Discuss
Dryer doesn't start.
 in
Dryer Repair
Just started looking at it. Dryer does not start. Do not have a schematic. Hand down dryer. With the door
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer doesn't start.
  #1 (permalink)
Old 11-04-2010, 01:48 PM
Junior Member
sanmigmike is on a distinguished road
Default Dryer doesn't start.
Model Number: KEYL517BWH2   Brand: Kitchen Aid   Age: More than 10 years
With the door closed or the door switch pressed we get a ticking sound or other sounds from the timer. Can't find the id for the wires on the Press to Start button (FSP 3398094) so calling the wiring Blue 1 and Blue 2 and PinkBlack we get resistance.
normal button pressed
PB-B1 2.3 1.0
PB-B2 1.8 1.0
B1-B2 4.2 0.0...not infinity.
Next step to check the thermal fuse? And then?
Thanks. Always hated the electrical system stuff in ground school...load shedding buses blah, blah, blah, if this does that what does that thing do...? So now I get to deal with with the appliances and old cars and not so old cars. Maybe I should have tried to pay more attention eh?
Ads By Google
Related Models
Whirlpool KEYL517BWH2
Whirlpool KEYS677EQ0
Whirlpool KEYS677EQ1
Whirlpool KEYS677EQ2
Whirlpool KEYS677EZ0
Whirlpool KEYS677EZ1
Whirlpool KEYS677EZ2
Whirlpool KEYS700EQ0
Whirlpool KEYS700EQ1
Whirlpool KEYS700EZ0
Whirlpool KEYS700EZ1
Whirlpool KEYS700GQ0
Whirlpool KEYS700GT0
Whirlpool KEYS700GZ0
Whirlpool KEYS700JQ0
Whirlpool KEYS700JQ1
Whirlpool KEYS700JT0
Whirlpool KEYS700JT1
Whirlpool KEYS700LQ0
Whirlpool KEYS700LQ1 29"electric Dryer
Whirlpool KEYS700LT0
Whirlpool KEYS700LT1 29"electric Dryer
Whirlpool KEYS710JQ0
Whirlpool KEYS710JQ1
Whirlpool KEYS710LQ0
Whirlpool KEYS710LQ1 29"electric Dryer
Whirlpool KEYS750GQ0
Whirlpool KEYS750GT0
Whirlpool KEYS750GZ0
Whirlpool KEYS750JQ0
Whirlpool KEYS750JQ1
Whirlpool KEYS750JT0
Whirlpool KEYS750JT1
Whirlpool KEYS750LQ0
Whirlpool KEYS750LQ1 29"electric Dryer
Whirlpool KEYS750LQ2 29"electric Dryer
Whirlpool KEYS750LT0
Whirlpool KEYS750LT1 29"electric Dryer
Whirlpool KEYS750LT2 29"electric Dryer
Whirlpool KEYS777EQ0
Whirlpool KEYS777EQ1
Whirlpool KEYS777EZ0
Whirlpool KEYS777EZ1
Whirlpool KEYS850GQ0
Whirlpool KEYS850GT0
Whirlpool KEYS850GZ0
Whirlpool KEYS850JQ0
Whirlpool KEYS850JQ1
Whirlpool KEYS850JT0
Whirlpool KEYS850JT1
Whirlpool KEYS850LE0
Whirlpool KEYS850LE1 29"electric Dryer
Whirlpool KEYS850LE2 29"electric Dryer
Whirlpool KEYS850LQ0
Whirlpool KEYS850LQ1 29"electric Dryer
Whirlpool KEYS850LQ2 29"electric Dryer
Whirlpool KEYS850LT0
Whirlpool KEYS850LT1 29"electric Dryer
Whirlpool KEYS850LT2 29"electric Dryer
Whirlpool KEYS855JE0
Whirlpool KEYS855JE1
Whirlpool KEYS977EQ0
Whirlpool KEYS977EZ0
Whirlpool KEYW770BAL0
Whirlpool KEYW770BWH0
Whirlpool KEYW770BWH2
Whirlpool KEYW777BWH0
Whirlpool KEYW777BWH1
Whirlpool KEYW777BWH2
Whirlpool KEYW778BAL0
Whirlpool KEYW778BAL1
Whirlpool KEYW778BAL2
Whirlpool KEYW870BAL0
Whirlpool KEYW870BWH0
Whirlpool KEYW877BWH0
Whirlpool KEYW878BAL0
Whirlpool KEYW977BWH0
Bosch KF100-190
Frigidaire KF100HDD1 Wwh(v1) / Electric Range
Frigidaire KF100HDH1 Wwh(v2) / Electric Range
Frigidaire KF100HDW1 Wwh(v3) / Electric Range
Frigidaire KF100KDD0 Wwh(v2) / Electric Range
Frigidaire KF100KDD1 Wwh(v2) / Electric Range
Frigidaire KF100KDD2 Wwh(v5) / Electric Range
Frigidaire KF100KDD3 Wwh(v8) / Electric Range
Frigidaire KF100KDD4 Wwh(v2) / Electric Range
Frigidaire KF100KDD5 Wwh(v2) / Electric Range
Frigidaire KF100KDH0 Wwh(v3) / Electric Range
Frigidaire KF100KDH1 Wwh(v3) / Electric Range
Frigidaire KF100KDH2 Wwh(v6) / Electric Range
Frigidaire KF100KDH3 Wwh(v9) / Electric Range
Frigidaire KF100KDH4 Wwh(v3) / Electric Range
Frigidaire KF100KDH5 Wwh(v3) / Electric Range
Frigidaire KF100KDW0 Wwh(v1) / Electric Range
Frigidaire KF100KDW1 Wwh(v1) / Electric Range
Frigidaire KF100KDW2 Wwh(v4) / Electric Range
Frigidaire KF100KDW3 Wwh(v7) / Electric Range
Frigidaire KF100KDW4 Wwh(v1) / Electric Range
Frigidaire KF100KDW5 Wwh(v1) / Electric Range
Frigidaire KF200GDD1 Wwh(v1) / Gas Range
Frigidaire KF200GDD2 Wwh(v3) / Electric Range
