Our Electric Dryer Has Stopped So I Was Checking Out Your Forum. Our's Has Given The Same Problems As Some Of The Others. It Sometimes Won't Stop Running In The Automatic Settings. Now It Won't Run At All. You Can Turn The Power On And Set The Cycle But When You Press Start It Just Clicks. The Timer Will Still Count Down But The Tub Doesn't Turn And It Doesn't Get Hot. At First We Got And F01 Code But None Of The Troubleshooting For That Fixed Anything. We Did A Diagnostic Test And Got A F26 Code. I Read About The Person That Determined Their Problem Was The Electronic Board. We Had Some Heavy Winds The Other Day That Took Down Our Power Line To The House And Bent The Pole Into Our Meter Box. Should We Maybe Just Assume That The Board Was Possibly Shorted Out Or Something When This Happened? We Don't Have A Lot Of Money For A Repairman. My Husband Usually Fixes Our Things.
