2) / Gas Range
Frigidaire TGF330WCWC Tap(v2) / Gas Range
Frigidaire TGF330WCWD Tap(v2) / Gas Range
Frigidaire TGF330WCWE Tap(v2) / Gas Range
Frigidaire TGF331SCDA Tap(v1) / Gas Range
Frigidaire TGF331SCDB Tap(v1) / Gas Range
Frigidaire TGF331SCDC Tap(v1) / Gas Range
Frigidaire TGF331SCWA Tap(v2) / Gas Range
Frigidaire TGF331SCWB Tap(v2) / Gas Range
Frigidaire TGF331SCWC Tap(v2) / Gas Range
Frigidaire TGF332BCDA Tap(v1) / Gas Range
Frigidaire TGF332BCDB Tap(v1) / Gas Range
Frigidaire TGF332BCDC Tap(v1) / Gas Range
Frigidaire TGF332BCDD Tap(v1) / Gas Range
Frigidaire TGF332BCDE Tap(v1) / Gas Range
Frigidaire TGF332BCWA Tap(v2) / Gas Range
Frigidaire TGF332BCWB Tap(v2) / Gas Range
Frigidaire TGF332BCWC Tap(v2) / Gas Range
Frigidaire TGF332BCWD Tap(v2) / Gas Range
Frigidaire TGF332BCWE Tap(v2) / Gas Range
Frigidaire TGF334BCDA Tap(v1) / Gas Range
Frigidaire TGF334BCDB Tap(v1) / Gas Range
Frigidaire TGF334BCDC Tap(v1) / Gas Range
Frigidaire TGF334BCDD Tap(v2) / Gas Range
Frigidaire TGF334BCDE Tap(v1) / Gas Range
Frigidaire TGF334BCDF Tap(v1) / Gas Range
Frigidaire TGF334BCDG Tap(v1) / Gas Range
Frigidaire TGF334BCDH Tap(v1) / Gas Range
Frigidaire TGF334BCWA Tap(v2) / Gas Range
Frigidaire TGF334BCWB Tap(v2) / Gas Range
Frigidaire TGF334BCWC Tap(v3) / Gas Range
Frigidaire TGF334BCWD Tap(v4) / Gas Range
Frigidaire TGF334BCWE Tap(v2) / Gas Range
Frigidaire TGF334BCWF Tap(v2) / Gas Range
Frigidaire TGF334BCWG Tap(v2) / Gas Range
Frigidaire TGF334BCWH Tap(v2) / Gas Range
Frigidaire TGF334WFSA Tap(v0) / Gas Range
Frigidaire TGF334WFSB Tap(v0) / Gas Range
Frigidaire TGF334WFSC Tap(v0) / Gas Range
Frigidaire TGF334WFSD Tap(v0) / Range
Frigidaire TGF335BCDA Tap(v1) / Gas Range
Frigidaire TGF335BCDB Tap(v1) / Gas Range
Frigidaire TGF335BCDC Tap(v1) / Gas Range
Frigidaire TGF335BCDD Tap(v1) / Gas Range
Frigidaire TGF335BCDE Tap(v1) / Gas Range
Frigidaire TGF335BCWA Tap(v2) / Gas Range
Frigidaire TGF335BCWB Tap(v2) / Gas Range
Frigidaire TGF335BCWC Tap(v2) / Gas Range
Frigidaire TGF335BCWD Tap(v2) / Gas Range
Frigidaire TGF335BCWE Tap(v2) / Gas Range
Frigidaire TGF335CFSA Tap(v1) / Gas Range
Frigidaire TGF335CFTA Tap(v2) / Gas Range
Tappan TGF336ASA Tappan/gas Range
Tappan TGF336ASB Tappan/gas Range
Tappan TGF336ASC Tappan/gas Range
Tappan TGF336ASD Tappan/gas Range
Tappan TGF336ASE Tappan/gas Range
Tappan TGF336ASF Tappan/gas Range
Tappan TGF336ASG Tappan/gas Range
Tappan TGF336ASH Tappan/range
Tappan TGF336ASJ Tappan/range
Tappan TGF336AUA Tappan/gas Range
Tappan TGF336AUC Tappan/gas Range
Tappan TGF336AUD Tappan/gas Range
Tappan TGF336AUE Tappan/gas Range
Tappan TGF336AUF Tappan/gas Range
  #2 (permalink)
Old 10-02-2007, 03:54 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
Pull front panel off and remove drum. Monitor the main gas electrical connector with a meter. Start dryer, if voltage is steady when the flame goes out, you have bad gas valve coils. Click on your model # above to get part #.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
No Heat Dryer Problem SpeedyG Dryer Repair 4 02-21-2010 05:52 AM
dryer heat problem ribwholesalers Dryer Repair 1 07-09-2009 04:00 AM
dryer heat problem wtelwe Dryer Repair 1 02-11-2009 03:24 AM