Frigidaire KF200GDH1 Wwh(v2) / Gas Range
Frigidaire KF200GDH2 Wwh(v2) / Electric Range
Frigidaire KF200GDW1 Wwh(v3) / Gas Range
Frigidaire KF200GDW2 Wwh(v1) / Electric Range
Frigidaire KF200KDD0 Wwh(v2) / Electric Range
Frigidaire KF200KDD1 Wwh(v4) / Electric Range
Frigidaire KF200KDD2 Wwh(v6) / Electric Range
Frigidaire KF200KDD3 Wwh(v8) / Electric Range
Frigidaire KF200KDD4 Wwh(v2) / Electric Range
Frigidaire KF200KDW0 Wwh(v1) / Electric Range
Frigidaire KF200KDW1 Wwh(v3) / Electric Range
Frigidaire KF200KDW2 Wwh(v5) / Electric Range
Frigidaire KF200KDW3 Wwh(v7) / Electric Range
Frigidaire KF200KDW4 Wwh(v1) / Electric Range
Frigidaire KF201HDD0 Wwh(v1) / 21 " Free Standing Electric Range
Frigidaire KF201HDD1 Wwh(v2) / 21 " Free Standing Electric Range
Frigidaire KF201HDD2 Wwh(v2) / Electric Range
Frigidaire KF201HDD3 Wwh(v1) / Electric Range
Frigidaire KF201HDD4 Wwh(v2) / Electric Range
  #2 (permalink)
Old 11-04-2010, 03:03 PM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
PB-B1 2.3 1.0
PB-B2 1.8 1.0
Mike,
It's not that elaborate,
Are you sure you have 220 VAC at the dryer terminal block ?
Yes, your next move will be the thermal fuse, down on the blower housing, it should be a closed circuit across the terminals with the wires off. You could also bypass the fuse to test the unit(ONLY).
Part number: AP3132867
If your fuse is open, you need to start looking for other possible failed or weak parts,
First check the exhaust venting system for kinks or clogs.
Then the regulating thermostat, and hi limit thermostat on the heater, all thermostats should be a closed circuit at room temperature.
I'm pretty sure you'll find an open thermal fuse, and a clogged vent,or the machine was overloaded or something like that.
Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 11-04-2010, 03:19 PM
Junior Member
Default First dumb question....
The thermal fuse needs to be checked with the wires off? Okay so I'll go back and do that again. The other ones, wire off too? And I'll check for 220, I seem to recall a posting on that.
  #4 (permalink)
Old 11-04-2010, 03:39 PM
Junior Member
Default Maybe AHA!
I think I have the right part...infinite resistance when the wires are pulled off. But it has on it G4AP0500 TF091C HDM1 3392519? Would be nice if it is simple so now the question is why it opened hmmh. Dryer vent hose doesn't look too bad but there is a bit more lint in the cabinet that I expected.
  #5 (permalink)
Old 11-04-2010, 04:24 PM
Senior Expert
Default
Mike, the fuse is temperature sensitive, approximately 250 to 300 degrees.
It can fail on its own, but is usually due to a overheat problem.
If the venting is clear,
Vacuum out all the lint , check the blower for clog,lint build up, and test the start with the new fuse, or jump fuse.
You'll be OK from there.
__________________
Joe M. APP TEAM
  #6 (permalink)
Old 11-05-2010, 03:55 PM
Junior Member
Default Cleaned out the dryer vent tubing...
Seems to be working now. Long term I'm going to move the 220 plug off the floor so the vent can have a straight run. Go to a solid tube rather than that foil wire coil stuff. Did clean out the cabinet and and checked the limit switch next to the temp fuse and it was working okay. So replacing the temp fuse fixed it.
Thank you very much!
Michael
  #7 (permalink)
Old 11-05-2010, 04:36 PM
Senior Expert
Default
Michael
Michael,
You're very welcome !!,
Glad to hear you're up and running... Great Job.
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
HOT POINT DRYER has power but start button doesn't start the dryer. HOT POINT Dryer Repair 2 08-01-2011 06:47 PM
Dryer will not start - will power up, but when push the start button, will not start perduena Dryer Repair 0 07-12-2010 07:14 PM
dryer start button flashing and not clicking to start dryer lawfamily Dryer Repair 0 06-21-2010 07:43 PM
whirlpol dryer won't start-just hums when I push the start button bdubois Dryer Repair 27 02-18-2010 07:36 PM
Kenmore Dryer won't start unless PTS (push to start) button depressed and held trp Dryer Repair 1 06-07-2009 06:13 AM
